This article provides performance results for a set of well-known or reference pre-trained Neural Network models.
Performance metrics verified by the MLCommons association have been published in the MLPerf™ Tiny v1.1 benchmark. Below are additional performance metrics measured by STMicroelectronics, which have not been verified by MLCommons [ST 1].
1. Performance results
1.1. STM32N6x7
The STM32N6x7 is a high performance MCU embedding an Arm Cortex®-M55 core together with a the Neural-ART Accelerator™ Neural Processing Unit (NPU) of 600 GOPS and 3 TOPS/W power consumption. STM32N6 has 4.2 MByte of embedded RAM.
The following measures are done on the STM32N657 Discovery kit with STM32Cube.AI 10.0.1 delivered in ST Edge AI Core v2.0 and with STM32CubeIDE 1.15.0.
- The Yolov8n and TinyYolov2 models are object detection models trained to recognized persons. The models are quantized in int8 per-channel using TensorFlow™ Lite converter.
- The MobileNet v2 1.0 model is an image classification models trained on ImageNet and quantized in int8 per-channel using TensorFlow™ Lite converter.
- The Yamnet 1024 model is an audio event detector trained on esc-10 dataset quantized in int8 per-channel using ONNX Runtime.
The performance table fields and measurement process are detailed in the section Measurement process for the STM32N6.
In nominal mode (VOS low) the settings used are the following ones: Cortex®-M55 configured at 600 MHz, Neural-ART Accelerator configured at 800 MHz, NPU RAMS (AXISRAM 3/4/5/6) access at 800 MHz, CPU RAM (AXISRAM 1/2) access at 400 MHz, VDDCORE set to 0.81 V, and VDDIO set to 1.8 V.
| Model Source\Link |
Flash Weights (Mbyte) |
RAM Activations (Mbyte) |
Proc Time (ms) |
inf/s | Total energy (mJ) |
Total average power (mW) |
VDDCORE (mJ) |
VDDCORE (mW) |
VDDA1V8 (mJ) |
VDDA1V8 (mW) |
External memories (mJ) |
External memories (mW) |
| Yolov8n 256x256x3 [1] |
2.91 MB | 1.59 MB | 35.6 ms | 28 | 8 mJ | 225 mW | 6.4 mJ | 177 mW | 0.26 mJ | 7.3 mW | 1.4 mJ | 40 mW |
| Yolov8n 320x320x3 [2] |
2.91 MB | 2.12 MB | 47.1 ms | 21 | 11 mJ | 232 mW | 9 mJ | 191 mW | 0.32 mJ | 6.75 mW | 1.6 mJ | 34 mW |
| TinyYolov2 224x224x3 [3] |
10.55 MB | 0.38 MB | 31.4 ms | 40 | 10.8 mJ | 343 mW | 6 mJ | 188 mW | 0.5 mJ | 16 mW | 4.34 mJ | 138 mW |
| MobileNet v2 1.0 224x224x3 [4] |
4.13 MB | 2.01 MB | 23.2 ms | 43 | 6 mJ | 257 mW | 3.85 mJ | 166 mW | 0.25 mJ | 10.8 mW | 1.86 mJ | 80 mW |
| Yamnet 1024 64x96 [5] |
3.41 MB | 0.14 MB | 9.9 ms | 101 | 2.72 mJ | 275 mW | 1.23 mJ | 124 mW | 0.16 mJ | 16 mW | 1.34 mJ | 135 mW |
In performance mode (VOS high) the settings used are the following ines: the Cortex®-M55 configured at 800 MHz, Neural-ART Accelerator configured at 1 GHz, NPU RAMS (AXISRAM 3/4/5/6) access at 900 MHz, RAM (AXISRAM 1/2) access at 400 MHz, VDDCORE set to 0.89 V, and VDDIO set to 1.8 V.
