1. Device Management
#include "zcl/se/zcl.device_mgmt.h"
Functions
ZbZclDeviceMgmtClientAlloc
struct ZbZclClusterT * ZbZclDeviceMgmtClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclDeviceMgmtClientCallbacksT *callbacks, void *arg);
Create a new instance of the Device Management Client cluster
Parameters
| zb | Zigbee stack instance |
| endpoint | Endpoint on which to create cluster |
| arg | Pointer to application data that will included in the callback when invoked. |
Return
- Cluster pointer, or NULL if there is an error
ZbZclDeviceMgmtClientGetChangeSupplier
enum ZclStatusCodeT ZbZclDeviceMgmtClientGetChangeSupplier(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Change of Supplier command
Parameters
| cluster | Cluster instance from which to send this command |
| dst | Destination address for request |
| callback | Callback function that will be invoked when the response is received. |
| arg | Pointer to application data that will be included in the callback when invoked. |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
ZbZclDeviceMgmtClientGetChangeTenancy
enum ZclStatusCodeT ZbZclDeviceMgmtClientGetChangeTenancy(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Change of Tenancy command
Parameters
Return
ZbZclDeviceMgmtClientGetCin
enum ZclStatusCodeT ZbZclDeviceMgmtClientGetCin(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get CIN command
Parameters
Return
ZbZclDeviceMgmtClientGetSiteId
enum ZclStatusCodeT ZbZclDeviceMgmtClientGetSiteId(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Site ID command
Parameters
Return
ZbZclDeviceMgmtClientReportEventConfig
enum ZclStatusCodeT ZbZclDeviceMgmtClientReportEventConfig(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtReportEvtConfigT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Report Event Configuration command
Parameters
| info | Report Event Configuration command structure |
Return
ZbZclDeviceMgmtClientReqNewPassword
enum ZclStatusCodeT ZbZclDeviceMgmtClientReqNewPassword(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtReqNewPassT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request New Password command
Parameters
| info | Request New Password command structure |
Return
ZbZclDeviceMgmtMirrorAlloc
struct ZbZclClusterT * ZbZclDeviceMgmtMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *device_mgmt_server, struct ZbZclClusterT *meter_mirror);
Allocates a Device Management Client Mirror cluster. The caller (application) must attach any attributes to the cluster you want to mirror.
Parameters
| device_mgmt_server | Pointer to Device Mgmt Server cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
| meter_mirror | Pointer to Metering Mirror cluster. This is used to queue any commands that need to be forwarded to the BOMD when it wakes up. |
Return
ZbZclDeviceMgmtParseReportEvtConfig
enum ZclStatusCodeT ZbZclDeviceMgmtParseReportEvtConfig(struct ZbZclClusterT *cluster, struct ZbApsdeDataIndT *dataIndPtr, struct ZbZclDeviceMgmtReportEvtConfigT *info);
Parse a Report Event Configuration command
Parameters
| dataIndPtr | Data Indication structure containing the command payload to be parsed |
Return
ZbZclDeviceMgmtParseReqNewPassRsp
bool ZbZclDeviceMgmtParseReqNewPassRsp(const uint8_t *buf, unsigned int len, struct ZbZclDeviceMgmtReqNewPassRspT *rsp);
Parse a Request New Password Response command
Parameters
| buf | Buffer containing response information |
| len | Length of response information in bytes |
| rsp | Request New Password Response command structure |
Return
- True on success, false otherwise
ZbZclDeviceMgmtParseUpdateCin
bool ZbZclDeviceMgmtParseUpdateCin(const uint8_t *buf, unsigned int len, struct ZbZclDeviceMgmtUpdateCinT *rsp);
Parse an Update CIN command
Parameters
| rsp | Update CIN command structure |
Return
ZbZclDeviceMgmtParseUpdateSiteId
bool ZbZclDeviceMgmtParseUpdateSiteId(const uint8_t *buf, unsigned int len, struct ZbZclDeviceMgmtUpdateSiteIdT *rsp);
Parse an Update Site ID command
Parameters
| rsp | Update Site ID command structure |
Return
ZbZclDeviceMgmtServerAlloc
struct ZbZclClusterT * ZbZclDeviceMgmtServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclDeviceMgmtServerCallbacksT *callbacks, void *arg);
Create a new instance of the Device Management Server cluster
Parameters
Return
ZbZclDeviceMgmtServerGetEventConfigReq
enum ZclStatusCodeT ZbZclDeviceMgmtServerGetEventConfigReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtGetEventConfigT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Event Configuration command
Parameters
| info | Get Event Configuration command structure |
Return
ZbZclDeviceMgmtServerPublishChangeSupplierRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerPublishChangeSupplierRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtPublishChangeSupplierT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Change of Supplier as a response to the Get Change of Supplier command.
Parameters
| dst | Destination address for response, including sequence number and tx options |
| info | Publish Change of Supplier command structure |
Return
ZbZclDeviceMgmtServerPublishChangeSupplierUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerPublishChangeSupplierUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtPublishChangeSupplierT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Change of Supplier as an unsolicited command
Parameters
Return
ZbZclDeviceMgmtServerPublishChangeTenancyRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerPublishChangeTenancyRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtPublishChangeTenancyT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Change of Tenancy as a response to the Get Change of Tenancy command.
Parameters
| info | Publish Change of Tenancy command structure |
Return
ZbZclDeviceMgmtServerPublishChangeTenancyUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerPublishChangeTenancyUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtPublishChangeTenancyT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Change of Tenancy as an unsolicited command
Parameters
Return
ZbZclDeviceMgmtServerReqNewPassRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerReqNewPassRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtReqNewPassRspT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Request New Password Response as a response to the Request New Password command.
Parameters
| info | Request New Password Response command structure |
Return
ZbZclDeviceMgmtServerReqNewPassRspUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerReqNewPassRspUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtReqNewPassRspT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request New Password Response as an unsolicited command
Parameters
Return
ZbZclDeviceMgmtServerSetEventConfigReq
enum ZclStatusCodeT ZbZclDeviceMgmtServerSetEventConfigReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtSetEventConfigT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Event Configuration command
Parameters
| info | Set Event Configuration command structure |
Return
ZbZclDeviceMgmtServerUpdateCinRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerUpdateCinRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtUpdateCinT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send an Update CIN as a response to the Get CIN command.
Parameters
| info | Update CIN command structure |
Return
ZbZclDeviceMgmtServerUpdateCinUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerUpdateCinUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtUpdateCinT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Update CIN as an unsolicited command
Parameters
Return
ZbZclDeviceMgmtServerUpdateSiteIdRsp
enum ZclStatusCodeT ZbZclDeviceMgmtServerUpdateSiteIdRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDeviceMgmtUpdateSiteIdT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send an Update SiteID as a response to the Get SiteID command.
Parameters
| info | Update SiteID command structure |
Return
ZbZclDeviceMgmtServerUpdateSiteIdUnsolic
enum ZclStatusCodeT ZbZclDeviceMgmtServerUpdateSiteIdUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDeviceMgmtUpdateSiteIdT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Update SiteID as an unsolicited command
Parameters
Return
Enumerations
ZbZclDeviceMgmtCliAttrT
Device Management Client Attribute IDs
| ZCL_DEVICE_MGMT_CLI_ATTR_ProviderID | Provider ID |
| ZCL_DEVICE_MGMT_CLI_ATTR_ReceivedProviderID | ReceivedProvider ID |
| ZCL_DEVICE_MGMT_CLI_ATTR_PRICE_START | Price Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_TOUTariffActivation | TOUTariffActivation |
| ZCL_DEVICE_MGMT_CLI_ATTR_BlockTariffactivated | BlockTariffactivated |
| ZCL_DEVICE_MGMT_CLI_ATTR_BlockTOUTariffActivated | BlockTOUTariffActivated |
| ZCL_DEVICE_MGMT_CLI_ATTR_SingleTariffRateActivated | SingleTariffRateActivated |
| ZCL_DEVICE_MGMT_CLI_ATTR_AsychronousBillingOccurred | AsychronousBillingOccurred |
| ZCL_DEVICE_MGMT_CLI_ATTR_SynchronousBillingOccurred | SynchronousBillingOccurred |
| ZCL_DEVICE_MGMT_CLI_ATTR_TariffNotSupported | Tariff NotSupported |
| ZCL_DEVICE_MGMT_CLI_ATTR_PriceClusterNotFound | PriceClusterNotFound |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceReceived | PublishPriceReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceActioned | PublishPriceActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceCancelled | PublishPriceCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceRejected | PublishPriceRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishTariffInformation | PublishTariffInformation Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishTariffInformationActio ned | PublishTariffInformation Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishTariffInformationCanc elled | PublishTariffInformation Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishTariffInformationReje cted | PublishTariffInformation Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceMatrixReceived | PublishPriceMatrixReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceMatrixActioned | PublishPriceMatrixActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceMatrixCancelled | PublishPriceMatrixCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishPriceMatrixRejected | PublishPriceMatrixRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishBlockThresholdsRece ived | PublishBlockThresholdsReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishBlockThresholdsActio ned | PublishBlockThresholdsActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishBlockThresholdsCanc elled | PublishBlockThresholdsCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishBlockThresholdsReje cted | PublishBlockThresholdsRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PRICE_GROUP_ID | Price cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_METERING_START | Metering Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_CheckMeter | Check Meter |
| ZCL_DEVICE_MGMT_CLI_ATTR_LowBattery | Low Battery |
| ZCL_DEVICE_MGMT_CLI_ATTR_TamperDetect | Tamper Detect |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyStatus | Supply Status |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyQuality | Supply Quality |
| ZCL_DEVICE_MGMT_CLI_ATTR_LeakDetect | Leak Detect |
| ZCL_DEVICE_MGMT_CLI_ATTR_BatteryFailure | BatteryFailure |
| ZCL_DEVICE_MGMT_CLI_ATTR_LowVoltageL1 | LowVoltageL1 |
| ZCL_DEVICE_MGMT_CLI_ATTR_HighVoltageL1 | HighVoltageL1 |
| ZCL_DEVICE_MGMT_CLI_ATTR_UnderVoltage | UnderVoltage |
| ZCL_DEVICE_MGMT_CLI_ATTR_OverVoltage | OverVoltage |
| ZCL_DEVICE_MGMT_CLI_ATTR_PressureTooLow | PressureTooLow |
| ZCL_DEVICE_MGMT_CLI_ATTR_PressureTooHigh | PressureTooHigh |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetProfileCommandReceive d | Get Profile Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetProfileCommandActioned | Get Profile Command Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetProfileCommandCancelle d | Get Profile Command Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetProfileCommandRejected | Get Profile Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestMirrorResponseCom mandReceived | RequestMirrorResponse Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestMirrorResponseCom mandActioned | RequestMirrorResponse Command Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestMirrorResponseCom mandCancelled | RequestMirrorResponse Command Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestMirrorResponseCom mandRejected | RequestMirrorResponse Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_MirrorRemoved0CommandR eceived | MirrorRemoved Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_MirrorRemoved0CommandA ctioned | MirrorRemoved Command Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_MirrorRemoved0CommandC ancelled | MirrorRemoved Command Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_MirrorRemoved0CommandR ejected | MirrorRemoved Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetSampledDataCommandR eceived | GetSampledData Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetSampledDataCommandA ctioned | GetSampledData Command Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetSampledDataCommandC ancelled | GetSampledData Command Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_GetSampledDataCommandR ejected | GetSampledData Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyON | Supply ON |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyARMED | Supply ARMED |
| ZCL_DEVICE_MGMT_CLI_ATTR_SupplyOFF | Supply OFF |
| ZCL_DEVICE_MGMT_CLI_ATTR_METERING_GROUP_ID | Metering cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_MESSAGING_START | Messaging Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_MessageConfirmationSent | Message Confirmation Sent |
| ZCL_DEVICE_MGMT_CLI_ATTR_DisplayMessageReceived | DisplayMessageReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_DisplayMessageActioned | DisplayMessageActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_DisplayMessageCancelled | DisplayMessageCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_DisplayMessageRejected | DisplayMessageRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_CancelMessageReceived | CancelMessageReceived |
| ZCL_DEVICE_MGMT_CLI_ATTR_CancelMessageActioned | CancelMessageActioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_CancelMessageCancelled | CancelMessageCancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_CancelMessageRejected | CancelMessageRejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_MESSAGING_GROUP_ID | Messaging cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_PREPAYMENT_START | Prepayment Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_LowCredit | Low Credit |
| ZCL_DEVICE_MGMT_CLI_ATTR_NoCredit | No Credit (Zero Credit) |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditExhausted | Credit Exhausted |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditEnabled | Emergency Credit Enabled |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditExhausted | Emergency Credit Exhausted |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustment | Credit Adjustment |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustFail | Credit Adjust Fail |
| ZCL_DEVICE_MGMT_CLI_ATTR_PrepayClusterNotFound | Prepay Cluster Not Found |
| ZCL_DEVICE_MGMT_CLI_ATTR_SelectAvailableEmergencyCr editReceived | SelectAvailableEmergencyCredit Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_SelectAvailableEmergencyCr editActioned | SelectAvailableEmergencyCredit Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_SelectAvailableEmergencyCr editCancelled | SelectAvailableEmergencyCredit Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_SelectAvailableEmergencyCr editRejected | SelectAvailableEmergencyCredit Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditSetupRecei ved | Emergency Credit Setup Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditSetupActio ned | Emergency Credit Setup Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditSetupCanc elled | Emergency Credit Setup Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_EmergencyCreditSetupRejec ted | Emergency Credit Setup Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustmentReceived | Credit Adjustment Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustmentActioned | Credit Adjustment Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustmentCancelled | Credit Adjustment Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_CreditAdjustmentRejected | Credit Adjustment Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetLowCreditWarningLevelR eceived | Set Low Credit Warning Level Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetLowCreditWarningLevelA ctioned | Set Low Credit Warning Level Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetLowCreditWarningLevelC ancelled | Set Low Credit Warning Level Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetLowCreditWarningLevelR ejected | Set Low Credit Warning Level Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetMaximumCreditLimitRece ived | SetMaximumCreditLimit Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetMaximumCreditLimitActio ned | SetMaximumCreditLimit Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetMaximumCreditLimitCanc elled | SetMaximumCreditLimit Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetMaximumCreditLimitReje cted | SetMaximumCreditLimit Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PREPAYMENT_GROUP_ID | Prepayment cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_CALENDAR_START | Calendar Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_CalendarClusterNotFound | Calendar Cluster Not Found |
| ZCL_DEVICE_MGMT_CLI_ATTR_CalendarChangePassiveActi vated | Calendar Change Passive Activated |
| ZCL_DEVICE_MGMT_CLI_ATTR_CalendarChangePassiveUpd ated | Calendar Change Passive Updated |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCalendarReceived | PublishCalendar Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCalendarActioned | PublishCalendar Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCalendarCancelled | PublishCalendar Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCalendarRejected | PublishCalendar Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishDayProfileReceived | Publish Day Profile Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishDayProfileActioned | Publish Day Profile Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishDayProfileCancelled | Publish Day Profile Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishDayProfileRejected | Publish Day Profile Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishWeekProfileReceived | Publish Week Profile Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishWeekProfileActioned | Publish Week Profile Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishWeekProfileCancelled | Publish Week Profile Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishWeekProfileRejected | Publish Week Profile Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSeasonsReceived | Publish Seasons Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSeasonsActioned | Publish Seasons Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSeasonsCancelled | Publish Seasons Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSeasonsRejected | Publish Seasons Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSpecialDaysReceived | Publish Special Days Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSpecialDaysActioned | Publish Special Days Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSpecialDaysCancelle d | Publish Special Days Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishSpecialDaysRejected | Publish Special Days Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_CALENDAR_GROUP_ID | Calendar cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_DEVICE_MGMT_START | Device Management Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_Password1Change | Password1Change |
