1. Introduction
The transparent mode or DTM (direct test mode) application is used to:
- receive commands on UART RX and propagate them to the Bluetooth® Low Energy stack.
- transmit events from Bluetooth®Low Energy stack on UART TX.
A set of commands/events are sent though the STM32WB0 UART to control the Bluetooth® Low Energy stack via the transparent mode application.
Level shifter, VCP ST-LINK or applicative VCP can be used to manage transmission and reception.
| Transparent mode with STM32WB0 Nucleo boards and ST-LINK VCP |
2. Requirements
2.1. Software and Hardware requirements
For software and hardware requirements refer to STM32WB0 Build BLE Project wiki page.
3. Transparent mode example description
3.1. Project directory
The "BLE_TransparentMode" and "BLE_TransparentMode_C_O" applications are available by downloading the STM32CubeWB0 MCU Package[1].
Refer to the How to Build a Bluetooth® LE project wiki page for information on the project directory.
3.2. Project description
3.2.1. Bluetooth® Low Energy host stack
The transparent mode application (BLE_TrasparentMode) uses the Bluetooth® LE Host + Controller Stack library (stm32wb0x_ble_stack.a). It also requires libcrypto.a binary library to work.
This configuration supports all the available ACI and HCI commands, as well as Bluetooth® Low Energy features.
There is also a variant of the transparent mode application (BLE_TrasparentMode_C_O) which uses the Bluetooth® LE Controller Only Stack library (stm32wb0x_ble_stack_controller_only.a).
This configuration supports all the available HCI commands.
For further information on the Bluetooth® Low Energy host stack library and the different Bluetooth® Low Energy stack configurations for STM32WB0 projects, refer to Bluetooth® Low Energy stack v4.x programming guidelines
3.2.2. Software project structure
Find below the software project structure and its main parts:
| Transparent mode project structure | |
| BLE_TrasparentMode | BLE_TrasparentMode_C_O |
| WARNING: Do not modify the files in the Middlewares folder | |
3.2.3. Application initialization
Find below the different steps of the application initialization:
| Transparent mode project initialization |
3.3. Build and install
Follow the steps described in Bluetooth® LE Build and Install Application page, and apply them to the STM32WB0 BLE_TransparentMode project.
3.4. How to use the Bluetooth® Low Energy transparent mode application
Once the Bluetooth® Low Energy transparent mode application is installed on the STM32WB0 platform, launch the STM32CubeMonitor-RF [2] application on the computer connected to the platform via USB.
3.4.1. STM32CubeMonitor-RF interface
From the STM32CubeMonitor-RF interface, select the COM port of the STM32WB0 Nucleo board, and click the CONNECT button:
| STM32CubeMonitor-RF connection with transparent mode |
Information on the platform and software is available under HCI_READ_LOCAL_VERSION_INFORMATION and ACI_HAL_GET_FIRMWARE_DETAILS:
| STM32CubeMonitor-RF device information |
ACI utilities allows the user to easily launch an advertising or a scan sequence:
| STM32CubeMonitor-RF advertising and scan sequences |
3.4.2. Vendor-specific commands
Vendor-specific commands have been developed to read the device information, and read/write registers from the command interface:
- ACI_HAL_GET_FIRMWARE_DETAILS
| Transparent mode vendor-specific commands | ||||
| Command name | HCI packet indicator | OCF | Description | Parameter |
| ACI_HAL_GET_FIRMWARE_DETAILS | 0x01 | 0xFC01 | Return BLE_TransparentMode/DTM version & variant; Return Bluetooth LE stack version & variant. |
N/A |
| ACI_HAL_GET_FIRMWARE_DETAILS returned values |
4. References