| Model Source\Link |
Proc Time (ms) |
inf/s | Energy (mJ) |
Average Power (mW) |
VDDCORE (mJ) |
VDDCORE (mW) |
VDDA1V8 (mJ) |
VDDA1V8 (mW) |
| Yolov8n 256x256x3 [6] |
2.91 MB | 1.587 MB | 29.1 ms | 34 | 9.4 mJ | 322 mW | 7.8 mJ | 267 mW | 0.26 mJ | 9 mW | 1.34 mJ | 46 mW |
| Yolov8n 320x320x3 [7] |
2.91 MB | 2.12 MB | 38.7 ms | 26 | 12.85 mJ | 332 mW | 11 mJ | 285 mW | 0.32 mJ | 8.36 mW | 1.5 mJ | 39 mW |
| TinyYolov2 224x224x3 [8] |
10.55 MB | 0.38 MB | 30.6 ms | 33 | 12.8 mJ | 417 mW | 8 mJ | 259 mW | 0.52 mJ | 17 mW | 4.32 mJ | 141 mW |
| MobileNet v2 1.0 224x224x3 [9] |
4.13 MB | 2.01 MB | 20.7 ms | 48 | 7 mJ | 337 mW | 4.88 mJ | 236 mW | 0.26 mJ | 12.6 mW | 1.82 mJ | 88 mW |
| Yamnet 1024 64x96 [10] |
3.41 MB | 0.14 MB | 9.7 ms | 103 | 3.2 mJ | 332 mW | 1.7 mJ | 176 mW | 0.17 mJ | 17 mW | 1.34 mJ | 138 mW |
1.2. STM32 High Performance MCUs
STM32 High Performance MCUs at 3.3 V: inference time, memory footprint and energy reported in milli Joules (mJ):
| STM32 Board | STM32 characteristics |
Model Source\Link |
Flash total (Kbyte) |
RAM total (Kbyte) |
Proc Time (ms) |
Cur. (mA) |
Energy (mJ) 3.3 V |
Version |
| STM32H735 SMPS STM32H735G-DK |
Flash 1 Mbyte RAM 564 Kbytes (432) Freq 550 MHz |
FDMobileNet 0.25 224x224x3 quant tfl [11] |
185 Kbytes | 166 Kbytes | 38.5 ms | 101 mA | 12.8 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
MobileNet v2 128x128x3 quant tfl [12] |
514 Kbytes | 255 Kbytes | 67.7 ms | 104 mA | 23.2 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Object Detector SSD MobileNet v1 0.25 192x192x3 [13] |
533 Kbytes | 270 Kbytes | 105.8 ms | 103 mA | 36 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Yamnet 256 quant tfl [14] |
187 Kbytes | 117 Kbytes | 50.4 ms | 99 mA | 16.5 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
CNN2D_ST_HandPosture VL53L8CX 8 postures float keras [15] |
25 Kbytes | 3 Kbytes | 0.14 ms | 92 mA | 0.043 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
HAR IGN float keras [16] |
26 Kbytes | 4 Kbytes | 0.38 ms | 92 mA | 0.115 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Anomaly Detection MLPerf™Tiny quant tfl [17] |
277 Kbytes | 6.39 Kbytes | 0.667 ms | 95 mA | 0.209 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Key Word Spotting MLPerf™Tiny quant tfl [18] |
65 Kbytes | 24 Kbytes | 8.16 ms | 96 mA | 2.59 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Image Classif MLPerf™Tiny quant tfl [19] |
127 Kbytes | 49 Kbytes | 21.7 ms | 96 mA | 6.9 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Visual Wake Word MLPerf™Tiny quant tfl [20] |
96 Kbytes | 56 Kbytes | 14.54 ms | 96 mA | 4.6 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| STM32H747 SMPS STM32H747I-DISCO |
Cortex®-M7 Flash 2 Mbytes RAM 1 Mbyte (0.5) Freq 400 MHz(1) |
FDMobileNet 0.25 224x224x3 quant tfl [21] |
185 Kbytes | 166 Kbytes | 53.8 ms | 63 mA | 11.2 mJ | STM32Cube.AI 8.1.0 STM32CubeIDE 1.12.1 |
MobileNet v2 128x128x3 quant tfl [22] |
514 Kbytes | 255 Kbytes | 94.9 ms | 65 mA | 20.4 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Object Detector SSD MobileNet v1 0.25 192x192x3 [23] |
533 Kbytes | 270 Kbytes | 149.5 ms | 64 mA | 31.6 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Yamnet 256 quant tfl [24] |
187 Kbytes | 117 Kbytes | 77.3 ms | 64 mA | 16.3 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
CNN2D_ST_HandPosture VL53L8CX 8 postures float keras [25] |
25 Kbytes | 3 Kbytes | 0.2 ms | 62 mA | 0.041 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
HAR IGN float keras [26] |