| ZCL_DEVICE_MGMT_CLI_ATTR_EventLogCleared | EventLogCleared |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoTReceived | Publish CoT Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoTActioned | Publish CoT Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoTCancelled | Publish CoT Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoTRejected | Publish CoT Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoSReceived | Publish CoS Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoSActioned | Publish CoS Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoSCancelled | Publish CoS Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_PublishCoSRejected | Publish CoS Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_ChangePasswordReceived | Change Password Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_ChangepasswordActioned | Change password Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_ChangePasswordCancelled | Change Password Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_ChangePasswordRejected | Change Password Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetEventConfigurationRecei ved | SetEventConfiguration Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetEventConfigurationAction ed | SetEventConfiguration Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetEventConfigurationCance lled | SetEventConfiguration Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_SetEventConfigurationReject ed | SetEventConfiguration Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateSiteIDReceived | UpdateSiteID Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateSiteIDActioned | UpdateSiteID Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateSiteIDCancelled | UpdateSiteID Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateSiteIDRejected | UpdateSiteID Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateCINReceived | UpdateCIN Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateCINActioned | UpdateCIN Actioned |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateCINCancelled | UpdateCIN Cancelled |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpdateCINRejected | UpdateCIN Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_DEVICE_MGMT_GROUP_ID | Device Management cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_TUNNEL_START | Tunnel Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_TunnelingClusterNotFound | Tunneling Cluster Not Found |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestTunnelCommandRe ceived | RequestTunnel Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestTunnelCommandRej ected | RequestTunnel Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_RequestTunnelCommandGe nerated | RequestTunnel Command Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_CloseTunnelCommandRecei ved | CloseTunnel Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_CloseTunnelCommandRejec ted | CloseTunnel Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_CloseTunnelCommandGener ated | CloseTunnel Command Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataCommandRecei ved | TransferData Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataCommandRejec ted | TransferData Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataCommandGene rated | TransferData Command Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataErrorCommand Received | TransferDataError Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataErrorCommand Rejected | TransferDataError Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_TransferDataErrorCommand Generated | TransferDataError Command Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_TUNNEL_GROUP_ID | Tunnel cluster Group ID (Last Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_OTA_START | OTA Event Configuration Attribute Set (First Id) |
| ZCL_DEVICE_MGMT_CLI_ATTR_FirmwareReadyForActivation | FirmwareReadyForActivation |
| ZCL_DEVICE_MGMT_CLI_ATTR_FirmwareActivated | FirmwareActivated |
| ZCL_DEVICE_MGMT_CLI_ATTR_FirmwareActivationFailure | Firmware Activation Failure |
| ZCL_DEVICE_MGMT_CLI_ATTR_PatchReadyForActivation | Patch Ready For Activation |
| ZCL_DEVICE_MGMT_CLI_ATTR_PatchActivated | Patch Activated |
| ZCL_DEVICE_MGMT_CLI_ATTR_PatchFailure | Patch Failure |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageNotifyCommandReceiv ed | Image Notify Command Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageNotifyCommandReject ed | Image Notify Command Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_QueryNextImageRequestGe nerated | Query Next Image Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_QueryNextImageResponseR eceived | Query Next Image Response Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_QueryNextImageResponseR ejected | Query Next Image Response Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageBlockRequestGenerat ed | Image Block Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImagePageRequestGenerate d | Image Page Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageBlockResponseReceiv ed | Image Block Response Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_ImageBlockResponseReject ed | Image Block Response Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpgradeEndRequestGenerat ed | Upgrade End Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpgradeEndResponseRecei ved | Upgrade End Response Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_UpgradeEndResponseReject ed | Upgrade End Response Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_QuerySpecificFileRequestGe nerated | Query Specific File Request Generated |
| ZCL_DEVICE_MGMT_CLI_ATTR_QuerySpecificFileResponse Received | Query Specific File Response Received |
| ZCL_DEVICE_MGMT_CLI_ATTR_QuerySpecificFileResponse Rejected | Query Specific File Response Rejected |
| ZCL_DEVICE_MGMT_CLI_ATTR_OTA_GROUP_ID | OTA cluster Group ID (Last Id) |
ZbZclDeviceMgmtSvrAttrT
Device Management Server Attribute IDs
| ZCL_DEVICE_MGMT_SVR_ATTR_ProviderID | ProviderID (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProviderName | ProviderName (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProviderContactDetails | ProviderContactDetails (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderID | ProposedProviderID (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderName | ProposedProviderName (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderChangeD ate | ProposedProviderChangeDate/Time (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderChangeC ontrol | ProposedProviderChangeControl (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedProviderContactD etails | ProposedProviderContactDetails (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProviderID | ReceivedProviderID (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProviderName | ReceivedProviderName (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProviderContactD etails | ReceivedProviderContactDetails (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProviderI D | ReceivedProposedProviderID (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProvider Name | ReceivedProposedProviderName (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProvider ChangeDate | ReceivedProposedProviderChangeDate/Time (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProvider ChangeControl | ReceivedProposedProviderChangeControl (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ReceivedProposedProvider ContactDetails | ReceivedProposedProviderContactDetails (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ChangeofTenancyUpdateD ate | ChangeofTenancyUpdateDate/Time (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_ProposedTenancyChangeC ontrol | ProposedTenancyChangeControl (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_WANStatus | WAN Status (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_LowMediumThreshold | LowMediumThreshold (Optional) |
| ZCL_DEVICE_MGMT_SVR_ATTR_MediumHighThreshold | MediumHighThreshold (Optional) |
Structures
Device Management Client callbacks configuration
Parameters
| publish_change_tenancy
(callback function pointer) |
enum ZclStatusCodeT (*publish_change_tenancy)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtPublishChangeTenancyT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Publish Change Tenancy' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| publish_change_supplier
enum ZclStatusCodeT (*publish_change_supplier)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtPublishChangeSupplierT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Publish Change Supplier' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| req_new_pass_rsp_unsolic
enum ZclStatusCodeT (*req_new_pass_rsp_unsolic)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtReqNewPassRspT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of an unsolicited 'Request New Password Response' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| update_site_id
enum ZclStatusCodeT (*update_site_id)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtUpdateSiteIdT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Update SiteID' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| set_event_config
enum ZclStatusCodeT (*set_event_config)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtSetEventConfigT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Set Event Configuration' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| get_event_config
enum ZclStatusCodeT (*get_event_config)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtGetEventConfigT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Get Event Configuration' command. The return code (e.g. ZCL_STATUS_SUCCESS) is included in the standard Default Response. |
| update_cin
enum ZclStatusCodeT (*update_cin)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtUpdateCinT *info, struct ZbZclAddrInfoT *srcInfo)
ZbZclDeviceMgmtEventConfigPayloadT
Event Configuration Payload structure
Parameters
| uint16_t event_id | Event ID |
| uint8_t event_config | Event Configuration |
Parameters
| bool to_bomd | If true, the timeout for this command is extended since it’s being sent to a BOMD via a Mirror device. |
Parameters
| uint32_t curr_provider_id | Current Provider ID |
| uint32_t issuer_event_id | Issuer Event ID |
| uint8_t tariff_type | Tariff Type |
| uint32_t proposed_provider_id | Proposed Provider ID |
| uint32_t provider_change_impl_time | Provider Change Implementation Time |
| uint32_t provider_change_ctrl | Provider Change Control |
| uint8_t proposed_provider_name | Proposed Provider Name |
| uint8_t proposed_provider_contact | Proposed Provider Contact Details |
Parameters
| uint32_t provider_id | Provider ID |
| uint32_t issuer_id | Issuer Event ID |
| uint32_t implement_time | Implementation Date/Time |
| uint32_t prop_tenancy_change_ctrl | Proposed Tenancy Change Control |
Parameters
| uint8_t command_index | Command Index |
| uint8_t total_commands | Total Commands |
| struct ZbZclDeviceMgmtEventConfigPayloadT event_config_payload | Event Configuration Payload |
| uint8_t num_entries | Number of Payload Entries |
Parameters
| uint16_t duration | Duration |
| uint8_t password_type | Password Type |
| uint8_t password | Password |
Parameters
Device Management Server callbacks configuration
Parameters
| get_change_tenancy
enum ZclStatusCodeT (*get_change_tenancy)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Get Change of Tenancy' command. The ESI may send a PublishChangeofTenancy command (ZbZclDeviceMgmtServerPublishChangeTenancy). Return ZCL_STATUS_SUCCESS if PublishChangeofTenancy was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
| get_change_supplier
enum ZclStatusCodeT (*get_change_supplier)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Get Change of Supplier' command. The ESI may send a PublishChangeofSupplier command (ZbZclDeviceMgmtServerPublishChangeSupplier). Return ZCL_STATUS_SUCCESS if PublishChangeofSupplier was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
| request_new_pass
enum ZclStatusCodeT (*request_new_pass)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclDeviceMgmtReqNewPassT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'Request New Password' command. The ESI may send a RequestNewPasswordResponse command (ZbZclDeviceMgmtServerReqNewPassRsp). Return ZCL_STATUS_SUCCESS if RequestNewPasswordResponse was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
| get_site_id
enum ZclStatusCodeT (*get_site_id)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'GetSiteID' command. The ESI may send a UpdateSiteID command (ZbZclDeviceMgmtServerUpdateSiteId). Return ZCL_STATUS_SUCCESS if UpdateSiteID was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
| get_cin
enum ZclStatusCodeT (*get_cin)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of 'GetCIN' command. The ESI may send a UpdateCIN command (ZbZclDeviceMgmtServerUpdateCin). Return ZCL_STATUS_SUCCESS if UpdateCIN was sent, or ZCL_STATUS_NOT_FOUND otherwise. |
Set Event command structure
Parameters
| uint32_t start_time | Start Date/Time |
| enum ZbZclDeviceMgmtEventConfigCtrl
config_ctrl |
Configuration Control |
| union { struct { uint8_t num_events | Number of Events |
| uint16_t event_id_list | Event IDs |
| struct { uint16_t group_id | Event Group ID |
| struct { uint8_t log_id | Log ID |
| struct { uint8_t config_match | Configuration Value Match |
Update CIN Configuration command structure
Parameters
| uint32_t cin_implement_time | CIN Implementation Time |
| uint8_t customer_id | CustomerID Number |
Parameters
| uint32_t site_id_time | SiteID Time |
| uint8_t site_id | Site ID |
2. Demand Response and Load Control
#include "zcl/se/zcl.drlc.h"
Functions
ZbZclDrlcClientAlloc
struct ZbZclClusterT * ZbZclDrlcClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *time_server, struct ZbZclDrlcClientCallbacksT *callbacks, void *cb_arg);
Create a new instance of the DRLC Client cluster
Parameters
| time_server | Time server cluster instance used to retrieve timing information of events |
| callbacks | Structure containing any callback function pointers for this cluster |
| cb_arg | Pointer to application data that will included in the callback when invoked. |
Return
ZbZclDrlcClientCommandGetEventsReq
enum ZclStatusCodeT ZbZclDrlcClientCommandGetEventsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDrlcGetEventsReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Get Scheduled Events
Parameters
| cmd_req | Get Scheduled Events command request structure |
Return
ZbZclDrlcClientCommandReportStatusReq
enum ZclStatusCodeT ZbZclDrlcClientCommandReportStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclDrlcStatusT *statusPtr, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Report Event Status Command
Parameters
| statusPtr | Report Event Status command request structure |
Return
ZbZclDrlcClientGetEventList
unsigned int ZbZclDrlcClientGetEventList(struct ZbZclClusterT *cluster, struct ZbZclDrlcEventT *eventList, unsigned int maxEntries);
Send a Get Event List command
Parameters
| eventList | Holds a pointer to the event list if successful |
| maxEntries | Max event list entries |
Return
- Event list size if successful, or 0 on error
ZbZclDrlcClientOptOutAdd
enum ZclStatusCodeT ZbZclDrlcClientOptOutAdd(struct ZbZclClusterT *cluster, uint32_t issuer_id);
Append an Issuer Event ID to "opt-out" of
Parameters
| eventList | Holds a pointer to the opt-outs list if successful |
Return
ZbZclDrlcClientOptOutClear
enum ZclStatusCodeT ZbZclDrlcClientOptOutClear(struct ZbZclClusterT *cluster);
Clear all Issuer Event IDs in list to "opt-out" of
Parameters
Return
ZbZclDrlcClientOptOutDel
enum ZclStatusCodeT ZbZclDrlcClientOptOutDel(struct ZbZclClusterT *cluster, uint32_t issuer_id);
Invalidate an Issuer Event ID to "opt-out" of
Parameters
Return
ZbZclDrlcServerAlloc
struct ZbZclClusterT * ZbZclDrlcServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclDrlcServerCallbacksT *callbacks, void *arg);
Create a new instance of the DRLC Server cluster
Parameters
Return
ZbZclDrlcServerCommandCancelAllReq
enum ZclStatusCodeT ZbZclDrlcServerCommandCancelAllReq(struct ZbZclClusterT *cluster, uint8_t ctrl, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Cancel All Load Control Event command
Parameters
| ctrl | Cancel control bitmap, used to determine method of cancellation - e.g. ZCL_DRLC_CANCEL_CONTROL_GRACEFUL |
Return
ZbZclDrlcServerCommandCancelReq
enum ZclStatusCodeT ZbZclDrlcServerCommandCancelReq(struct ZbZclClusterT *cluster, struct ZbZclDrlcCancelT *cancelInfoPtr, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Cancel Load Control Event command
Parameters
| eventPtr | Cancel Load Control Event command request structure |
Return
ZbZclDrlcServerCommandEventReq
enum ZclStatusCodeT ZbZclDrlcServerCommandEventReq(struct ZbZclClusterT *cluster, struct ZbZclDrlcEventT *eventPtr, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Load Control Event command
Parameters
| eventPtr | Load Control Event command request structure |
Return
Enumerations
ZbZclDrlcCliAttrT
DRLC Client Attribute IDs
| ZCL_DRLC_CLI_ATTR_UTILITY_ENROL_GRP | UtilityEnrollmentGroup |
| ZCL_DRLC_CLI_ATTR_START_RAND_MINS | StartRandomizationMinutes |
| ZCL_DRLC_CLI_ATTR_DURATION_RAND_MINS | DurationRandomizationMinutes |
| ZCL_DRLC_CLI_ATTR_DEVICE_CLASS | DeviceClassValue |
Structures
ZbZclDrlcCancelT
Cancel Load Control Event command structure
Parameters
| uint16_t device_class | Device Class |
| uint8_t util_enrol_group | Utility Enrollment Group |
| uint8_t cancel_control | Cancel Control - e.g. ZCL_DRLC_CANCEL_CONTROL_GRACEFUL |
DRLC Client callbacks configuration
Parameters
| start
bool (*start)(void *arg, struct ZbZclDrlcEventT *event)
Callback to application, invoked on the start of an event |
| stop
void (*stop)(void *arg, struct ZbZclDrlcEventT *event)
Callback to application, invoked on the end of an event |
ZbZclDrlcEventT
Parameters
| uint8_t util_enrol_group | Utility Entrollment Group |
| uint32_t start_time | Start Time - UTC, or 0 = now |
| uint16_t duration | Duration in Minutes |
| enum ZbZclDrlcCriticalityLevelT criticality | Criticality Level |
| uint8_t cool_offset | Cooling Temperature Offset (Optional) |
| uint8_t heat_offset | Heating Temperature Offset (Optional) |
| int16_t cool_setpoint | Cooling Temperature Set Point (Optional) |
| int16_t heat_setpoint | Heating Temperature Set Point (Optional) |
| int8_t avg_load_adj | Average Load Adjustment Percentage (Optional) |
| uint8_t dutycycle | Duty Cycle (Optional) |
| uint8_t event_control | Event Control - e.g. ZCL_DRLC_EVENT_CTRL_RAND_START |
Get Scheduled Events command structure
Parameters
| uint32_t earliest_end_time | Earliest End Time |
DRLC Server callbacks configuration
Parameters
| report_status
void (*report_status)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, struct ZbZclDrlcStatusT *status, void *arg)
Callback to application, invoked on receipt of Report Event Status command |
| get_events
enum ZclStatusCodeT (*get_events)(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *srcInfo, struct ZbZclDrlcGetEventsReqT *req, void *arg)
Callback to application, invoked on receipt of Get Scheduled Events command. The get_events callback handler in the application should return ZCL_STATUS_SUCCESS, or ZCL_STATUS_NOT_FOUND if no events are found.Events are re-issued by calling ZbZclDrlcServerCommandEventReq() |
ZbZclDrlcStatusT
Report Event Status command structure
Parameters
| enum ZbZclDrlcEventStatusT status | Event Status |
| uint32_t status_time | Event Status Time |
crit_level_applied |
Criticality Level Applied |
| uint16_t cool_setpoint_applied | Cooling Temperature Set Point Applied (Optional). Set to ZCL_DRLC_COOL_SETPOINT_IGNORED if not used |
| uint16_t heat_setpoint_applied | Heating Temperature Set Point Applied (Optional). Set to ZCL_DRLC_HEAT_SETPOINT_IGNORED if not used |
| int8_t avg_load_adj_applied | Average Load Adjustment Percentage Applied (Optional). Set to ZCL_DRLC_AVG_LOAD_ADJ_IGNORED if not used |
| uint8_t dutycycle_applied | Duty Cycle Applied (Optional). Set to ZCL_DRLC_DUTYCYCLE_IGNORED if not used |
| uint8_t event_control | Event Control |
| enum ZbZclDrlcSignatureT sig_type | Signature Type |
| uint8_t sig_data | Signature (Optional) |
3. Energy Management
#include "zcl/se/zcl.energy_mgmt.h"
Functions
ZbZclEnergyMgmtClientAlloc
struct ZbZclClusterT * ZbZclEnergyMgmtClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Energy Management Client cluster
Parameters
Return
ZbZclEnergyMgmtClientManageEventReq
enum ZclStatusCodeT ZbZclEnergyMgmtClientManageEventReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclEnergyMgmtManageEventT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Manage Event command
Parameters
| info | Manage Event command request structure |
Return
ZbZclEnergyMgmtServerAlloc
struct ZbZclClusterT * ZbZclEnergyMgmtServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclEnergyMgmtServerCallbacksT *callbacks, void *arg);
Create a new instance of the Energy Management Server cluster
Parameters
Return
ZbZclEnergyMgmtServerReportEvtStatus
enum ZclStatusCodeT ZbZclEnergyMgmtServerReportEvtStatus(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclDrlcStatusT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Parameters
| cluster | |
| dst | |
| info | |
| callback | |
| arg |
Return
- Undocumented
Enumerations
ZbZclEnergyMgmtSvrAttrT
Energy Management Server Attribute IDs
| ZCL_ENERGY_MGMT_SVR_ATTR_LOAD_CONTROL_STATE | LoadControlState |
| ZCL_ENERGY_MGMT_SVR_ATTR_CURR_EVENT_ID | CurrentEventID |
| ZCL_ENERGY_MGMT_SVR_ATTR_CURR_EVENT_STATUS | CurrentEventStatus |
| ZCL_ENERGY_MGMT_SVR_ATTR_CONFORMANCE_LEVEL | ConformanceLevel |
| ZCL_ENERGY_MGMT_SVR_ATTR_MIN_OFF_TIME | MinimumOffTime |
| ZCL_ENERGY_MGMT_SVR_ATTR_MIN_ON_TIME | MinimumOnTime |
| ZCL_ENERGY_MGMT_SVR_ATTR_MIN_CYCLE_PERIOD | MinimumCyclePeriod |
Structures
Manage Event (ZCL_ENERGY_MGMT_CLI_CMD_MANAGE_EVENT) command structure
Parameters
| uint8_t utility_enrol_group | Utility Enrollment Group |
| uint8_t actions_required | Action(s) Required |
Energy Management Server callbacks configuration
Parameters
| manage_event
enum ZclStatusCodeT (*manage_event)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEnergyMgmtManageEventT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Manage Event command |
4. Events
#include "zcl/se/zcl.events.h"
Functions
ZbZclEventsClientAlloc
struct ZbZclClusterT * ZbZclEventsClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclEventsClientCallbacksT *callbacks, void *arg);
Create a new instance of the Events Client cluster
Parameters
Return
ZbZclEventsClientCommandClearEventLogReq
enum ZclStatusCodeT ZbZclEventsClientCommandClearEventLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclEventsClientClearEventLogT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Clear Event Log command
Parameters
| dst | Destination address for command |
| cmd_req | Clear Event Log command structure |
Return
ZbZclEventsClientCommandGetEventLogReq
enum ZclStatusCodeT ZbZclEventsClientCommandGetEventLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclEventsClientGetEventLogT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Event Log command
Parameters
| cmd_req | Get Event Log command structure |
Return
ZbZclEventsMirrorAlloc
struct ZbZclClusterT * ZbZclEventsMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *events_client, struct ZbZclClusterT *meter_mirror);
Allocates a Events Server Mirror cluster. The caller (application) must attach any attributes to the cluster you want to mirror.
