1. Health Thermometer Profile
Health Thermometer Profile (HTP) [1] is a Generic Attribute Profile (GATT) based low-energy profile defined by the Bluetooth® Special Interest Group.[2]
Health Thermometer Profile is a combination of a Health Thermometer Collector and a Health Thermometer Sensor to connect and exchange data in different applications.
The Health Thermometer Sensor:
- Measures the temperature and exposes it via the Health Thermometer Service[3]
- Contains the Device Information Service to be identified by the remote device
- Is the GATT server
The Health Thermometer Collector:
- Accesses the information exposed by the Health Thermometer Sensor and can for example display it to the end user or store it on nonvolatile memory for later analysis.
- Is the GATT client
This wiki page is the description of the Health Thermometer Sensor project provided within the:
- STM32CubeWB0 MCU Package[4]
The table below describes the structure of Health Thermometer Sensor services:
Bluetooth® LE Health Thermometer Service specification | ||||||||||||||||||||||||||||||||||||||||||||||||||
Health Thermometer is exported as a Service:
- Temperature Measurement characteristic (TEMM):
- Sends a temperature measurement, and updates related flags.
- Temperature Type characteristic (MNBS):
- One of two methods used to describe the type of temperature measurement in relation to the location on the human body where the temperature was measured.
- Intermediate Temperature characteristic (INT):
- Sends intermediate temperature values to a device for display purposes while the measurement is in progress.
- Measurement Interval characteristic (MEI):
- Enables and controls the interval between consecutive temperature measurements.
Device Information (DIS) is exported as a Service:
- Manufacturer Name String characteristic (MANS):
- Name of the manufacturer of the device.
- Model Number String characteristic (MONS):
- Model number assigned by the device vendor.
- System ID characteristic (SYID):
- Structure containing an Organizationally Unique Identifier (OUI) followed by a manufacturer-defined identifier and is unique for each individual instance of the product.
1.1. Advertising data
At start up, the Health Thermometer application starts advertising with an interval of approximatively 80-100ms.
Data advertised are composed as follows:
HealthThermometer Advertising packet | ||||||||||||||||||||
The Manufacturer data are encoded following the STMicroelectronics BlueST-SDK v2 for STM32WB0 as described below:
STMicroelectronics Manufacturer Advertising data | |||||||||||||||||||||||||||||||||
2. Requirements
2.1. Software and Hardware requirements
For software and hardware requirements, refer to the STM32WB0 Build BLE Project wiki page.
2.2. Compatible collector applications
The STM32CubeWB0 Health Thermometer Sensor project is compatible with the following collectors:
3. STM32WB0 Health Thermometer Sensor example description
3.1. Project directory
The "BLE_HealthThermometer" application is available by downloading STM32CubeWB0 MCU Package[4].
Refer to the How to Build a Bluetooth® LE project wiki page for project directory information.
3.2. Project description
3.2.1. Structure
Software project structure illustrating the most important parts:
3.2.2. Application initialization
The different steps of the application initialization are described below:
3.2.3. GAP and GATT initialization and interaction
and The Bluetooth® Low Energy Health Thermometer application initialization is done within app_ble.c
- Initialize the Bluetooth® Low Energy stack - initialize the device as peripheral - configure and start advertising: ADV parameters, local name, UUID - APP_BLE_init()
- Call the services controller initialization BLEEVT_Init() - ble_evt.c.
- Manage the GAP event - BLEEVT_App_Notification()
- HCI_LE_CONNECTION_COMPLETE_SUBEVT_CODE- provides information of the connection interval, slave latency, supervision timeout
- HCI_LE_CONNECTION_UPDATE_COMPLETE_SUBEVT_CODE- provides the new information of the connection
- HCI_DISCONNECTION_COMPLETE_EVT_CODE- informs the application about the link disconnection and the reason
Event management is done by the Bluetoooth® Low Energy Event Dispatcher, ble_evt.c.
- Initialize the number of registered handler - BLEEVT_Init()
- Manage events - BLE_STACK_Event() - from the Bluetooth® Low Energy Host Stack and redirect them to the event handler - BLEEVT_App_Notification
The application level of the Health Thermometer is done with hts_app.c:
- Initialization of the services:
- Health Thermometer Service - HTS_APP_Init() -> HTS_Init() in hts.c
- Initialization of the context of the application
- Receive notification from the Health Thermometer Service - HTS_Notification()
- When temperature measurement characteristics are enabled by remote, simulate the temperature measurement every second (HTS_APP_Measurement) and increase the energy expended to transfer to the remote device (collector) - HTS_UpdateValue()
The Health Thermometer Service hts.c manages the specification of the service:
- Service Init - HTS_Init()
- Register Health Thermometer Event Handle to Service Controller - BLEEVT_RegisterGattEvtHandler(HTS_EventHandler).