26 Kbytes | 4 Kbytes | 0.53 ms | 59 mA | 0.103 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Anomaly Detection MLPerf™Tiny quant tfl [27] |
277 Kbytes | 6.39 Kbytes | 1.08 ms | 63 mA | 0.193 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Key Word Spotting MLPerf™Tiny quant tfl [28] |
65 Kbytes | 24 Kbytes | 11.44 ms | 64 mA | 2.4 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Image Classif MLPerf™Tiny quant tfl [29] |
127 Kbytes | 49 Kbytes | 33 ms | 64 mA | 6.4 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Visual Wake Word MLPerf™Tiny quant tfl [30] |
96 Kbytes | 56 Kbytes | 20.7 ms | 64 mA | 4.4 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| STM32H7A3 SMPS NUCLEO-H7A3ZI-Q |
Flash 2 Mbytes RAM 1.4 Mbyte (1.18) Freq 280 MHz |
FDMobileNet 0.25 224x224x3 quant tfl [31] |
185 Kbytes | 166 Kbytes | 76 ms | 43 mA | 10.8 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
MobileNet v2 128x128x3 quant tfl [32] |
514 Kbytes | 255 Kbytes | 132 ms | 44 mA | 19.2 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Object Detector SSD MobileNet v1 0.25 192x192x3 [33] |
533 Kbytes | 270 Kbytes | 208 ms | 44 mA | 30.2 mJ | STM32Cube.AI 8.1.0 STM32CubeIDE 1.12.1 |
Yamnet 256 quant tfl [34] |
187 Kbytes | 117 Kbytes | 105 ms | 45 mA | 15.6 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
CNN2D_ST_HandPosture VL53L8CX 8 postures float keras [35] |
25 Kbytes | 3 Kbytes | 0.29 ms | 41 mA | 0.039 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
HAR IGN float keras [36] |
26 Kbytes | 4 Kbytes | 0.76 ms | 40 mA | 0.1 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Anomaly Detection MLPerf™Tiny quant tfl [37] |
277 Kbytes | 6.39 Kbytes | 1.24 ms | 44 mA | 0.184 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Key Word Spotting MLPerf™Tiny quant tfl [38] |
65 Kbytes | 24 Kbytes | 16.3 ms | 44 mA | 2.4 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Image Classif MLPerf™Tiny quant tfl [39] |
127 Kbytes | 49 Kbytes | 43 ms | 44 mA | 6.2 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.1 |
Visual Wake Word MLPerf™Tiny quant tfl [40] |
96 Kbytes | 56 Kbytes | 29.3 ms | 44 mA | 4.3 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
(1) On Cortex®-M7 core in SMPS mode 400 MHz instead of 480 max in LDO. The Cortex®-M4 is running on a while(1) infinite loop.
For a given STM32 in a fixed configuration, the current consumption is in the same range regardless of the model. it might however vary depending on the complexity and topology of the model. The following table is providing the average current consumption of the model listed in the table above table (excluding the Anomaly Detection model which has a specific topology). These data can be used as a first estimation of the current consumption and the energy consumption of a new model from just the measurement of its inference time. From the average inference time of t second and the average current of i Ampere for a given input voltage of u Volt. The average energy is easily computed as (t x i x u) in Joule.
| STM32 Board | STM32H735 550 MHz SMPS |
STM32H747 400 MHz SMPS |
STM32H7A3 280 MHz SMPS |
| Average current (mA) |
98 | 63 | 43 |
STM32Cube.AI (X-CUBE-AI) can also generate a TensorFlow™ Lite for Microcontroller (TFLm) runtime implementation (based on TensorFlow™ version 2.10 sha-1 = 79f6defor STM32Cube.AI v8.1.0). The following table is comparing the TFLm runtime to the X-CUBE-AI runtime, the Flash and RAM footprints include the code / runtime footprint on top of the weights and activation buffer.