Parameters
| events_client | Pointer to Events Client cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
Return
ZbZclEventsServerAlloc
struct ZbZclClusterT * ZbZclEventsServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclEventsServerCallbacksT *callbacks, void *arg);
Create a new instance of the Events Server cluster
Parameters
Return
ZbZclEventsServerClearEventLogRsp
enum ZclStatusCodeT ZbZclEventsServerClearEventLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclEventsServerClearEventLogResponseT *rsp);
Send a Clear Event Log Response command
Parameters
| rsp | Clear Event Log Response command structure |
Return
ZbZclEventsServerPublishEventUnsolic
enum ZclStatusCodeT ZbZclEventsServerPublishEventUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclEventsServerPublishEventT *event, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Publish Event command
Parameters
| event | Publish Event command structure |
| callback | Callback function that will be invoked when response is received, if one is expected. If broadcasting, then this should be set to NULL since no response is expected |
| arg | Pointer to application data that will later be provided back to the callback function when invoked |
Return
Structures
Events Client callbacks configuration
Parameters
| publish_event
enum ZclStatusCodeT (*publish_event)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEventsServerPublishEventT *event, const struct ZbApsAddrT *src)
Callback to application, invoked on receipt of Publish Event command. |
| publish_event_log
enum ZclStatusCodeT (*publish_event_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEventsServerPublishEventLogT *event_log, const struct ZbApsAddrT *src)
Callback to application, invoked on receipt of Publish Event Log command. |
Parameters
| bool to_bomd | If true, the timeout for this command is extended since it’s being sent to a BOMD. |
Parameters
| uint8_t event_ctrl_log_id | Event Control/Log ID. Event Control is high nibble. Log ID is low nibble. |
| uint32_t start_time | Start Time - UTC Time |
| uint32_t end_time | End Time - UTC Time |
| uint8_t number_of_events | Number of Events |
| uint16_t event_offset | Event Offset |
Events Server callbacks configuration
Parameters
| get_event_log
enum ZclStatusCodeT (*get_event_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEventsClientGetEventLogT *get_log, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Event Log command. Application should call ZbZclEventsServerPublishEventLogRsp for any matching event log, or return ZCL_STATUS_NOT_FOUND otherwise to return a Default Response. |
| clear_event_log
enum ZclStatusCodeT (*clear_event_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclEventsClientClearEventLogT *clear_log, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Clear Event Log Request command. Application calls ZbZclEventsServerClearEventLogRsp to send the response. Application should always return ZCL_STATUS_SUCCESS. |
Parameters
| uint8_t cleared_events_logs | ClearedEventsLogs |
ZbZclEventsServerEventLogPayloadT
Publish Event Log Payload structure
Parameters
| uint8_t control | Log Payload Control |
event_list |
Publish Event Response Payload |
Publish Event Log command structure
Parameters
| uint16_t total_matching_events | Total Number of Matching Events |
| struct ZbZclEventsServerEventLogPayloadT log_payload | Log Payload |
Parameters
| uint32_t event_time | Event Time - UTC time |
| uint8_t *event_data | Event Data - max length = ZCL_EVENTS_SVR_EVENT_DATA_MAX_LEN |
| uint8_t event_data_len | Event Data length |
5. Messaging
#include "zcl/se/zcl.message.h"
Functions
ZbZclMessageClientParseDisplayMsg
enum ZclStatusCodeT ZbZclMessageClientParseDisplayMsg(struct ZbZclMsgMessageT *msg, uint8_t *payload, unsigned int len);
Parses a ZCL_MESSAGE_SVR_CMD_DISPLAY_MESSAGE paylaod into a 'struct ZbZclMsgMessageT'.
Parameters
| msg | Structure to parse message into |
| payload | ZCL payload of ZCL_MESSAGE_SVR_CMD_DISPLAY_MESSAGE packet |
| len | Length of payload |
Return
ZbZclMsgClientAlloc
struct ZbZclClusterT * ZbZclMsgClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclMsgClientCallbacksT *callbacks, void *arg);
Create a new instance of the Messaging Client cluster
Parameters
Return
ZbZclMsgClientConfEnhReq
enum ZclStatusCodeT ZbZclMsgClientConfEnhReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgConfirmEnhT *msg_conf_enh, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Enhanced Message Confirmation command
Parameters
| msg_conf_enh | Enhanced Message Confirmation command request structure |
Return
ZbZclMsgClientConfReq
enum ZclStatusCodeT ZbZclMsgClientConfReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgConfirmT *msg_conf, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Message Confirmation command
Parameters
| msg_conf | Message Confirmation command request structure |
Return
ZbZclMsgClientGetLastReq
enum ZclStatusCodeT ZbZclMsgClientGetLastReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Last Message command
Parameters
Return
ZbZclMsgClientGetMsgCancelReq
enum ZclStatusCodeT ZbZclMsgClientGetMsgCancelReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, uint32_t earliestTime, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Message Cancellation command
Parameters
| earliestTime | UTC Timestamp indicating the earliest implementation time of a Cancel All Messages command to be returned |
Return
ZbZclMsgMirrorAlloc
struct ZbZclClusterT * ZbZclMsgMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *msg_server, struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *meter_client);
Allocates a Messaging Client Mirror cluster.
Parameters
| msg_server | Pointer to Messaging Server cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
| meter_client | Pointer to Metering Client cluster. This is used to know the existing notification scheme setup between BOMD & ESI and to determine if the command needs to be queued or only the notification flag needs to be set. |
Return
ZbZclMsgServerAlloc
struct ZbZclClusterT * ZbZclMsgServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclMsgServerCallbacksT *callbacks, void *arg);
Create a new instance of the Messaging Server cluster
Parameters
Return
ZbZclMsgServerCancelAllRsp
enum ZclStatusCodeT ZbZclMsgServerCancelAllRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMsgMessageCancelAllT *cancel_all);
Send a Cancel All Messages command as a response
Parameters
| dstInfo | Destination address for response |
| cancel_all | Cancel All Messages command structure |
Return
ZbZclMsgServerCancelAllUnsolic
enum ZclStatusCodeT ZbZclMsgServerCancelAllUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgMessageCancelAllT *cancel_all, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Unsolicited Cancel All Messages command
Parameters
| cancel_all | Cancel All Messages command request structure |
Return
ZbZclMsgServerCancelMessageReq
enum ZclStatusCodeT ZbZclMsgServerCancelMessageReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgMessageCancelT *cancel, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Cancel Message command
Parameters
| cancel | Cancel Message command request structure |
Return
ZbZclMsgServerDisplayMessageRsp
enum ZclStatusCodeT ZbZclMsgServerDisplayMessageRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMsgMessageT *msg);
Send a Display or Display Protected Message as response
Parameters
| dstInfo | Destination address for command, including sequence number and tx options |
| msg | Display Message command structure |
Return
ZbZclMsgServerDisplayMessageUnsolic
enum ZclStatusCodeT ZbZclMsgServerDisplayMessageUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMsgMessageT *msg, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Display or Display Protected Message command
Parameters
| msg | Display Message command request structure |
Return
Structures
Messaging Client callbacks configuration
Parameters
| display_message
enum ZclStatusCodeT (*display_message)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageT *msg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Display Message command |
| cancel_message
enum ZclStatusCodeT (*cancel_message)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageCancelT *cancel, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Cancel Message command |
| cancel_all_messages
enum ZclStatusCodeT (*cancel_all_messages)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageCancelAllT *cancel_all, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Cancel All Messages command |
| display_protected_message
enum ZclStatusCodeT (*display_protected_message)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageT *msg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Display Protected Message command |
ZbZclMsgConfirmEnhT
Enhanced Message Confirmation command structure
Parameters
| uint32_t message_id | Message ID |
| uint32_t confirm_time | Confirmation Time |
| uint8_t confirm_control | Message Confirmation Control |
| char confirm_response | Message Confirmation Response |
ZbZclMsgConfirmT
Parameters
ZbZclMsgGetMsgCancellationT
Get Messsage Cancellation command structure
Parameters
| uint32_t earliest_impl_time | Earliest Implementation Time |
Parameters
| uint32_t implementation_time | Implementation Date/Time |
Cancel Message command structure
Parameters
| uint8_t control | Message Control |
ZbZclMsgMessageConfT
Message Confirmation callback structure
Parameters
| bool has_confirm_control | Has Message Confirmation Control |
| bool has_confirm_response | Has Message Confirmation Response |
| uint8_t confirm_response | Message Confirmation Response |
ZbZclMsgMessageT
Display Message/Display Protected Message command structure
Parameters
| uint32_t start_time | Start Time - UTC Seconds |
| uint16_t duration | Duration In Minutes |
| uint8_t message_control | Message Control |
| uint8_t message_len | Message Length |
| uint8_t *message_str | Message - UTF-8 |
| uint8_t extended_control | Extended Message Control |
| bool protected_msg | If true, indicates display message is protected. |
Messaging Server callbacks configuration
Parameters
| get_last_message
enum ZclStatusCodeT (*get_last_message)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Last Message command |
| message_confirmation
enum ZclStatusCodeT (*message_confirmation)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgMessageConfT *conf, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Message Confirmation command |
| get_message_cancellation
enum ZclStatusCodeT (*get_message_cancellation)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclMsgGetMsgCancellationT *req, struct ZbZclAddrInfoT *source)
Callback to application, invoked on receipt of Get Message Cancellation command |
6. Metering
#include "zcl/se/zcl.meter.h"
Functions
ZbZclMeterClientAlloc
struct ZbZclClusterT * ZbZclMeterClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclMeterClientCallbacksT *callbacks, void *arg);
Create a new instance of the Metering Client cluster
Parameters
Return
ZbZclMeterClientAttachMirror
bool ZbZclMeterClientAttachMirror(struct ZbZclClusterT *cluster, struct ZbZclClusterT mirror_server, uint64_t rmt_addr, uint8_t rmt_endpoint);
Attach the Meter Mirror Server to the Meter Client. Configures the Client to manage the Mirror Server, and handle reports from the remote Meter and update the Mirror Server attributes.
Parameters
| cluster | EXEGIN |
| mirror_server | Pointer to the Mirror Server cluster. |
| rmt_addr | EUI64 address of the remote Meter Server. |
| rmt_endpoint | Endpoint on the remote Meter Server. |
Return
- True if the Mirror Server could be attached, false otherwise.
ZbZclMeterClientClearNotifFlag
bool ZbZclMeterClientClearNotifFlag(struct ZbZclClusterT *cluster, uint16_t attr_id, uint32_t notif_flag);
Clear the Metering Client notification flag(s).
Parameters
| cluster | Metering client cluster instance. |
| attr_id | Notification flag attribute id. |
| notif_flag | Notification flag(s) to be cleared. |
Return
- True if notification flag is cleared successfully, false otherwise.
ZbZclMeterClientCommandChangeSupplyReq
enum ZclStatusCodeT ZbZclMeterClientCommandChangeSupplyReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientChangeSupplyReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Change Supply Command
Parameters
| cmd_req | Change Supply payload information structure. |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error. The callback will only be called if this function returns SUCCESS.