- Initialize Service UUID – add Health Thermometer service as Primary services
- Initialize Temperature measurement (TEMM) characteristic
- Initialize Temperature Type (MNBS) characteristic
- Initialize Intermediate Temperature (INT) characteristic
- Initialize Measurement Interval (MEI) characteristic
- Manage the GATT event from Bluetooth® Low Energy Stack - HTS_EventHandler()
- ACI_GATT_SRV_WRITE_VSEVT_CODE
- Reception of a Write Command: Measurement Interval Characterictic Value
- Send an aci_gatt_srv_resp() with an OK or KO status.
- ACI_GATT_SRV_ATTRIBUTE_MODIFIED_VSEVT_CODE
- Reception of an attribute modification - Temperature Measurement Value: ENABLE or DISABLE Indication
- Notify application of the Measurement Notification:
notification.EvtOpcode = HTS_TEMM_INDICATE_ENABLED_EVT/HTS_TEMM_INDICATE_DISABLED_EVT; HTS_Notification(¬ification);
- Reception of an attribute modification - Intermediate Temperature Value : ENABLE or DISABLE Notification
notification.EvtOpcode = HTS_INT_NOTIFY_ENABLED/HTS_INT_NOTIFY_DISABLED_EVT; HTS_Notification(¬ification);
- Reception of an attribute modification - Measurement Interval Value : ENABLE or DISABLE Indication
notification.EvtOpcode = HTS_MEI_INDICATE_ENABLED_EVT/HTS_MEI_INDICATE_DISABLED_EVT; HTS_Notification(¬ification);
3.3. How to use the Bluetooth® Low Energy Health Thermometer application
Once the Bluetooth® Low Energy Health Thermometer application is installed on the STM32WB0 platform, launch the ST BLE ToolBox smartphone application.
Then, scan and connect the device called HT_XX (where XX is replaced by the last byte of the BD address) to the application.
Once the Bluetooth® LE connection is established and the notification enabled by the smartphone (by clicking on Health Thermometer icon):
- Intermediate temperature notification is provided to remote every 1 s.
- Temperature measurement indication is provided to remote every 10 s.
3.4. UART debug trace
Thanks to the debug log via UART interface , it is possible to trace the application project.
To enable the traces within the project, enable them within app_conf.h as described below:
* Enable or Disable traces in application
#define CFG_DEBUG_APP_TRACE (1)
Health Thermometer - Initialization phase | Connected Phase |
==>> Start BLE_Init function Success: aci_hal_set_tx_power_level command Success: aci_gatt_srv_profile_init command Success: aci_gap_init command Static Random Bluetooth Address: db:79:9e:4a:b8:6c Success: Gap_profile_set_dev_name - Device Name Success: Gap_profile_set_appearance - Appearance Success: hci_le_set_default_phy command Success: aci_gap_set_io_capability command Success: aci_gap_set_security_requirements command Success: aci_gap_configure_filter_accept_and_resolving_list command ==>> End BLE_Init function Services and Characteristics creation Success: aci_gatt_srv_add_service command: DIS Success: aci_gatt_srv_add_service command: HTS End of Services and Characteristics creation ==>> Success: aci_gap_set_advertising_configuration ==>> Success: aci_gap_set_advertising_data ==>> Success: aci_gap_set_advertising_enable |
>>== hci_le_connection_complete_event - Connection handle: 0x0801 - Connection established with @:4f:ad:b2:b0:04:3a - Connection Interval: 45.00 ms - Connection latency: 0 - Supervision Timeout: 5000 ms >>== HCI_LE_CONNECTION_UPDATE_COMPLETE_SUBEVT_CODE - Connection Interval: 7.50 ms - Connection latency: 0 - Supervision Timeout: 5000 ms HCI_VENDOR_EVT: 0x0C03 >>== HCI_LE_CONNECTION_UPDATE_COMPLETE_SUBEVT_CODE - Connection Interval: 45.00 ms - Connection latency: 0 - Supervision Timeout: 5000 ms HCI_LE_META_EVT: 0x08 >>== ACI_GAP_NUMERIC_COMPARISON_VALUE_VSEVT_CODE - numeric_value = 801598 - Hex_value = c3b3e ==>> aci_gap_numeric_comparison_value_confirm_yesno : Success HCI_LE_META_EVT: 0x09 HCI_EVENT: 0x08 >>== ACI_GAP_PAIRING_COMPLETE_VSEVT_CODE - Pairing Success HCI_VENDOR_EVT: 0x0C01 ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE HTS_TEMM_INDICATE_ENABLED_EVT ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE HTS_INT_NOTIFY_ENABLED_EVT HTS_INT_NOTIFY_ENABLED_EVT HTS_MEI_INDICATE_ENABLED_EVT |
4. References
Bluetooth® Low Energy stack v4.x Programming Guidelines (PM0274)