Model Source/Link |
Runtime | Flash (Kbyte) |
RAM (Kbyte) |
Proc Time (ms) |
Version |
Image Classif MLPerf™Tiny [41] |
X-CUBE-AI | 127 Kbytes | 49 Kbytes | 43 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| TFLm | 160 Kbytes | 55 Kbytes | 98 ms | TFLm sha-1 = 79f6de STM32CubeIDE 1.12.1 | |||
| Visual Wake Word MLPerf™Tiny [42] |
X-CUBE-AI | 96 Kbytes | 56 Kbytes | 29.3 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 | ||
| TFLm | 392 Kbytes | 101 Kbytes | 67 ms | TFLm sha-1 = 79f6de STM32CubeIDE 1.12.1 |
1.3. STM32 Ultra Low Power MCUs
STM32 Ultra Low Power MCUs at 1.8 V: inference time, memory footprint and energy reported in micro Joules (uJ):
Model Source/Link |
Flash Total. (Kbyte) |
RAM Total. (Kbyte) |
Proc Time (ms) |
Cur. (mA) |
Energy (uJ) 1.8 V |
Version |
| STM32U575 SMPS NUCLEO-U575ZI-Q |
Flash 2 Mbytes RAM 786 Kbytes Freq 160 MHz |
FDMobileNet 0.25 224x224x3 quant tfl [43] |
186 Kbytes | 166 Kbytes | 188 ms | 13.8 mA | 4670 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
MobileNet v2 128x128x3 quant tfl [44] |
516 Kbytes | 255 Kbytes | 345 ms | 14.2 mA | 8818 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Object Detector SSD MobileNet v1 0.25 192x192x3 [45] |
534 Kbytes | 270 Kbytes | 549 ms | 14.1 mA | 13934 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Yamnet 256 quant tfl [46] |
190 Kbytes | 117 Kbytes | 282 ms | 14.1 mA | 7157 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
CNN2D_ST_HandPosture VL53L8CX 8 postures float keras [47] |
24.4 Kbytes | 3.2 Kbytes | 0.67 ms | 14.2 mA | 17 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
HAR IGN float keras [48] |
25 Kbytes | 4 Kbytes | 2.25 ms | 12.4 mA | 50 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Anomaly Detection MLPerf™Tiny quant tfl [49] |
278 Kbytes | 6.39 Kbytes | 3.47 ms | 13.6 mA | 85 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Key Word Spotting MLPerf™Tiny] quant tfl [50] |
67 Kbytes | 24 Kbytes | 44.9 ms | 13.7 mA | 1107 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Image Classif MLPerf™Tiny quant tfl [51] |
129 Kbytes | 49 Kbytes | 116 ms | 14 mA | 2923 mJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Visual Wake Word MLPerf™Tiny quant tfl [52] |
98 Kbytes | 56 Kbytes | 74 ms | 14.1 mA | 1878 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| STM32L4R5 LDO NUCLEO-L4R5ZI |
Flash 2 Mbytes RAM 640 Kbytes Freq 120 MHz |
FDMobileNet 0.25 224x224x3 quant tfl [53] |
186 Kbytes | 166 Kbytes | 291 ms | 23.2 mA | 12152 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
MobileNet v2 128x128x3 quant tfl [54] |
516 Kbytes | 255 Kbytes | 545 ms | 23.2 mA | 22759 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Object Detector SSD MobileNet v1 0.25 192x192x3 [55] |
534 Kbytes | 270 Kbytes | 851 ms | 23.3 mA | 35691 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Yamnet 256 quant tfl [56] |
190 Kbytes | 117 Kbytes | 426 ms | 23.6 mA | 18096 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
CNN2D_ST_HandPosture VL53L8CX 8 postures [57] |
24.5 Kbytes | 3.2 Kbytes | 1.14 ms | 23.1 mA | 47 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
HAR IGN float [58] |
25 Kbytes | 4 Kbytes | 3.5 ms | 21.9 mA | 137 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Anomaly Detection MLPerf™Tiny quant tfl [59] |
278 Kbytes | 6.39 Kbytes | 5.33 ms | 21.8 mA | 209 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Key Word Spotting MLPerf™Tiny quant tfl [60] |