ZbZclMeterClientCommandFastPollReq
enum ZclStatusCodeT ZbZclMeterClientCommandFastPollReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientFastPollModeReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request Fast Poll Mode command
Parameters
| cmd_req | Request Fast Poll Mode command structure |
Return
ZbZclMeterClientCommandGetProfileReq
enum ZclStatusCodeT ZbZclMeterClientCommandGetProfileReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientGetProfileReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Profile command
Parameters
| cmd_req | Get Profile command structure |
Return
ZbZclMeterClientCommandGetSampledDataReq
enum ZclStatusCodeT ZbZclMeterClientCommandGetSampledDataReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientGetSampledDataReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Sampled Data command
Parameters
| cmd_req | Get Sampled Data command structure |
Return
ZbZclMeterClientCommandGetSnapshotReq
enum ZclStatusCodeT ZbZclMeterClientCommandGetSnapshotReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientGetSnapshotReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Snapshot command
Parameters
| cmd_req | Get Snapshot command structure |
Return
ZbZclMeterClientCommandLocalChangeSupplyReq
enum ZclStatusCodeT ZbZclMeterClientCommandLocalChangeSupplyReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientLocalChangeSupplyReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Local Change Supply command
Parameters
Return
ZbZclMeterClientCommandResetLoadLimitCounterReq
enum ZclStatusCodeT ZbZclMeterClientCommandResetLoadLimitCounterReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientResetLoadLimitCounterReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send Reset Load Limit Counter command
Parameters
| cmd_req | Reset Load Limit Counter command structure |
Return
ZbZclMeterClientCommandScheduleSnapshotReq
enum ZclStatusCodeT ZbZclMeterClientCommandScheduleSnapshotReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientScheduleSnapshotReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Schedule Snapshot Request command
Parameters
| cmd_req | Schedule Snapshot Request command structure |
Return
ZbZclMeterClientCommandSetSupplyStatusReq
enum ZclStatusCodeT ZbZclMeterClientCommandSetSupplyStatusReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientSetSupplyStatusReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Supply Status command
Parameters
| cmd_req | Set Supply Status command structure |
Return
ZbZclMeterClientCommandSetUnctrlFlowThreshReq
enum ZclStatusCodeT ZbZclMeterClientCommandSetUnctrlFlowThreshReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientSetUnctrlFlowThreshReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Uncontrolled Flow Threshold command
Parameters
| cluster | Cluster instance from which to send this command |
| dst | Destination address for request |
| cmd_req | Set Uncontrolled Flow Threshold command structure |
| callback | Callback function that will be invoked when the response is received. |
Return
ZbZclMeterClientCommandStartSamplingReq
enum ZclStatusCodeT ZbZclMeterClientCommandStartSamplingReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientStartSamplingReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Start Sampling command
Parameters
| cmd_req | Start Sampling command structure |
Return
ZbZclMeterClientCommandTakeSnapshotReq
enum ZclStatusCodeT ZbZclMeterClientCommandTakeSnapshotReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterClientTakeSnapshotReqT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Take Snapshot command
Parameters
| cmd_req | Take Snapshot command structure |
Return
ZbZclMeterClientSetNotifFlag
bool ZbZclMeterClientSetNotifFlag(struct ZbZclClusterT *cluster, uint16_t attr_id, uint32_t notif_flag);
Set the Metering Client notification flag(s).
Parameters
| notif_flag | Notification(s) flag to be set. |
Return
- True if notification flag is set successfully, false otherwise.
ZbZclMeterFormSampledData
int ZbZclMeterFormSampledData(uint8_t *sample_data, unsigned int max_len, uint32_t *samples, uint16_t num_samples);
Convert an array of 24-bit integers to the Zigbee frame format
Parameters
| sample_data | Converted data for Zigbee frame |
| max_len | Maximum length |
| samples | Array of 24-bit integers to convert |
| num_samples | Number of integers to convert |
Return
- Returns the number of octets written to sample_data or -1 on error
ZbZclMeterGetProfileIntervalPeriod
int ZbZclMeterGetProfileIntervalPeriod(uint8_t profile_interval_id);
Convert the profile interval period enumerated value to a time in seconds
Parameters
| profile_interval_id | Zigbee stack instance |
Return
- Converted time in seconds or -1 on error
ZbZclMeterMirrorAlloc
struct ZbZclClusterT * ZbZclMeterMirrorAlloc(struct ZigBeeT *zb, struct ZbZclClusterT *client, uint8_t endpoint, uint64_t meter_extaddr, uint8_t meter_endpoint);
Allocate a Meter Server used for Mirroring.
Parameters
| zb | |
| client | Meter Client being used to manage this Mirror Server |
| endpoint | |
| meter_extaddr | The EUI64 of the remote Meter Server |
| meter_endpoint | The endpoint on the remote Meter Server |
Return
- Undocumented
ZbZclMeterMirrorBomdReadReq
enum ZclStatusCodeT ZbZclMeterMirrorBomdReadReq(struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *client, struct ZbZclReadReqT *req, void (*callback)(const struct ZbZclReadRspT *readRsp, void *cb_arg), void *arg);
Sends a One-Way Mirror ZCL Read Request to the BOMD. The request is queued until the BOMD wakes up. The ZCL_METER_FUNC_NOTIF_FLAG_STAY_AWAKE_HAN notification flag is set so the BOMD knows to keep polling for data after waking up. The Metering Mirror Cluster must already be allocated.
Parameters
| meter_mirror | Metering Mirror cluster |
| client | Client cluster originating this request |
| req | ZCL Read Request struct |
Return
ZbZclMeterMirrorBomdWriteReq
enum ZclStatusCodeT ZbZclMeterMirrorBomdWriteReq(struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *client, struct ZbZclWriteReqT *req, void (*callback)(const struct ZbZclWriteRspT *writeRsp, void *cb_arg), void *arg);
Sends a One-Way Mirror ZCL Write Request to the BOMD. The request is queued until the BOMD wakes up. The ZCL_METER_FUNC_NOTIF_FLAG_STAY_AWAKE_HAN notification flag is set so the BOMD knows to keep polling for data after waking up. The Metering Mirror Cluster must already be allocated.
Parameters
| req | ZCL Write Request struct |
Return
ZbZclMeterServerAlloc
struct ZbZclClusterT * ZbZclMeterServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclMeterServerCallbacksT *callbacks, void *arg);
Create a new instance of the Metering Server cluster
Parameters
| zb | Zigbee stack instance |
| endpoint | Endpoint on which to create cluster |
| arg | Pointer to application data that will included in the callbacks when invoked. |
Return
- Cluster pointer, or NULL if there is an error
ZbZclMeterServerPublishSnapshotRsp
enum ZclStatusCodeT ZbZclMeterServerPublishSnapshotRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMeterServerPublishSnapshotT *rsp);
Send a Publish Snapshot Response command
Parameters
| dstInfo | Destination address for response, including sequence number and tx options |
| rsp | Publish Snapshot Response command structure |
Return
ZbZclMeterServerPublishSnapshotUnsolic
enum ZclStatusCodeT ZbZclMeterServerPublishSnapshotUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclMeterServerPublishSnapshotT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an Unsolicited Publish Snapshot command
Parameters
| dst | Destination of command. |
| req | Publish Snapshot command structure. |
Return
ZbZclMeterServerSendConfigMirror
enum ZclStatusCodeT ZbZclMeterServerSendConfigMirror(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclMeterServerConfigMirrorT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a ConfigureMirror Command (ZCL_METER_SVR_CMD_CONFIGURE_MIRROR)
Parameters
| dst | Destination of command. Should be the Coordinator / TC / Comms Hub in this case. |
| req | ConfigureMirror parameters |
Return
ZbZclMeterServerSendConfigNotifFlags
enum ZclStatusCodeT ZbZclMeterServerSendConfigNotifFlags(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclMeterServerConfigNotifFlagsT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Configure Notification Flags Command (ZCL_METER_SVR_CMD_CONFIGURE_NOTIFICATION_FLAG) "Where ‘Two Way Mirroring’ is being implemented, and a non-default Notification Scheme is to be used, the ConfigureNotificationFlags command allows a BOMD to set the commands relating to the bit value for each NotificationFlags#N attribute that the scheme is proposing to use. This command should be used in conjunction with the associated ConfigureNotificationScheme command."
Parameters
| req | Configure Notification Flags payload information structure. |
Return
ZbZclMeterServerSendConfigNotifScheme
enum ZclStatusCodeT ZbZclMeterServerSendConfigNotifScheme(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclMeterServerConfigNotifSchemeT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Configure Notification Scheme Command (ZCL_METER_SVR_CMD_CONFIGURE_NOTIFICATION_SCHEME)
Parameters
| req | Configure Notification Scheme payload information structure. |
Return
ZbZclMeterServerSendFastPollModeRsp
enum ZclStatusCodeT ZbZclMeterServerSendFastPollModeRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMeterServerFastPollModeRspT *rsp);
Send a Request Fast Poll Mode Response command
Parameters
| rsp | Request Fast Poll Mode Response command structure |
Return
ZbZclMeterServerSendGetNotifMsg
enum ZclStatusCodeT ZbZclMeterServerSendGetNotifMsg(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclMeterServerGetNotifMsgT *req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Notified Message Command.
Parameters
| dst | Destination address for response, including sequence number and tx options |
| req | Get Notified Message payload information structure. |
Return
ZbZclMeterServerSendGetProfileRsp
enum ZclStatusCodeT ZbZclMeterServerSendGetProfileRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterServerGetProfileRspT *rsp);
Send a Get Profile Response command
Parameters
| rsp | Get Profile Response command structure |
Return
ZbZclMeterServerSendGetSampledDataRsp
enum ZclStatusCodeT ZbZclMeterServerSendGetSampledDataRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterServerGetSampledDataRspT *rsp);
Send a Get Sampled Data Response command
Parameters
| rsp | Get Sampled Data Response command structure |
Return
ZbZclMeterServerSendRemoveMirror
enum ZclStatusCodeT ZbZclMeterServerSendRemoveMirror(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Remove Mirror Command (ZCL_METER_SVR_CMD_REMOVE_MIRROR)
Parameters
Return
ZbZclMeterServerSendRequestMirror
enum ZclStatusCodeT ZbZclMeterServerSendRequestMirror(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Request Mirror Command (ZCL_METER_SVR_CMD_REQUEST_MIRROR)
Parameters
Return
ZbZclMeterServerSendScheduleSnapshotRsp
enum ZclStatusCodeT ZbZclMeterServerSendScheduleSnapshotRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterClientScheduleSnapshotRspT *rsp);
Send a Schedule Snapshot Response command
Parameters
| rsp | Schedule Snapshot Response command structure |
Return
ZbZclMeterServerSendStartSamplingRsp
enum ZclStatusCodeT ZbZclMeterServerSendStartSamplingRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterClientStartSamplingRspT *rsp);
Send a Start Sampling Response command
Parameters
| rsp | Start Sampling Response command structure |
Return
ZbZclMeterServerSendSupplyStatusRsp
enum ZclStatusCodeT ZbZclMeterServerSendSupplyStatusRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclMeterServerSupplyStatusRspT *rsp);
Send a Supply Status Response command
Parameters
| rsp | Supply Status Response command structure |
Return
ZbZclMeterServerSendTakeSnapshotRsp
enum ZclStatusCodeT ZbZclMeterServerSendTakeSnapshotRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclMeterClientTakeSnapshotRspT *rsp);
Send a Take Snapshot Response command
Parameters
| rsp | Take Snapshot Response command structure |
Return
Structures
ZbZclMeterClientMirrorReportAttrRspT
MirrorReportAttributeResponse Command
Parameters
| enum ZbZclMeterNotifSchemesT
notif_scheme |
Notification Scheme |
| uint8_t num_flags | Notification Flags |
7. Prepayment
#include "zcl/se/zcl.prepay.h"
Functions
ZbZclPrepayClientAlloc
struct ZbZclClusterT * ZbZclPrepayClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPrepayClientCallbacksT *callbacks, void *arg);
Create a new instance of the Prepayment Client cluster
Parameters
Return
ZbZclPrepayClientChangeDebtReq
enum ZclStatusCodeT ZbZclPrepayClientChangeDebtReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayChangeDebtReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Change Debt command
Parameters
| info | Change Debt command structure |
| arg | Pointer to application data that will be included in the callback when invoked. |
Return
ZbZclPrepayClientChangePaymentModeReq
enum ZclStatusCodeT ZbZclPrepayClientChangePaymentModeReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayChangePaymentModeReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Change Payment Mode command
Parameters
| info | Change Payment Mode command structure |
Return
ZbZclPrepayClientConsumerTopUpReq
enum ZclStatusCodeT ZbZclPrepayClientConsumerTopUpReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayConsumerTopUpReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Consumer Top Up command
Parameters
| info | Consumer Top Up command structure |
Return
ZbZclPrepayClientCreateMirror
struct ZbZclClusterT * ZbZclPrepayClientCreateMirror(struct ZbZclClusterT *cluster, uint8_t endpoint, struct ZbZclClusterT *meter_mirror_client, struct ZbZclClusterT *meter_mirror_server, uint64_t rmt_addr, uint8_t rmt_endpoint);
Allocates a PrePayment Server Mirror cluster. The caller (application) must attach any attributes to the cluster you want to mirror. By default, stack attaches the mandatory prepayment server attributes.
Parameters
| cluster | Prepayment client cluster instance |
| endpoint | Endpoint on which to create the mirror cluster |
| meter_mirror_client | Metering Mirror Client cluster. This is used to manage the Mirror. |
| meter_mirror_server | Metering Mirror Server cluster. This is used to queue any commands that need to be forwarded to the BOMD when it wakes up. |
| rmt_addr | Extended address of the remote Metering device being mirrored. |
| rmt_endpoint | Endpoint on the remote Metering device being mirrored. |
Return
ZbZclPrepayClientCreditAdjustReq
enum ZclStatusCodeT ZbZclPrepayClientCreditAdjustReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayCreditAdjustReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Credit Adjustment command
Parameters
| info | Credit Adjustment command structure |
Return
ZbZclPrepayClientEmergCreditSetupReq
enum ZclStatusCodeT ZbZclPrepayClientEmergCreditSetupReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayEmergCreditSetupReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Emergency Credit Setup command
Parameters
| info | Emergency Credit Setup command structure |
Return
ZbZclPrepayClientGetDebtRepayLogReq
enum ZclStatusCodeT ZbZclPrepayClientGetDebtRepayLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayGetDebtRepayLogReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Debt Repayment Log command
Parameters
| info | Get Debt Repayment Log command structure |
Return
ZbZclPrepayClientGetPrepaySnapshotReq
enum ZclStatusCodeT ZbZclPrepayClientGetPrepaySnapshotReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayGetPrepaySnapshotReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Prepay Snapshot command
Parameters
| info | Get Prepay Snapshot command structure |
Return
ZbZclPrepayClientGetTopUpLogReq
enum ZclStatusCodeT ZbZclPrepayClientGetTopUpLogReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayGetTopUpLogReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get TopUp Log command
Parameters
| info | Get TopUp Log command structure |
Return
ZbZclPrepayClientSelectAvailEmergCreditReq
enum ZclStatusCodeT ZbZclPrepayClientSelectAvailEmergCreditReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepaySelectAvailEmergCreditReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Select Available Emergency Credit command
Parameters
| info | Select Available Emergency Credit command structure |
Return
ZbZclPrepayClientSetLowCreditWarnLevelReq
enum ZclStatusCodeT ZbZclPrepayClientSetLowCreditWarnLevelReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepaySetLowCreditWarnLevelReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Low Credit Warning Level command
Parameters
| info | Set Low Credit Warning Level command structure |
Return
ZbZclPrepayClientSetMaxCreditLimitReq
enum ZclStatusCodeT ZbZclPrepayClientSetMaxCreditLimitReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepaySetMaxCreditLimitReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Max Credit Limit command
Parameters
| info | Set Max Credit Limit command structure |
Return
ZbZclPrepayClientSetOverallDebtCapReq
enum ZclStatusCodeT ZbZclPrepayClientSetOverallDebtCapReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepaySetOverallDebtCapReqT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Set Overall Debt Cap command
Parameters
| info | Set Overall Debt Cap command structure |
Return
ZbZclPrepayServerAlloc
struct ZbZclClusterT * ZbZclPrepayServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *time_server, struct ZbZclPrepayServerCallbacksT *callbacks, void *arg);
Create a new instance of the Prepayment Server cluster
Parameters
| time_server | Pointer to time server cluster |
Return
ZbZclPrepayServerAttrCreditRemainingWriteCb
enum ZclStatusCodeT ZbZclPrepayServerAttrCreditRemainingWriteCb(struct ZbZclClusterT *cluster, struct ZbZclAttrCbInfoT *info);
Prepayment server default write callback for optional attribute 'Credit Remaining'.
Parameters
| cluster | Cluster instance for Prepayment server. |
| info | Attribute information structure. |
Return
ZbZclPrepayServerChangePaymentModeRsp
enum ZclStatusCodeT ZbZclPrepayServerChangePaymentModeRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPrepayChangePaymentModeRspT *info);
Send a Change Payment Mode response
Parameters
| info | Change Payment Mode Response command structure |
Return
ZbZclPrepayServerConsumerTopUpRsp
enum ZclStatusCodeT ZbZclPrepayServerConsumerTopUpRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPrepayConsumerTopUpRspT *info);
Send a Consumer Top Up response
Parameters
| info | Consumer Top Up Response command structure |
Return
ZbZclPrepayServerPublishDebtLogRsp
enum ZclStatusCodeT ZbZclPrepayServerPublishDebtLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclPrepayPublishDebtLogT *info);
Send a Publish Debt Log Response
Parameters
| info | Publish Debt Log command structure |
Return
ZbZclPrepayServerPublishDebtLogUnsolic
enum ZclStatusCodeT ZbZclPrepayServerPublishDebtLogUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayPublishDebtLogT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Debt Log
Parameters
| dst | Destination address for this unsolicted command. |
| info | Publish Debt Log command structure. |
| callback | Callback function that will be invoked when the Default Response is received, or times-out. |
Return
ZbZclPrepayServerPublishPrepaySnapshotRsp
enum ZclStatusCodeT ZbZclPrepayServerPublishPrepaySnapshotRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclPrepayPublishPrepaySnapshotT *info);
Send a Publish Prepay Snapshot as a response to the GetPrepaySnapshot command.