67 Kbytes | 24 Kbytes | 71.2 ms | 22.9 mA | 2937 uJ | STM32Cube.AI 8.1.0 STM32CubeIDE 1.12.1 |
Image Classif MLPerf™Tiny quant tfl [61] |
129 Kbytes | 49 Kbytes | 179 ms | 23.3 mA | 7507 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Visual Wake Word MLPerf™Tiny quant tfl [62] |
98 Kbytes | 56 Kbytes | 119.5 ms | 23.3 mA | 5012 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| STM32G474 LDO NUCLEO-G474REI |
Flash 512 Mbytes RAM 128 Kbytes Freq 170 MHz |
Anomaly Detection MLPerf™Tiny quant tfl [63] |
278 Kbytes | 6.39 Kbytes | 4.06 ms | 32 mA | 429 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Key Word Spotting MLPerf™Tiny quant tfl [64] |
67 Kbytes | 24 Kbytes | 65.6 ms | 35 mA | 7578 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Image Classif MLPerf™Tiny quant tfl [65] |
129 Kbytes | 49 Kbytes | 126.8 ms | 35 mA | 14645 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
Visual Wake Word MLPerf™Tiny quant tfl [66] |
98 Kbytes | 56 Kbytes | 84.88 ms | 34 mA | 9524 uJ | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| STM32 Board | STM32U575 160 MHz SMPS |
STM32L4R5 120 MHz LDO Single Bank |
STM32G474 170 MHz LDO |
14 | 23 | 34 |
STM32Cube.AI (X-CUBE-AI) can also generate a TensorFlow™ Lite for Microcontroller (TFLm) runtime implementation (based on TensorFlow™ version 2.10 sha-1 = 79f6de for STM32Cube.AI v8.1.0). The following table is comparing the TFLm runtime to the X-CUBE-AI runtime, the Flash and RAM footprints include the code / runtime footprint on top of the weights and activation buffer.
Model Source/Link |
RAM (Kbyte) |
Proc Time (ms) |
Version |
Image Classif MLPerf™Tiny [67] |
X-CUBE-AI | 129 Kbytes | 49 Kbytes | 116 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| TFLm | 161 Kbytes | 55 Kbytes | 251 ms | TFLm sha-1 = 79f6de STM32CubeIDE 1.12.1 | |||
| Visual Wake Word MLPerf™Tiny [68] |
X-CUBE-AI | 96 Kbytes | 56 Kbytes | 74 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 | ||
| TFLm | 393 Kbytes | 101 Kbytes | 176 ms | TFLm sha-1 = 79f6de STM32CubeIDE 1.12.1 |
2. SMPS vs LDO
Inference time, memory footprint and energy for SMPS and LDO power configuration at 3.3V :
Model Source/Link |
PWR config |
Cur. (mA) |
Energy (uJ) |
Proc Time (ms) |
Version |
| STM32U575 NUCLEO-U575ZI-Q |
Image Classif MLPerf™Tiny [69] |
SMPS | 8.7 | 3330 | 116 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| LDO | 18.1 | 6929 | 116 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 | |||
| Visual Wake Word MLPerf™Tiny [70] |
SMPS | 8.8 | 2149 | 74 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 | ||
| LDO | 18.3 | 4469 | 74 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 | |||
| STM32L4R5ZI-P NUCLEO-L4R5ZI-P |
Image Classif MLPerf™Tiny [71] |
SMPS (external) | 10.2 | 6025 | 179 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
| LDO | 22.8 | 13468 | 179 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 | |||
| Visual Wake Word MLPerf™Tiny [72] |
SMPS (external) | 10.4 | 4101 | 119.5 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 | ||
| LDO | 18.3 | 9188 | 119.5 ms | STM32Cube.AI 9.1.0 STM32CubeIDE 1.16.0 |
3. Measurement process for the STM32N6x7
On this performance only the Machine Learning model inference processing is reported. In a complete application, the sensor acquisition, the data conditioning and pre-processing must also be considered.