Parameters
| info | Publish Prepay Snapshot command structure |
Return
ZbZclPrepayServerPublishPrepaySnapshotUnsolic
enum ZclStatusCodeT ZbZclPrepayServerPublishPrepaySnapshotUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayPublishPrepaySnapshotT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Prepay Snapshot as an unsolicited command
Parameters
Return
ZbZclPrepayServerPublishTopUpLogRsp
enum ZclStatusCodeT ZbZclPrepayServerPublishTopUpLogRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dstInfo, struct ZbZclPrepayPublishTopUpLogT *info);
Send a Publish Top Up Log as a response
Parameters
Return
ZbZclPrepayServerPublishTopUpLogUnsolic
enum ZclStatusCodeT ZbZclPrepayServerPublishTopUpLogUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPrepayPublishTopUpLogT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Publish Top Up Log as an unsolicited command
Parameters
| info | Publish Top Up Log command structure |
Return
ZbZclPrepayServerUpdateAlarmStatusFlag
enum ZclStatusCodeT ZbZclPrepayServerUpdateAlarmStatusFlag(struct ZbZclClusterT *cluster, uint16_t flag, bool set);
Set/Clear the alram status flag in 'Alarm Status' attribute.
Parameters
| flag | Alarm status flags e.g, ZCL_PREPAY_ALARM_LOW_CREDIT_WARN |
| set | if true, sets the input flags. Otherwise, clears the flags. |
Return
ZbZclPrepayServerUpdateCreditStatusFlag
enum ZclStatusCodeT ZbZclPrepayServerUpdateCreditStatusFlag(struct ZbZclClusterT *cluster, uint8_t flag, bool set);
Set/Clear the credit status flag in 'Credit Status' attribute.
Parameters
| flag | Credit status flags e.g, ZCL_PREPAY_CREDIT_OK |
Return
zcl_prepay_get_topup_record
bool zcl_prepay_get_topup_record(struct ZbZclClusterT *cluster, struct ZbZclPrepayTopUpPayloadT *payload, uint8_t attr_idx);
Helper function to retrieve the topup record from the topup attribute set pointed by attribute index.
Parameters
| cluster | Cluster instance to get the topup record. |
| payload | Pointer to TopUp record payload. |
| attr_idx | Attribute index to the TopUp attribute set |
Return
- true if the top up record is retrieved successfully, false otherwise.
zcl_prepay_topup_code_duplicate_check
bool zcl_prepay_topup_code_duplicate_check(struct ZbZclClusterT *cluster, const uint8_t *topup_code);
Helper function to check if the topup code received is duplicate or not.
Parameters
| topup_code | Pointer to topup_code received as part of comsumer topup command. |
Return
- true if the received topup code is duplicate, false otherwise.
zcl_prepay_update_topup_attrs
enum ZbZclPrepayTopUpResultT zcl_prepay_update_topup_attrs(struct ZbZclClusterT *cluster, enum ZbZclPrepayOriginDeviceT origin_device, uint8_t *topup_code, int32_t topup_value);
Helper function to update the prepayment server topup attributes on receiving the consumer topup command.
Parameters
| cluster | Cluster instance to check the topup attributes. |
| origin_device | Origin device of the consumer topup command. |
| topup_code | Pointer to topup code received as part of consumer topup command. |
| topup_value | topup amount derived from the topup code. |
Return
- ZCL_PREPAY_TOPUP_RSLT_ACCEPTED if the topup attributes are updated successfully, ZCL_PREPAY_TOPUP_RSLT_RJCTD_MAX_CREDIT if the top amount results in credit remaining value exceeding the maximum credit limit.
Enumerations
ZbZclPreaymentSvrAttrT
Prepayment Server Attribute IDs
| ZCL_PREPAY_SVR_ATTR_PAYMENT_CONTROL_CONFIG | Payment Control Configuration |
| ZCL_PREPAY_SVR_ATTR_CREDIT_REMAINING | Credit Remaining (Optional) |
| ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_REMAINING | Emergency Credit Remaining (Optional) |
| ZCL_PREPAY_SVR_ATTR_CREDIT_STATUS | Credit Status (Optional) |
| ZCL_PREPAY_SVR_ATTR_CREDIT_REMAIN_TIMESTAMP | CreditRemaining TimeStamp (Optional) |
| ZCL_PREPAY_SVR_ATTR_ACCUMULATED_DEBT | Accumulated Debt (Optional) |
| ZCL_PREPAY_SVR_ATTR_OVERALL_DEBT_CAP | OverallDebtCap (Optional) |
| ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_ALLOWANCE | EmergencyCredit Limit/Allowance (Optional) |
| ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_THRESHOLD | EmergencyCredit Threshold (Optional) |
| ZCL_PREPAY_SVR_ATTR_TOTAL_CREDIT_ADDED | TotalCreditAdded (Optional) |
| ZCL_PREPAY_SVR_ATTR_MAX_CRED_LIMIT | MaxCreditLimit (Optional) |
| ZCL_PREPAY_SVR_ATTR_MAX_CRED_PER_TOPUP | MaxCreditPerTopUp (Optional) |
| ZCL_PREPAY_SVR_ATTR_FRIENDLY_CREDIT_WARNING | FriendlyCredit Warning (Optional) |
| ZCL_PREPAY_SVR_ATTR_LOW_CREDIT_WARNING | LowCredit Warning (Optional) |
| ZCL_PREPAY_SVR_ATTR_IHD_LOW_CREDIT_WARNING | IHDLow CreditWarning (Optional) |
| ZCL_PREPAY_SVR_ATTR_INTERRUPT_SUSPEND_TIME | InterruptSuspend Time (Optional) |
| ZCL_PREPAY_SVR_ATTR_REMAINING_FRIENDLY_CREDIT
_TIME |
RemainingFriendlyCreditTime (Optional) |
| ZCL_PREPAY_SVR_ATTR_NEXT_FRIENDLY_CREDIT_TIME | NextFriendly CreditPeriod (Optional) |
| ZCL_PREPAY_SVR_ATTR_CUT_OFF_VALUE | CutOffValue (Optional) |
| ZCL_PREPAY_SVR_ATTR_TOKEN_CARRIER_ID | TokenCarrierID (Optional) |
| ZCL_PREPAY_SVR_ATTR_TOPUP_DATE_TIME_1 | Top up Date/Time #1 (Optional) ZCL_PREPAY_SVR_ATTR_TOPUP_DATE_TIME_N(1) For the
remaining Top up Date/Time attributes, use the ZCL_PREPAY_SVR_ATTR_TOPUP_DATE_TIME_N macro. |
| ZCL_PREPAY_SVR_ATTR_TOPUP_AMOUNT_1 | Top up Amount #1 (Optional) ZCL_PREPAY_SVR_ATTR_TOPUP_AMOUNT_N(1) For the remaining Top up Amount attributes, use the ZCL_PREPAY_SVR_ATTR_TOPUP_AMOUNT_N macro. |
| ZCL_PREPAY_SVR_ATTR_TOPUP_ORIGINATOR | Originating Device #1 (Optional) ZCL_PREPAY_SVR_ATTR_TOPUP_ORIGINATOR_N(1) For the remaining Orginating Device attributes, use the ZCL_PREPAY_SVR_ATTR_TOPUP_ORIGINATOR_N macro. |
| ZCL_PREPAY_SVR_ATTR_TOPUP_CODE | Top up Code #1 (Optional) ZCL_PREPAY_SVR_ATTR_TOPUP_CODE_N(1) For the remaining Top up Code attributes, use the ZCL_PREPAY_SVR_ATTR_TOPUP_CODE_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_LABEL_1 | DebtLabel#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_LABEL_N(1) For the remaining DebtLabel attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_LABEL_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_AMOUNT_1 | DebtAmount#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_AMOUNT_N(1) For the remaining DebtAmount attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_AMOUNT_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_METHOD_1 | DebtRecovery Method#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_METHOD_N(1) For the remaining DebtRecovery Method attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_METHOD_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_START_TIME_1 | DebtRecovery StartTime#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_START_TIME_N(1)
For the remaining DebtRecovery StartTime attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_START_TIME_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_COLLECT_TIME_1 | DebtRecovery CollectionTime#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_COLLECT_TIME_N(1)
For the remaining DebtRecovery CollectionTime attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_COLLECT_TIME_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_FREQ_1 | DebtRecovery Frequency#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_FREQ_N(1) For the
remaining DebtRecovery Frequency attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_FREQ_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_AMOUNT_1 | DebtRecovery Amount#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_AMOUNT_N(1) For
the remaining DebtRecovery Amount attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_AMOUNT_N macro. |
| ZCL_PREPAY_SVR_ATTR_DEBT_REC_TOPUP_PERCENT_1 | DebtRecovery TopUpPercentage#1 (Optional) ZCL_PREPAY_SVR_ATTR_DEBT_REC_TOPUP_PERCENT_
N(1) For the remaining DebtRecovery TopUpPercentage attributes, use the ZCL_PREPAY_SVR_ATTR_DEBT_REC_TOPUP_PERCENT_N macro. |
| ZCL_PREPAY_SVR_ATTR_ALARM_STATUS | PrepaymentAlarmStatus (Optional) |
| ZCL_PREPAY_SVR_ATTR_GENERIC_ALARM_MASK | PrepayGenericAlarmMask (Optional) |
| ZCL_PREPAY_SVR_ATTR_SWITCH_ALARM_MASK | PrepaySwitchAlarmMask (Optional) |
| ZCL_PREPAY_SVR_ATTR_EVENT_ALARM_MASK | PrepayEventAlarmMask (Optional) |
| ZCL_PREPAY_SVR_ATTR_HIST_CCTION_FORMAT | HistoricalCostConsumption Formatting (Optional) |
| ZCL_PREPAY_SVR_ATTR_CONSUMPTION_UNIT_OF_MEAS URE | ConsumptionUnitofMeasurement (Optional) |
| ZCL_PREPAY_SVR_ATTR_CURRENCY_SCALING_FACTOR | CurrencyScalingFactor (Optional) |
| ZCL_PREPAY_SVR_ATTR_CURRENCY | Currency (Optional) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_0 | CurrentDay CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_0 | CurrentDay CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_1 | PreviousDay CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_1 | PreviousDay CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_2 | PreviousDay2 CostConsumptionDelivered (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_N(2) For
the remaining days, use the ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_DAY_N(prev_d ay) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_2 | PreviousDay2 CostConsumptionReceived (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_N(2)
For the remaining days, use the ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_DAY_N(pr ev_day) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_0 | CurrentWeek CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_0 | CurrentWeek CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_N( 0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_1 | PreviousWeek CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_1 | PreviousWeek CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_N( 1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_2 | PreviousWeek2 CostConsumptionDelivered (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_N(2)
For the remaining weeks, use the ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_WEEK_N(prev _week) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_2 | PreviousWeek2 CostConsumptionReceived (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_N(
2) For the remaining weeks, use the ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_WEEK_N( prev_week) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_0 | CurrentMonth CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_0 | CurrentMonth CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_ N(0) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_1 | PreviousMonth CostConsumptionDelivered (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_1 | PreviousMonth CostConsumptionReceived (Optional) - ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_ N(1) |
| ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_2 | PreviousMonth2 CostConsumptionDelivered (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_N(2)
For the remaining months, use the ZCL_PREPAY_SVR_ATTR_COSTCON_DELIV_MONTH_N(pre v_month) macro. |
| ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_2 | PreviousMonth2 CostConsumptionReceived (Optional) ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_
N(2) For the remaining months, use the ZCL_PREPAY_SVR_ATTR_COSTCON_RECEIVED_MONTH_ N(prev_month) macro. |
| ZCL_PREPAY_SVR_ATTR_HIST_FREEZE_TIME | Historical Freeze Time (Optional) |
ZbZclPrepayCreditTypeT
Credit Type Field enumerations
| ZCL_PREPAY_CREDIT_TYPE_INCREMENTAL | Credit Incremental |
| ZCL_PREPAY_CREDIT_TYPE_ABSOLUTE | Credit Absolute |
ZbZclPrepayDebtRecMethodT
Debt Recovery Method enumerations
| ZCL_PREPAY_REC_METHOD_TIME | Time Based |
| ZCL_PREPAY_REC_METHOD_PERCENTAGE | Percentage Based |
| ZCL_PREPAY_REC_METHOD_CATCH_UP | Catch-up Based |
| /**< | 0x03 -0xff Reserved |
ZbZclPrepayDebtTypeT
Debt Type Field enumerations
| ZCL_PREPAY_DEBT_TYPE_1_ABSOLUTE | Debt Type 1 Absolute |
| ZCL_PREPAY_DEBT_TYPE_1_INCREMENTAL | Debt Type 1 Incremental |
| ZCL_PREPAY_DEBT_TYPE_2_ABSOLUTE | Debt Type 2 Absolute |
| ZCL_PREPAY_DEBT_TYPE_2_INCREMENTAL | Debt Type 2 Incremental |
| ZCL_PREPAY_DEBT_TYPE_3_ABSOLUTE | Debt Type 3 Absolute |
| ZCL_PREPAY_DEBT_TYPE_3_INCREMENTAL | Debt Type 3 Incremental |
| /**< | 0x06 - 0xff Reserved. |
Originating Device Field enumerations
| ZCL_PREPAY_ORIGIN_DEVICE_ESI | Energy Service Interface |
| ZCL_PREPAY_ORIGIN_DEVICE_METER | Meter |
| ZCL_PREPAY_ORIGIN_DEVICE_IHD | In-Home Display Device |
ZbZclPrepaySnapshotPayloadTypeT
Prepayment Snapshot Payload type.
| ZCL_PREPAY_SNAPSHOT_PAYLOAD_TYPE_DEBT_STATUS | Debt/Credit Status |
Result Type Field enumerations
| ZCL_PREPAY_TOPUP_RSLT_ACCEPTED | Accepted |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_INVALID | Rejected-Invalid Top Up |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_DUPLICATE | Rejected-Duplicate Top Up |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_ERROR | Rejected-Error |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_MAX_CREDIT | Rejected-Max Credit Reached |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_KEYPAD_LOCK | Rejected-Keypad Lock |
| ZCL_PREPAY_TOPUP_RSLT_RJCTD_TOO_LARGE | Rejected-Top Up Value Too Large |
| ZCL_PREPAY_TOPUP_RSLT_ACCPD_SUPPLY_ENABLED | Accepted – Supply Enabled |
| ZCL_PREPAY_TOPUP_RSLT_ACCPD_SUPPLY_DISABLED | Accepted – Supply Disabled |
| ZCL_PREPAY_TOPUP_RSLT_ACCPD_SUPPLY_ARMED | Accepted – Supply Armed |
Structures
Parameters
| uint32_t issuer_event_id | Issuer Event ID |
| char debt_label | Debt Label, first byte is length. |
| int32_t debt_amount | Debt Amount |
| enum ZbZclPrepayDebtRecMethodT
rec_method |
Debt Recovery Method. |
| enum ZbZclPrepayDebtTypeT debt_type | Debt Amount Type. |
| uint32_t rec_start_time | Debt Recovery Start Time. |
| uint16_t rec_collect_time | Debt Recovery Collection Time. |
| uint8_t rec_freq | Debt Recovery Frequency. |
| int32_t rec_amount | Debt Recovery Amount. |
| uint16_t rec_bal_percent | Debt Recovery Balance Percentage. |
| bool to_bomd | If true, the timeout for this command is extended since it’s being sent to a BOMD via a Mirror device. |
Change Payment Mode command structure (ZCL_PREPAY_CLI_CMD_CHANGE_PAYMENT_MODE)
Parameters
| uint32_t provider_id | Provider ID |
| uint32_t implement_time | Implementation Date/Time |
| uint16_t ctrl_config | Proposed Payment Control Configuration |
| int32_t cutoff_value | Cut Off Value |
Consumer Change Supply Mode Response command structure
Parameters
| uint8_t friendly_credit | Friendly Credit Bitmap |
| uint32_t friendly_calendar_id | Friendly Credit Calendar Id |
| uint32_t emerg_credit_limit | Emergency Credit Limit |
| uint32_t emerg_credit_thresh | Emergency Credit Threshold |
Parameters
origin_device |
Originating Device |
| uint8_t topup_code | TopUp Code (ZCL octet string, first byte is length) |
Parameters
| enum ZbZclPrepayTopUpResultT result | Result Type Field enumeration |
| int32_t value | Top Up Value |
| enum ZbZclPrepayOriginDeviceT source | Originating Device Field enumeration |
| int32_t credit_remain | Credit Remaining |
Credit Adjustment command structure (ZCL_PREPAY_CLI_CMD_CREDIT_ADJUST)
Parameters
| uint32_t start_time | Start Time |
| enum ZbZclPrepayCreditTypeT
credit_adjust_type |
Credit Adjustment Type |
| int32_t credit_adjust_value | Credit Adjustment Value |
ZbZclPrepayDebtRecordT
Debt Payload structure
Parameters
| uint32_t collect_time | Collection Time - UTC Time |
| uint32_t amount_collect | Amount Collected |
| enum ZbZclPrepayDebtTypeT debt_type | Debt Type |
| uint32_t outstand_debt | Outstanding Debt |
Parameters
Parameters
| uint32_t latest_end_time | Latest EndTime - UTC Time |
| uint8_t number_of_debts | Number of Debts |
Get Prepay Snapshot command structure (ZCL_PREPAY_CLI_CMD_GET_PREPAY_SNAPSHOT)
Parameters
| uint32_t start_time | Earliest Start Time - UTC Time |
| uint32_t latest_end_time | Latest End Time - UTC Time |
| uint8_t snapshot_offset | Snapshot offset. |
| uint32_t snapshot_cause | Snapshot cause. |
Parameters
| uint8_t number_of_records | Number of Records |
Parameters
| uint8_t command_index | Command Index |
| uint8_t total_commands | Total Number of Commands |
| struct ZbZclPrepayDebtRecordT
debt_records |
Debt Payload |
| uint8_t num_records | Number of records in 'debt_records' |
Parameters
| uint32_t issue_time | Command Issue Date/Time |
origin_device |
Prepayment Server callbacks configuration
Parameters
| select_avail_emerg_credit
(callback function pointer) |
enum ZclStatusCodeT (*select_avail_emerg_credit)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepaySelectAvailEmergCreditReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Select Available Emergency Credit command (ZCL_PREPAY_CLI_CMD_SELECT_AVAIL_EMERG_CREDIT). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates ZCL_PREPAY_SVR_ATTR_CREDIT_STATUS attribute as per the command. |
| change_debt
enum ZclStatusCodeT (*change_debt)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayChangeDebtReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Change Debt command (ZCL_PREPAY_CLI_CMD_CHANGE_DEBT). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates attributes ZCL_PREPAY_SVR_ATTR_DEBT_LABEL_N(n) to ZCL_PREPAY_SVR_ATTR_DEBT_REC_TOPUP_PERCENT_N(n) as per the command. |
| emerg_credit_setup
enum ZclStatusCodeT (*emerg_credit_setup)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayEmergCreditSetupReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Emergency Credit Setup command (ZCL_PREPAY_CLI_CMD_EMERG_CREDIT_SETUP). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attributes ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_ALLOWANCE and ZCL_PREPAY_SVR_ATTR_EMERG_CREDIT_THRESHOLD, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned emerg_credit_setup requests with matching 'IssuerEvent ID' will be cancelled. |
| consumer_topup
enum ZclStatusCodeT (*consumer_topup)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayConsumerTopUpReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Consumer Top Up command. Return ZCL_STATUS_SUCCESS if log(s) found and Consumer Top Up Response sent (ZbZclPrepayServerConsumerTopUpRsp), or ZCL_STATUS_NOT_FOUND otherwise. |
| credit_adjust
enum ZclStatusCodeT (*credit_adjust)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayCreditAdjustReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Credit Adjustment command (ZCL_PREPAY_CLI_CMD_CREDIT_ADJUST). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attribute ZCL_PREPAY_SVR_ATTR_CREDIT_REMAINING, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned credit_adjust requests with matching 'IssuerEvent ID' will be cancelled. |
| change_payment_mode
enum ZclStatusCodeT (*change_payment_mode)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayChangePaymentModeReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Change Payment Mode command (ZCL_PREPAY_CLI_CMD_CHANGE_PAYMENT_MODE). Returns ZCL status code from sending ZbZclPrepayServerChangePaymentModeRsp() (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attribute ZCL_PREPAY_SVR_ATTR_PAYMENT_CONTROL_CONFIG, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned change_payment_mode requests with matching 'Provider ID' and 'IssuerEvent ID' will be cancelled. |
| get_prepay_snapshot
enum ZclStatusCodeT (*get_prepay_snapshot)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayGetPrepaySnapshotReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Prepay Snapshot command. Return ZCL_STATUS_SUCCESS if snapshot(s) found and Publish Snapshot command sent (ZbZclPrepayServerPublishPrepaySnapshotRsp), or ZCL_STATUS_NOT_FOUND otherwise. |
| get_debt_repay_log
enum ZclStatusCodeT (*get_debt_repay_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayGetDebtRepayLogReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Debt Repayment Log command. Return ZCL_STATUS_SUCCESS if log(s) found and Publish Debt Log command(s) sent (ZbZclPrepayServerPublishDebtLogRsp), or ZCL_STATUS_NOT_FOUND otherwise. |
| get_topup_log
enum ZclStatusCodeT (*get_topup_log)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepayGetTopUpLogReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get TopUp Log command. Return ZCL_STATUS_SUCCESS if log(s) found and Publish TopUp Log command(s) sent (ZbZclPrepayServerPublishTopUpLogRsp), or ZCL_STATUS_NOT_FOUND otherwise. |
| set_low_credit_warn_level
enum ZclStatusCodeT (*set_low_credit_warn_level)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepaySetLowCreditWarnLevelReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Set Low Credit Warning Level command (ZCL_PREPAY_CLI_CMD_SET_LOW_CREDIT_WARN_LEVEL). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attributes ZCL_PREPAY_SVR_ATTR_LOW_CREDIT_WARNING and ZCL_PREPAY_SVR_ATTR_CREDIT_REMAINING. |
| set_max_credit_limit
enum ZclStatusCodeT (*set_max_credit_limit)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepaySetMaxCreditLimitReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Set Max Credit Limit command (ZCL_PREPAY_CLI_CMD_SET_MAX_CREDIT_LIMIT). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attributes ZCL_PREPAY_SVR_ATTR_MAX_CRED_LIMIT and ZCL_PREPAY_SVR_ATTR_MAX_CRED_PER_TOPUP, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned set_max_credit_limit requests with matching 'Provider ID' and 'IssuerEvent ID' will be cancelled. |
| set_overall_debt_cap
enum ZclStatusCodeT (*set_overall_debt_cap)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPrepaySetOverallDebtCapReqT *info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Set Overall Debt Cap command (ZCL_PREPAY_CLI_CMD_SET_OVERALL_DEBT_CAP). Return ZCL status code (e.g. ZCL_STATUS_SUCCESS) to include in Default Response. If the application callback returns ZCL status of ZCL_STATUS_SUCCESS, then the stack updates the attribute ZCL_PREPAY_SVR_ATTR_OVERALL_DEBT_CAP, provided start_time is != 0xffffffff. If start_time is 0xffffffff then previous scheduled & unactioned set_overall_debt_cap requests with matching 'Provider ID' and 'IssuerEvent ID' will be cancelled. |
Parameters
| uint32_t warn_level | Low Credit Warning Level |
Set Maximum Credit Limit
Parameters
| uint32_t implement_time | Implementation Data/Time |
| uint32_t max_credit_level | Maximum Credit Level |
| uint32_t max_credit_per_topup | Maximum Credit Per Top Up |
Parameters
| int32_t overall_debt_cap | Overall Debt Cap |
8. Price
#include "zcl/se/zcl.price.h"
Functions
ZbZclPriceClientAlloc
struct ZbZclClusterT * ZbZclPriceClientAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPriceClientCallbacksT *callbacks, void *arg);
Create a new instance of the Price Client cluster
Parameters
| callbacks | Structure containing any callback function pointers for this cluster |
| arg | Pointer to application data that will included in the callback when invoked. |
Return
ZbZclPriceClientCommandGetBillingPeriodReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetBillingPeriodReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetBillingPeriodT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Billing Period command
Parameters
| cmd_req | Get Billing Period command structure |
Return
ZbZclPriceClientCommandGetBlockPeriodReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetBlockPeriodReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetBlockPeriodT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Block Period(s) command
Parameters
| cmd_req | Get Block Period(s) command structure |
Return
ZbZclPriceClientCommandGetBlockThresholdsReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetBlockThresholdsReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetBlockThresholdsT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Block Thresholds command
Parameters
| cmd_req | Get Block Thresholds command structure |
Return
ZbZclPriceClientCommandGetCO2ValueReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetCO2ValueReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetCO2ValueT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get CO2 Value command
Parameters
| cmd_req | Get CO2 Value command structure |
Return
ZbZclPriceClientCommandGetCalorificValueReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetCalorificValueReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetCalorificValueT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Calorific Value command
Parameters
| cmd_req | Get Calorific Value command structure |
Return
ZbZclPriceClientCommandGetConsolidatedBillReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetConsolidatedBillReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetConsolidatedBillT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Consolidated Bill command
Parameters
| cmd_req | Get Consolidated Bill command structure |
| arg | Pointer to application data that will be provided back to the callback function when invoked. |
Return
ZbZclPriceClientCommandGetConversionFactorReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetConversionFactorReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetConversionFactorT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Conversion Factor command
Parameters
| cmd_req | Get Conversion Factor command structure |
Return
ZbZclPriceClientCommandGetCurrencyConversionReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetCurrencyConversionReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Currency Conversion command
Parameters
Return
ZbZclPriceClientCommandGetCurrentPriceReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetCurrentPriceReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Current Price command
Parameters
Return
ZbZclPriceClientCommandGetPriceMatrixReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetPriceMatrixReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetPriceMatrixT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Price Matrix command
Parameters
| cmd_req | Get Price Matrix command structure |
Return
ZbZclPriceClientCommandGetScheduledPricesReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetScheduledPricesReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetScheduledPricesT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Scheduled Prices command
Parameters
| cmd_req | Get Scheduled Prices command structure |
Return
ZbZclPriceClientCommandGetTariffInfoReq
enum ZclStatusCodeT ZbZclPriceClientCommandGetTariffInfoReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientGetTariffInfoT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Get Tariff Information command
Parameters
| cmd_req | Get Tariff Information command structure |
Return
ZbZclPriceClientCommandPriceAckReq
enum ZclStatusCodeT ZbZclPriceClientCommandPriceAckReq(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceClientPriceAckT *cmd_req, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send a Price Acknowledgement command
Parameters
| cmd_req | Price Acknowledge command structure |
Return
ZbZclPriceMirrorAlloc
struct ZbZclClusterT * ZbZclPriceMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *price_server, struct ZbZclClusterT *meter_mirror, struct ZbZclClusterT *meter_client);
Allocates a Price Client Mirror cluster.
Parameters
| price_server | Pointer to Price Server cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
| meter_mirror | Pointer to Metering Mirror cluster. This is used to queue any commands that need to be forwarded to the BOMD when it wakes up. |
Return
ZbZclPriceServerAlloc
struct ZbZclClusterT * ZbZclPriceServerAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclPriceServerCallbacksT *callbacks, void *arg);
Create a new instance of the Price Server cluster
Parameters
Return
ZbZclPriceServerPublishPriceInit
void ZbZclPriceServerPublishPriceInit(struct ZbZclPriceServerPublishPriceT *rsp);
Initialize Publish Price information
Parameters
| rsp | Publish Price command structure |
Return
- Void
ZbZclPriceServerSendPublishBillingPeriodRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishBillingPeriodRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishBillingPeriodT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Billing Period command as a response
Parameters
| dst | Destination address for command, including sequence number and tx options |
| info | Publish Billing Period command structure |
| callback | Callback function for an APSDE-DATA.confirm |
| arg | Pointer to application data that will later be provided back to the callback function when invoked |
Return
ZbZclPriceServerSendPublishBillingPeriodUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishBillingPeriodUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishBillingPeriodT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Billing Period command
Parameters
| dst | Destination address for command |
| callback | Callback function that will be invoked when response is received, if one is expected. If broadcasting, then this should be set to NULL since no response is expected |
Return
ZbZclPriceServerSendPublishBlockPeriodRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishBlockPeriodRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishBlockPeriodT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Block Period command as a response
Parameters
| info | Publish Block Period command structure |
Return
ZbZclPriceServerSendPublishBlockPeriodUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishBlockPeriodUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishBlockPeriodT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Block Period command
Parameters
Return
ZbZclPriceServerSendPublishBlockThresholdsRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishBlockThresholdsRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishBlockThresholdsT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Block Thresholds command as a response
Parameters
| info | Publish Block Thresholds command structure |
Return