The Neural Art compiler options used are -O3 with the epoch controller enabled: --all-buffers-info --no-hw-sw-parallelism --cache-maintenance --enable-virtual-mem-pools --native-float --optimization 3 --Os --Omax-ca-pipe 4 --Ocache-opt --enable-epoch-controller. For the Yamnet onnx model, the stedgeai options --input-data-type int8 --output-data-type float32 --inputs-ch-position chfirst --outputs-ch-position chlast have been used to optimize the input / output format of the end application. The C toolchain is GCC.
The column Model Source/Links indicates the pre-trained ML model and the source, either how it was built / trained or where it can be downloaded.
The column Flash Weights (Mbyte) reports the model weights Flash occupancy stored in external Flash.
The column Activations (Mbyte) reports the model activations as well as input and output buffers RAM occupancy. They are stored in the internal RAM. Note that to input buffer is not counted as it can be generally integrated within the activation buffer using "Use activation buffer for input buffer" and "Use activation buffer for the output buffer" options.
The column Proc Time (ms) reports the model inference processing time.
The column FPS reports the model frame per second.
The column Total energy (mJ) is the total energy spent during an inference of the model on the STM32N6 discovery kit including the external Flash and RAM memories.
The column Total average Power (mW) is the average power consumption during an inference of the model on the STM32N6 discovery kit including the external Flash and RAM memories.
The columns VDDCORE are the energy and power consumption spent through the VDDCORE power supply including VDDCSI, set to 0.81 V for nominal mode and 0.89 V for performance mode.
The columns VDDA1V8 are the energy and power consumption spent through the VDDA1V8 1.8 V power supplies: VDDA18PLL1, VDDA18CSI, VIO2 (Hexa SPI IOs), VDDIO3 (Octo SPI IOs).
The columns External memories are the energy and power consumption spent by the external memories Flash and RAM used on the STM32N6 discovery board. Please refer to the STM32N657 discovery kit user manual for details on the external memories reference.
The application package x-cube-n6-ai-power-measurement provides the mean to measure VDDCORE on the STM32N6 discovery kit. Details are provided in the Readme.md of the package.
4. Measurement process for other STM32
To give developers more control over their applications, ST introduced a new setting in STM32Cube.AI v8.1.0 to define priorities. If users choose the “Time” setting, the algorithm will take more RAM but have faster inference times. On the other hand, choosing “RAM” will have the smallest memory footprint and the slowest times. Finally, the default “Balanced” parameter finds the middle ground between the two approaches, providing a good compromise. For these measurements, the setting "balanced" is used.
The STM32 Board column indicates the STM32 reference and the board used for measurement. By default, the STM32 is configured in maximum performance configuration, so with maximum frequency and especially HCLK / AXI clock at maximal frequency. When a different setting is used it is specified (for instance lower frequency to use a different Voltage Scale or for STM32H7, lower HCLK/AXI frequency). Many STM32 embed a powerful switched-mode power supply (SMPS) that can be used to improve power efficiency when the supply voltage is high enough. When used instead of the integrated low-dropout regulator (LDO), power consumption is optimized by a factor equal to the ratio of the internal VCORE supply voltage to the VDD voltage. The improvement due to the SMPS depends only upon the SMPS efficiency and the VDD voltage. When SMPS is indicated it means that the internal voltage regulator used is the SMPS step-down converter instead of the LDO.