ZbZclPriceServerSendPublishBlockThresholdsUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishBlockThresholdsUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishBlockThresholdsT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Block Thresholds command
Parameters
Return
ZbZclPriceServerSendPublishCO2ValueRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishCO2ValueRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishCO2ValueT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish CO2 Value command as a response
Parameters
| info | Publish CO2 Value command structure |
Return
ZbZclPriceServerSendPublishCO2ValueUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishCO2ValueUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishCO2ValueT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish CO2 Value command
Parameters
Return
ZbZclPriceServerSendPublishCalorificValueRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishCalorificValueRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishCalorificValueT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Calorific Value command as a response
Parameters
| info | Publish Calorific Value command structure |
Return
ZbZclPriceServerSendPublishCalorificValueUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishCalorificValueUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishCalorificValueT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Calorific Value command
Parameters
Return
ZbZclPriceServerSendPublishConsolidatedBillRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishConsolidatedBillRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishConsolidatedBillT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Consolidated Bill command as a response
Parameters
| info | Publish Consolidated Bill command structure |
Return
- ZCL_STATUS_SUCCESS if successful, or other ZCL_STATUS value on error
ZbZclPriceServerSendPublishConsolidatedBillUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishConsolidatedBillUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishConsolidatedBillT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Consolidated Bill command
Parameters
| callback | Callback function that will be invoked when response is received, if one is expected. If broadcasting, then this should be set to NULL since no response is expected. |
Return
ZbZclPriceServerSendPublishConversionFactorRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishConversionFactorRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishConversionFactorT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Conversion Factor command as a response
Parameters
| info | Publish Conversion Factor command structure |
Return
ZbZclPriceServerSendPublishConversionFactorUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishConversionFactorUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishConversionFactorT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Conversion Factor command
Parameters
Return
ZbZclPriceServerSendPublishCurrencyConversionRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishCurrencyConversionRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishCurrencyConversionT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Currency Conversion command as a response
Parameters
| info | Publish Currency Conversion command structure |
Return
- ZCL_STATUS_SUCCESS or other ZCL_STATUS value on error
ZbZclPriceServerSendPublishCurrencyConversionUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishCurrencyConversionUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishCurrencyConversionT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Currency Conversion command
Parameters
Return
- ZCL_STATUS_SUCCESS if successful or other ZCL_STATUS value on error
ZbZclPriceServerSendPublishMatrixUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishMatrixUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishPriceMatrixT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Price Matrix command
Parameters
| info | Publish Price Matrix command structure |
Return
ZbZclPriceServerSendPublishPriceRsp
enum ZclStatusCodeT ZbZclPriceServerSendPublishPriceRsp(struct ZbZclClusterT *cluster, struct ZbZclAddrInfoT *dst, struct ZbZclPriceServerPublishPriceT *info, void (*callback)(struct ZbApsdeDataConfT *conf, void *arg), void *arg);
Send a Publish Price command as a response
Parameters
| info | Publish Price command structure |
Return
ZbZclPriceServerSendPublishPriceUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishPriceUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishPriceT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Price command
Parameters
Return
- ZCL_STATUS_SUCCESS if successful, or other ZclStatusCodeT value on error
ZbZclPriceServerSendPublishTariffInfoUnsolic
enum ZclStatusCodeT ZbZclPriceServerSendPublishTariffInfoUnsolic(struct ZbZclClusterT *cluster, const struct ZbApsAddrT *dst, struct ZbZclPriceServerPublishTariffInfoT *info, void (*callback)(struct ZbZclCommandRspT *rsp, void *arg), void *arg);
Send an unsolicited Publish Tariff Information command
Parameters
| info | Publish Tariff Info command structure |
Return
Enumerations
ZbZclPriceSvrAttrT
Price Server Attribute IDs
| ZCL_PRICE_SVR_ATTR_TIER1_LABEL | Tier1PriceLabel (Optional)
ZCL_PRICE_SVR_ATTR_TIERN_LABEL(1) For all the tiers, use the ZCL_PRICE_SVR_ATTR_TIERN_LABEL(tier) macro. |
| ZCL_PRICE_SVR_ATTR_BLOCK1_THRESHOLD | Block1Threshold (Optional)
ZCL_PRICE_SVR_ATTR_BLOCKN_THRESHOLD(1) For all the blocks, use the ZCL_PRICE_SVR_ATTR_BLOCKN_THRESHOLD(block) macro. For all tiers and blocks, use the ZCL_PRICE_SVR_ATTR_TIERN_BLOCKN_THRESHOLD(tier, block) macro |
| ZCL_PRICE_SVR_ATTR_BLOCK_THRESHOLD_COUNT | BlockThresholdCount (Optional) ZCL_PRICE_SVR_ATTR_TIERN_BLOCK_THRESHOLD_COUNT(0) For all the tiers, use the ZCL_PRICE_SVR_ATTR_TIERN_BLOCK_THRESHOLD_COUNT(tier) macro. |
| ZCL_PRICE_SVR_ATTR_START_OF_BLOCK_PERIOD | StartofBlockPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_BLOCK_PERIOD_DURATION | BlockPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_THRESHOLD_MULTIPLIER | ThresholdMultiplier (Optional) |
| ZCL_PRICE_SVR_ATTR_THRESHOLD_DIVISOR | ThresholdDivisor (Optional) |
| ZCL_PRICE_SVR_ATTR_BLOCK_PERIOD_DURATION_TYPE | BlockPeriodDurationType (Optional) |
| ZCL_PRICE_SVR_ATTR_COMMODITY_TYPE | CommodityType (Optional) |
| ZCL_PRICE_SVR_ATTR_STANDING_CHARGE | StandingCharge (Optional) |
| ZCL_PRICE_SVR_ATTR_CONVERSION_FACTOR | ConversionFactor (Optional) |
| ZCL_PRICE_SVR_ATTR_CONVERSION_FACTOR_TRAILING_DIGIT | ConversionFactorTrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_CALORIFIC_VALUE | CalorificValue (Optional) |
| ZCL_PRICE_SVR_ATTR_CALORIFIC_VALUE_UNIT | CalorificValueUnit (Optional) |
| ZCL_PRICE_SVR_ATTR_CALORIFIC_VALUE_TRAILING_DIG IT | CalorificValueTrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_NO_TIER_BLOCK1_PRICE | NoTierBlock1Price (Optional) ZCL_PRICE_SVR_ATTR_NO_TIER_BLOCKN_PRICE(1) For all the blocks, use the ZCL_PRICE_SVR_ATTR_NO_TIER_BLOCKN_PRICE(block) macro. |
| ZCL_PRICE_SVR_ATTR_TIER1_BLOCK1_PRICE | Tier1Block1Price (Optional) ZCL_PRICE_SVR_ATTR_TIERN_BLOCKN_PRICE(1,1) For all the tiers and blocks, use the ZCL_PRICE_SVR_ATTR_TIERN_BLOCKN_PRICE(tier, block) macro. |
| ZCL_PRICE_SVR_ATTR_PRICE_TIER16 | PriceTier16 (Optional) ZCL_PRICE_SVR_ATTR_PRICE_TIERN(16) For all the tiers, use the ZCL_PRICE_SVR_ATTR_PRICE_TIERN(tier) macro. |
| ZCL_PRICE_SVR_ATTR_CPP1_PRICE | CPP1 Price (Optional) |
| ZCL_PRICE_SVR_ATTR_CPP2_PRICE | CPP2 Price (Optional) |
| ZCL_PRICE_SVR_ATTR_TARIFF_LABEL | TariffLabel (Optional) |
| ZCL_PRICE_SVR_ATTR_NO_PRICE_TIERS_IN_USE | NumberOfPriceTiersInUse (Optional) |
| ZCL_PRICE_SVR_ATTR_NO_BLOCK_THRESH_IN_USE | NumberOfBlockThresholdsInUse (Optional) |
| ZCL_PRICE_SVR_ATTR_TIER_BLOCK_MODE | TierBlockMode (Optional) |
| ZCL_PRICE_SVR_ATTR_UNIT_OF_MEASURE | UnitOfMeasure (Optional) |
| ZCL_PRICE_SVR_ATTR_CURRENCY | Currency (Optional) |
| ZCL_PRICE_SVR_ATTR_PRICE_TRAILING_DIGIT | PriceTrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_TARIFF_RESLTN_PERIOD | TariffResolutionPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_CO2 | CO2Value (Optional) |
| ZCL_PRICE_SVR_ATTR_CO2_UNIT | CO2ValueUnit (Optional) |
| ZCL_PRICE_SVR_ATTR_CO2_TRAILING_DIGIT | CO2TrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_CBP_START | CurrentBillingPeriodStart (Optional) |
| ZCL_PRICE_SVR_ATTR_CBP_DURATION | CurrentBillingPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_LBP_START | LastBillingPeriodStart (Optional) |
| ZCL_PRICE_SVR_ATTR_LBP_DURATION | LastBillingPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_LBP_CONSOLIDATED_BILL | LastBillingPeriodConsolidatedBill (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DUE_DATE | CreditPaymentDueDate (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_STATUS | CreditPaymentStatus (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_OVERDUE_AMT | CreditPaymentOverdueAmount (Optional) |
| ZCL_PRICE_SVR_ATTR_PAYMENT_DISCOUNT | PaymentDiscount (Optional) |
| ZCL_PRICE_SVR_ATTR_PAYMENT_DISCOUNT_PERIOD | PaymentDiscountPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_1 | CreditPayment#1 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_1 | CreditPaymentDate#1 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_1 | CreditPaymentRef#1 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_2 | CreditPayment#2 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_2 | CreditPaymentDate#2 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_2 | CreditPaymentRef#2 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_3 | CreditPayment#3 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_3 | CreditPaymentDate#3 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_3 | CreditPaymentRef#3 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_4 | CreditPayment#4 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_4 | CreditPaymentDate#4 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_4 | CreditPaymentRef#4 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_5 | CreditPayment#5 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_DATE_5 | CreditPaymentDate#5 (Optional) |
| ZCL_PRICE_SVR_ATTR_CRDT_PAYMENT_REF_5 | CreditPaymentRef#5 (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_TIER1_LABEL | ReceivedTier1PriceLabel ZCL_PRICE_SVR_ATTR_RECV_TIERN_LABEL(1) For all the tiers, use the ZCL_PRICE_SVR_ATTR_RECV_TIERN_LABEL(tier) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_BLOCK1_THRESHOLD | ReceivedBlock1Threshold ZCL_PRICE_SVR_ATTR_RECV_BLOCKN_THRESHOLD(1)
For all the blocks, use the ZCL_PRICE_SVR_ATTR_RECV_BLOCKN_THRESHOLD(block) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_START_OF_BLOCK_PERIOD | ReceivedStartofBlockPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_BLOCK_PERIOD_DURATION | ReceivedBlockPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_THRESHOLD_MULTIPLIER | ReceivedThresholdMultiplier (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_THRESHOLD_DIVISOR | ReceivedThresholdDivisor (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_NO_TIER_BLOCK1_PRICE | RxNoTierBlock1Price ZCL_PRICE_SVR_ATTR_RECV_NO_TIER_BLOCKN_PRICE(1) For all the blocks, use the ZCL_PRICE_SVR_ATTR_RECV_NO_TIER_BLOCKN_PRICE(block) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_TIER1_BLOCK1_PRICE | RxTier1Block1Price ZCL_PRICE_SVR_ATTR_RECV_TIERN_BLOCKN_PRICE(1,1)
For all the tiers and blocks, use the ZCL_PRICE_SVR_ATTR_RECV_TIERN_BLOCKN_PRICE(tier, block) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_PRICE_TIER16 | RxPriceTier16 ZCL_PRICE_SVR_ATTR_RECV_PRICE_TIERN(16) For all the tiers, use the ZCL_PRICE_SVR_ATTR_RECV_PRICE_TIERN(tier) macro. |
| ZCL_PRICE_SVR_ATTR_RECV_TARIFF_LABEL | ReceivedTariffLabel (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_NO_PRICE_TIERS_IN_USE | ReceivedNumberOfPriceTiersInUse (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_NO_BLOCK_THRESH_IN_U SE | ReceivedNumberOfBlockThresholdsInUse (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_TIER_BLOCK_MODE | ReceivedTierBlockMode (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_TARIFF_RESLTN_PERIOD | ReceivedTariffResolutionPeriod (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CO2 | ReceivedCO2Value (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CO2_UNIT | ReceivedCO2ValueUnit (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CO2_TRAILING_DIGIT | ReceivedCO2TrailingDigit (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CBP_START | ReceivedCurrentBillingPeriodStart (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_CBP_DURATION | ReceivedCurrentBillingPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_LBP_START | ReceivedLastBillingPeriodStart (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_LBP_DURATION | ReceivedLastBillingPeriodDuration (Optional) |
| ZCL_PRICE_SVR_ATTR_RECV_LBP_CONSOLIDATED_BILL | ReceivedLastBillingPeriodConsolidatedBill (Optional) |
ZbZclPriceTariffChargingSchemeT
Tariff Charging Scheme Enumeration
| ZCL_PRICE_CHARGE_TOU_TARIFF | TOU Tariff |
| ZCL_PRICE_CHARGE_BLOCK_TARIFF | Block Tariff |
| ZCL_PRICE_CHARGE_BLOCK_TOU_COMM_THRESH | Block/TOU Tariff with common thresholds |
| ZCL_PRICE_CHARGE_BLOCK_TOU_IND_THRESH | Block/TOU Tariff with individual thresholds per tier |
ZbZclPriceTariffTypeT
Tariff Type Enumeration
| ZCL_PRICE_TARIFF_TYPE_DELIV | Delivered tariff |
| ZCL_PRICE_TARIFF_TYPE_RECV | Received tariff |
| ZCL_PRICE_TARIFF_TYPE_DELIV_RECV | Delivered and received tariff |
| ZCL_PRICE_TARIFF_TYPE_UNSPECIFIED | Unspecified tariff type, meaning any tariff type. |
ZbZclPriceTierBlockModeT
Tier Block Mode Enumeration
| ZCL_PRICE_TIER_BLOCK_MODE_0 | This tariff employs a single set of thresholds. |
| ZCL_PRICE_TIER_BLOCK_MODE_1 | This tariff employs a single set of thresholds common across all TOU tiers. |
| ZCL_PRICE_TIER_BLOCK_MODE_2 | This combination tariff employs an individual set of Thresholds for each TOU tier. |
Structures
Price Client callbacks configuration
Parameters
| publish_price
enum ZclStatusCodeT (*publish_price)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishPriceT *price, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Price command. |
| publish_conversion_factor
enum ZclStatusCodeT (*publish_conversion_factor)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishConversionFactorT *co2, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Conversion Factor command. |
| publish_calorific_value
enum ZclStatusCodeT (*publish_calorific_value)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishCalorificValueT *calorific, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Calorific Value command. |
| publish_tariff_info
enum ZclStatusCodeT (*publish_tariff_info)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishTariffInfoT *tariff_info, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Tariff information command. |
| publish_price_matrix
enum ZclStatusCodeT (*publish_price_matrix)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishPriceMatrixT *price_matrix, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Price Matrix command. |
| publish_block_thresholds
enum ZclStatusCodeT (*publish_block_thresholds)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishBlockThresholdsT *block_threshs, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Block Thresholds command. |
| publish_block_period
enum ZclStatusCodeT (*publish_block_period)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishBlockPeriodT *block_period, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Block Period command. |
| publish_co2_value
enum ZclStatusCodeT (*publish_co2_value)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishCO2ValueT *co2, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish CO2 Value command. |
| publish_billing_period
enum ZclStatusCodeT (*publish_billing_period)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishBillingPeriodT *period, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Billing Period command. |
| publish_consolidated_bill
enum ZclStatusCodeT (*publish_consolidated_bill)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishConsolidatedBillT *bill, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Consolidated Bill command. |
| publish_currency_conversion
enum ZclStatusCodeT (*publish_currency_conversion)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceServerPublishCurrencyConversionT *conversion, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Publish Currency Conversion command. |
| optional
enum ZclStatusCodeT (*optional)(struct ZbZclClusterT *cluster, struct ZbZclHeaderT *zclHdrPtr, struct ZbApsdeDataIndT *dataIndPtr)
Callback to application, invoked on receipt of optional Server commands. |
Parameters
| uint32_t earliest_start_time | Earliest Start Time |
| uint32_t min_issuer_event_id | Min. Issuer Event ID |
| uint8_t num_commands | Number of Commands |
| enum ZbZclPriceTariffTypeT tariff_type | Optional - Tariff Type |
Get Block Period command structure
Parameters
| uint32_t start_time | Start Time - UTC Time |
| uint8_t num_events | Number of Events requested |
| enum ZbZclPriceTariffTypeT tariff_type | Tariff Type |
Parameters
| uint32_t issuer_tariff_id | Issuer Tariff ID |
Parameters
Parameters
Parameters
Parameters
ZbZclPriceClientGetCurrentPriceT
Get Current Price command structure
Parameters
| uint8_t command_options | Command Options |
Parameters
Parameters
| uint32_t startTime | StartTime |
| uint8_t maxPrices | NumberofEvents |
Parameters
Parameters
| uint32_t price_ack_time | Price Ack Time |
| uint8_t control | Control. E.g. ZCL_PRICE_CTRL_MASK_PRICE_ACK |
ZbZclPriceServerBlockThreshEntryT
Block Threshold Entry structure
Parameters
| uint8_t tier_num_block_thresh | Tier/NumberOfBlockThresholds |
| uint64_t *block_thresh | Block Threshold |
Price Server callbacks configuration
Parameters
| get_current_price
enum ZclStatusCodeT (*get_current_price)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetCurrentPriceT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Current command. Return ZCL_STATUS_SUCCESS if Publish Price command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| price_ack
enum ZclStatusCodeT (*price_ack)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientPriceAckT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Price Acknowledgement command. |
| get_scheduled_prices
enum ZclStatusCodeT (*get_scheduled_prices)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetScheduledPricesT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Scheduled Prices command. Return ZCL_STATUS_SUCCESS if relevant Events are sent in Publish Price commands or ZCL_STATUS_NOT_FOUND otherwise. |
| get_tariff_info
enum ZclStatusCodeT (*get_tariff_info)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetTariffInfoT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Tariff Information command. Return ZCL_STATUS_SUCCESS if Publish Tariff Information command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_price_matrix
enum ZclStatusCodeT (*get_price_matrix)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetPriceMatrixT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Price Matrix command. Return ZCL_STATUS_SUCCESS if Publish Price Matrix command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_block_thresholds
enum ZclStatusCodeT (*get_block_thresholds)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetBlockThresholdsT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Block Thresholds command. Return ZCL_STATUS_SUCCESS if Publish Block Thresholds command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_calorific_value
enum ZclStatusCodeT (*get_calorific_value)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetCalorificValueT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Calorific Value command. Return ZCL_STATUS_SUCCESS if Publish Calorific Value command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_co2_value
enum ZclStatusCodeT (*get_co2_value)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetCO2ValueT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get CO2 Value command. Return ZCL_STATUS_SUCCESS if Publish CO2 Value command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_conversion_factor
enum ZclStatusCodeT (*get_conversion_factor)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetConversionFactorT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Conversion Factor command. Return ZCL_STATUS_SUCCESS if Publish Conversion Factor command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_block_period
enum ZclStatusCodeT (*get_block_period)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetBlockPeriodT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Block Period command. Return ZCL_STATUS_SUCCESS if Publish Block Period command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_billing_period
enum ZclStatusCodeT (*get_billing_period)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetBillingPeriodT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Billing Period command. Return ZCL_STATUS_SUCCESS if Publish Billing Period command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_consolidated_bill
enum ZclStatusCodeT (*get_consolidated_bill)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclPriceClientGetConsolidatedBillT *req, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Consolidated Bill command. Return ZCL_STATUS_SUCCESS if Publish Consolidated Bill command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| get_currency_conversion
enum ZclStatusCodeT (*get_currency_conversion)(struct ZbZclClusterT *cluster, void *arg, struct ZbZclAddrInfoT *srcInfo)
Callback to application, invoked on receipt of Get Currency Conversion command. Return ZCL_STATUS_SUCCESS if Publish Currency Conversion command sent or ZCL_STATUS_NOT_FOUND otherwise. |
| optional
Callback to application, invoked on receipt of optional Client commands. |
ZbZclPriceServerPriceMatrixEntryT
Price Matrix Entry structure
Parameters
| uint8_t tier_block_id | Tier/Block ID |
| uint32_t price | Price |
Parameters
| uint32_t start_time | Billing Period Start Time - UTC Time |
| uint32_t duration | Billing Period Duration |
| uint8_t duration_type | Billing Period Duration Type |
Parameters
| uint32_t block_period_start_time | Block Period Start Time - UTC Time |
| uint32_t block_period_duration | Block Period Duration |
| uint8_t block_period_control | Block Period Control |
| uint8_t block_period_duration_type | Block Period Duration Type |
| uint8_t tariff_resolution_period | Tariff Resolution Period |
Parameters
| uint8_t total_number_commands | Total Number of Commands |
| uint8_t sub_payload_control | Sub-payload Control |
| uint8_t num_sub_payload | Number of items in Block Threshold Sub-payload |
| struct ZbZclPriceServerBlockThreshEntryT sub_payload | Block Threshold Sub-payload |
Parameters
| uint32_t co2_value | CO2 Value |
| uint8_t co2_value_unit | CO2 Value Unit |
| uint8_t co2_value_trail_digits | CO2 Value Trailing Digit |
Parameters
| uint32_t calorific_value | Calorific Value |
| uint8_t calorific_value_unit | Calorific Value Unit |
| uint8_t calorific_value_trail_digits | Calorific Value Trailing Digit |
Parameters
| uint32_t consolidated_bill | Consolidated Bill |
| uint16_t currency | Currency |
| uint8_t bill_trail_digits | Bill Trailing Digit |
Parameters
| uint32_t conversion_factor | Conversion Factor |
| uint8_t conversion_factor_trail_digits | Conversion Factor Trailing Digit |
Parameters
| uint16_t old_currency | Old Currency |
| uint16_t new_currency | New Currency |
| uint8_t conversion_trail_digits | Conversion Trailing Digit |
| uint32_tcurrency_change_control_flags | Currency Change Control Flags |
Parameters
| uint8_t num_sub_payload | Number of items in Price Matrix Sub-payload |
| struct ZbZclPriceServerPriceMatrixEntryT
sub_payload |
Parameters
| char rate_label | Rate Label array |
| uint32_t current_Time | Current Time - UTC Time |
| enum ZbZclMeterUnitsT
unit_of_measure |
Unit of Measure |
| enum ZbZclPriceCurrencyCodeT
currency |
Currency |
| uint8_t trailing_digit_and_price_tier | Price Trailing Digit & Price Tier |
| uint8_t num_price_tiers | Number of Price Tiers & Register Tier |
| uint16_t duration | Duration in Minutes |
| uint8_t price_ratio | Price Ratio (Optional) |
| uint32_t generation_price | Generation Price (Optional) |
| uint8_t generation_price_ratio | Generation Price Ratio (Optional) |
| uint32_t alternate_cost_delivered | Alternate Cost Delivered (Optional) |
| uint8_t alternate_cost_units | Alternate Cost Unit (Optional) |
| uint8_t alternate_cost_trail_digits | Alternate Cost Trailing Digit (Optional) |
| uint8_t num_block_thresholds | Number of Block Thresholds (Optional) |
| uint8_t price_control | Price Control (Optional) |
| uint8_t number_of_gen_tiers | Number of Generation Tiers (Optional) |
| uint8_t gen_tier | Generation Tier (Optional) |
| uint8_t ext_number_price_tiers | Extended Number of Price Tiers (Optional) |
| uint8_t ext_price_tier | Extended Price Tier (Optional) |
| uint8_t ext_register_tier | Extended Register Tier (Optional) |
Parameters
| uint8_t
tariff_type_and_charging_scheme |
Tariff Type/Charging Scheme |
| char tariff_label | Tariff Label array |
| uint8_t number_of_price_tiers_in_use | Number of Price Tiers in Use |
| uint8_t
number_of_block_thresh_in_use |
Number of Block Thresholds in Use |
| uint8_t unit_of_measure | Unit of Measure |
| uint8_t price_trailing_digit | Price Trailing Digit |
| uint32_t standing_charge | Standing Charge |
| uint8_t tier_block_mode | TierBlockMode |
| uint32_t block_thresh_multiplier | Block Threshold Multiplier - 24-bit |
| uint32_t block_thresh_divisor | Block Threshold Divisor - 24-bit |
9. Tunneling
#include "zcl/se/zcl.tunnel.h"
Functions
ZbZclTunnelClientAddProto
enum ZclStatusCodeT ZbZclTunnelClientAddProto(struct ZbZclClusterT *cluster, enum ZbZclTunnelProtocolT protocol, uint16_t mfr, uint16_t mtu, struct ZbZclTunnelProtoCbT *callbacks);
Add a protocol tunnel to the server
Parameters
| cluster | Cluster instance from which to send this command |
| protocol | Protocol ID enumeration |
| mfr | Manufacturer ID |
| mtu | Protocol’s MTU |
| callbacks | Protocol callbacks |
Return
ZbZclTunnelClientAlloc
struct ZbZclClusterT * ZbZclTunnelClientAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Tunneling Client cluster
Parameters
| zb | Zigbee stack instance |
| endpoint | Endpoint on which to create cluster |
Return
- Cluster pointer, or NULL if there is an error
ZbZclTunnelClientCloseQuietReq
enum ZclStatusCodeT ZbZclTunnelClientCloseQuietReq(struct ZbZclClusterT *cluster);
Close the local tunnel without informing the server
Parameters
Return
ZbZclTunnelClientCloseReq
enum ZclStatusCodeT ZbZclTunnelClientCloseReq(struct ZbZclClusterT *cluster, struct ZbZclTunnelCloseT *close, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Close Tunnel command
Parameters
| close | Close Tunnel command structure. |
| callback | Callback function that will be invoked when the response is received. |
Return
ZbZclTunnelClientGetSupportedProtocols
enum ZclStatusCodeT ZbZclTunnelClientGetSupportedProtocols(struct ZbZclClusterT *cluster, struct ZbApsAddrT *dst, struct ZbZclTunnelGetSupportedProtocolsT *suppported_proto, void (*callback)(struct ZbZclCommandRspT *zcl_rsp, void *arg), void *arg);
Send a Get Supported Protocols command
Parameters
| dst | Destination address for this command. |
| suppported_proto | Get Supported Protocol command structure. |
Return
ZbZclTunnelClientSendReq
enum ZclStatusCodeT ZbZclTunnelClientSendReq(struct ZbZclClusterT *cluster, struct ZbZclTunnelDataT *data, void (*callback)(struct ZbZclCommandRspT *rspPr, void *arg), void *arg);
Send a Transfer Data command
Parameters
| data | Tunnel Data information structure. |
Return
ZbZclTunnelMirrorAlloc
struct ZbZclClusterT * ZbZclTunnelMirrorAlloc(struct ZigBeeT *zb, uint8_t endpoint, struct ZbZclClusterT *tunnel, struct ZbZclClusterT *meter_mirror);
Allocates a Tunneling Client/Server Mirror cluster. The caller (application) must attach any attributes to the cluster you want to mirror.
Parameters
| events_client | Pointer to Events Client cluster. This is used by the Metering Mirror to send mirrored commands to the BOMD. |
Return
ZbZclTunnelSendData
enum ZclStatusCodeT ZbZclTunnelSendData(struct ZbZclClusterT *cluster, struct ZbZclTunnelStateT *state, struct ZbZclTunnelDataT *data, void (*callback)(struct ZbZclCommandRspT *rspPtr, void *arg), void *arg);
Send data via the tunnel. If the input cluster is server then the data will be sent to the client and vice versa.
Parameters
| state | State of the tunnel |
| callback | Callback function to handle response |
Return
ZbZclTunnelServerAddProto
enum ZclStatusCodeT ZbZclTunnelServerAddProto(struct ZbZclClusterT *cluster, enum ZbZclTunnelProtocolT protocol, uint16_t mfr, uint16_t mtu, struct ZbZclTunnelProtoCbT *callbacks);
Parameters
Return
ZbZclTunnelServerAlloc
struct ZbZclClusterT * ZbZclTunnelServerAlloc(struct ZigBeeT *zb, uint8_t endpoint);
Create a new instance of the Tunneling Server cluster
Parameters
Return
ZbZclTunnelServerStateFindById
struct ZbZclTunnelStateT * ZbZclTunnelServerStateFindById(struct ZbZclClusterT *cluster, uint16_t tunnel_id);
Get tunnel server state by tunnel ID
Parameters
| tunnel_id | Tunnel ID |
Return
- State of the tunnel
ZbZclTunnelStateGetDataLen
uint32_t ZbZclTunnelStateGetDataLen(struct ZbZclTunnelStateT *state, bool clear_data);
Get received data length using Tunneling Cluster State structure
Parameters
| state | Tunneling Cluster State structure |
| clear_data | If true, clear any data queued in the tunnel. The application would first call ZbZclTunnelStateGetDataLen with clear_data set to false to get the length and process the data. Once complete, it will call ZbZclTunnelStateGetDataLen with clear_data set to true. |
Return
- Length of data in the buffer
ZbZclTunnelStateGetDataPtr
uint8_t * ZbZclTunnelStateGetDataPtr(struct ZbZclTunnelStateT *state);
Get received data using Tunneling Cluster State structure
Parameters
Return
- Pointer to received data buffer. Length of data is determined by ZbZclTunnelStateGetDataLen.
ZbZclTunnelStateGetId
uint16_t ZbZclTunnelStateGetId(struct ZbZclTunnelStateT *state);
Get ID using Tunneling Cluster State structure
Parameters
Return
- Allocated tunnel ID
ZbZclTunnelStateGetMtu
uint16_t ZbZclTunnelStateGetMtu(struct ZbZclTunnelStateT *state);
Get the current tunnel’s MTU, which is the smaller of the two side’s MTUs.
Parameters
Return
- MTU size in bytes
ZbZclTunnelStateGetProtocol
enum ZbZclTunnelProtocolT ZbZclTunnelStateGetProtocol(struct ZbZclTunnelStateT *state);
Get Tunneling Protocol Instance using Tunneling Cluster State structure
Parameters
Return
- Tunneling Protocol Instance structure
ZbZclTunnelStateGetRmtAddr
bool ZbZclTunnelStateGetRmtAddr(struct ZbZclTunnelStateT *state, uint64_t *addr, uint8_t *endpoint);
Get the current tunnel’s remote addressing.
Parameters
| addr | Pointer to write EUI-64 of the remote device’s address. |
| endpoint | Pointer to write EUI-64 of the remote device’s endpoint. |
Return
- True if address info is present and valid, false otherwise.
Enumerations
Tunneling Protocol ID enumerations
| ZCL_TUNNEL_PROTO_DLMS_COSEM | DLMS/COSEM (IEC 62056) |
| ZCL_TUNNEL_PROTO_IEC_61107 | IEC 61107 |
| ZCL_TUNNEL_PROTO_ANSI_C12 | ANSI C12 |
| ZCL_TUNNEL_PROTO_M_BUS | M-BUS |
| ZCL_TUNNEL_PROTO_SML | SML |
| ZCL_TUNNEL_PROTO_CLIMATE_TALK | ClimateTalk |
| ZCL_TUNNEL_PROTO_GB_HRGP | GB-HRGP |
| ZCL_TUNNEL_PROTO_IPV4 | IP v4 |
| ZCL_TUNNEL_PROTO_IPV6 | IP v6 |
| ZCL_TUNNEL_PROTO_MANUF_MIN | Start of manufacturer specific protocols. For values greater than or equal to this value, the Protocol Id and Manufacturer Code must match. |
| ZCL_TUNNEL_PROTO_RESERVED | Reserved |
ZbZclTunnelStatusT
Tunneling Status Values
| ZCL_TUNNEL_STATUS_SUCCESS | Success |
| ZCL_TUNNEL_STATUS_BUSY | Busy |
| ZCL_TUNNEL_STATUS_NO_RESOURCES | No more tunnel IDs |
| ZCL_TUNNEL_STATUS_PROTO_UNSUPPORTED | Protocol not supported |
| ZCL_TUNNEL_STATUS_FLOW_UNSUPPORTED | Flow control not supported |
ZbZclTunnelSvrAttrT
Tunneling Server Attribute IDs
| ZCL_TUNNEL_SVR_ATTR_TIMEOUT | CloseTunnelTimeout |
| ZCL_TUNNEL_SVR_ATTR_NUM_TUNNELS | This is an internal attribute that can be used by the application to set the number of tunnels that tunnel server shall support. After this, the server shall return NO_RESOURCES error for any request to create the tunnel. by default it is set to ZCL_TUNNEL_SVR_NUM_TUNNELS_MAX. |
| ZCL_TUNNEL_SVR_ATTR_PERSIST | This is an internal attribute used to read/write the tunnel data from/to tunnel server. |
ZbZclTunnelXferStatusT
Tunneling Transfer Data Status Values
| ZCL_TUNNEL_XFER_STATUS_NO_TUNNEL | No such tunnel |
| ZCL_TUNNEL_XFER_STATUS_WRONG_DEVICE | Wrong device |
| ZCL_TUNNEL_XFER_STATUS_OVERFLOW | Data overflow |
| ZCL_TUNNEL_XFER_STATUS_NO_RESPONSE | No Response - If zcl_tunnel_handle_data returns ZCL_TUNNEL_XFER_STATUS_NO_RESPONSE, don’t send a response |
Structures
ZbZclTunnelCloseT
Parameters
| uint8_t mirror_ep | ESI Mirror endpoint to send Tunnel data in case the destination is BOMD and to_bomd flag is set to 'true'. |
ZbZclTunnelConnectT
Request Tunnel command structure
Parameters
ZbZclTunnelDataT
Tunnel Data command structure
Parameters
| uint8_t *data | Pointer to the data being sent over the Tunnel. |
| uint16_t len | Data length. |
Get Supported Protocols command structure
Parameters
| uint8_t protocol_offset | Protocol offset |
ZbZclTunnelProtoCbT
ZbZclTunnelServerAddProto and ZbZclTunnelClientAddProto callback data structure
Parameters
| request
enum ZbZclTunnelStatusT (*request)(struct ZbZclClusterT *clusterPtr, struct ZbZclTunnelStateT *statePtr, void *priv)
Callback to handle a Request Tunnel (ZCL_TUNNEL_CLI_CMD_REQUEST) command. The callback returns a tunnel state structure, which is used to identify the tunnel to the server cluster. It is an opaque structure, meaning the application does not have access to the internals, but the application can call functions such as ZbZclTunnelStateGetId to get the tunnel Id from the state. |
| input
void (*input)(struct ZbZclClusterT *clusterPtr, struct ZbZclTunnelStateT *statePtr, void *priv)
Callback to handle received data from the tunnel (ZCL_TUNNEL_CLI_CMD_DATA). The application uses the ZbZclTunnelStateGetDataPtr and ZbZclTunnelStateGetDataLen to get the current received data queued in the tunnel cluster. |
| close
void (*close)(struct ZbZclClusterT *clusterPtr, struct ZbZclTunnelStateT *statePtr, void *priv)
Callback to handle a Close Tunnel command, to close the tunnel (Optional). |
| error
bool (*error)(struct ZbZclClusterT *clusterPtr, struct ZbZclTunnelStateT *statePtr, void *priv, enum ZbZclTunnelXferStatusT status)
Callback to handle an Error command (ZCL_TUNNEL_SVR_CMD_ERROR) (Optional). Return false if tunnel should also be closed. Return true to keep tunnel open and continue normally. |
| void *priv | Application private data pointer |