The STM32 Characteristics column provides the available internal Flash size, the full internal RAM size and the frequency. The RAM size includes the different kind of memories and banks, TCM, SRAM etc. For the time being, the buffers used by X-CUBE-AI must be placed in a continuous memory area, the maximal RAM size available in continuous area is provided between "()" if not equal to the full size. The frequency indicated is the operating frequency used for the test, so generally the maximal frequency. The only different case is with the STM32H747 Discovery kit (STM32H747I-DISCO), which is operating by default in SMPS power mode and therefore is limited to 400 MHz instead of 480 MHz. Data are rounded to 3 decimals.
The column Model Source/Links indicates the pre-trained ML model and the source, either how it was built / trained or where it can be downloaded. tfl stands for TensorFlow™ Lite .tflite model , h5 stands for Keras .h5 model, quant for quantized models on 8 bits.
The memory footprints are the one reported by X-CUBE-AI using the "Analyze" function (the version of X-CUBE-AI used is mentioned in the table).
The column Flash reports the Flash occupancy including the model weights, the runtime code generated by X-CUBE-AI to run the neural network and its constants (including the initialized tables).
The column RAM reports the RAM buffers occupancy, used to store the model activations as well as input and output buffers, and the RAM required by the runtime to inference the model. Note that to gain RAM space the "Use activation buffer for input buffer" and "Use activation buffer for the output buffer" options are selected (through X-CUBE-AI Advanced Settings panel).
For X-CUBE-AI runtime, the total Flash and RAM memory footprints are reported after an "Analyze" operation on the main panel by the fields Used Flash and Used RAM. The compiler used is gcc embedded in STM32CubeIDE.
For TensorFlow™ Lite for microcontroller runtime, the Flash and RAM memory footprints related to the runtime/code execution are computed from the memory map of the validation project of the given model built with STM32CubeIDE. The runtime/code part is computed taking into account all the modules used by tflite_micro. The STM32CubeIDE build options for TensorFlow™ Lite for microcontroller are the optimal ones (best compromise between speed and code size), -Ofast for GCC compiler and -Osize for G++ Compiler.
The column Proc Time reports the model inference processing time. When the current / energy is indicated, the measure is obtained through the X-CUBE-AI "System Performance" application following the process described on this WiKi article on power measurement. Otherwise the "Validation on target" application is used. In all cases, when generating the application, the selected clock source is always the HSI, X-CUBE-AI is generating first the optimal clock settings and eventually afterwards the clock is set to HSI. STM32CubeMX then autonomously reconfigures the clock settings.
Cur. and Energy is the current and energy computed following the process described in the WiKi article on power measurement. For STM32 Ultra Low Power microcontrollers, measurement is done with the X-NUCLEO-LPM01A power shield as described in the section 4.3.1 "Measure process when current is below 50 mA". For STM32 High Performance microcontrollers, measurement is done with the Qoitec Otii Arc power analyzer as described in the section 4.3.2 "Measure process when current is above 50 mA". In both cases, a 10 s window is used for averaging) and HSI is selected as the clock source.
Accuracy is not reported. X-CUBE-AI is not modifying the DL/ML model topology. The impact on accuracy should be limited. X-CUBE-AI is providing through the "Validation" application a way to measure the accuracy either on x86 or on the target. It can be used to check the eventual impact on accuracy. When running the "Validation on target" application several metrics are computed, one of them is the X-Cross providing error metrics between the original model executed in Python™ and the C model executed on the target. Random data can be used to compute the RMSE/MAE/L2R errors, however it is recommended to use true data to get the final accuracy. For more details on the metrics, refer to the STEdgeAI-Core documentation.
Note that accuracy check is important to compare a float model with a quantize model or when using the Weight compression feature of X-CUBE-AI for float models.
5. STMicroelectronics references
- ↑ MLPerf™ name and logo are trademarks of MLCommons Association in the United States and other countries. All rights reserved. Unauthorized use strictly prohibited. See www.mlcommons.org for more information.”
- ↑ ST Edge AI Core
- ↑ SLA0104
See also:
