1. Introduction
The Bluetooth® LE Audio Stream Management section regroups
- the Basic Audio Profile (BAP)
- the Audio Stream Control Service (ASCS)
- the Published Audio Capability Service (PACS)
- the Broadcast Audio Scan Service (BASS)
These profile and services are used to configure and establish unicast and broadcast audio streams.
2. Basic Audio Profile (BAP)
The Basic Audio Profile defines roles and procedures to establish audio streams with remote devices. It's specified by the Bluetooth® SIG and the full specification is accessible on their website[1].
2.1. Roles
The BAP introduces 6 roles:
- Unicast client: Establishes connection to the Unicast server, discovers its capabilities, and configures the audio stream. This role is used by a smartphone, a laptop, a television etc.
- Unicast server: Advertises its role, exposes its capabilities, accepts connection from the Unicast client to configure the audio stream. This role can be used by a headphone, a speaker, some hearing aids, some earbuds, or even a microphone.
- Broadcast source: Establishes a Broadcast Isochronous Stream and advertises all the information over extended advertising and periodic advertising.
- Broadcast sink: Scans advertising to find broadcast sources, and gets synchronized to receive audio streams.
- Scan delegator: Exposes its capabilities and waits for a broadcast assistant to receive some information of a broadcast source and commands. The scan delegator also requires the broadcast sink role to synchronize to the selected broadcast source.
- Broadcast assistant: Scans advertising to find broadcast sources, discovers the scan delegator capabilities. It sends the information of broadcast sources to the scan delegator.
2.2. Codec Configuration
To configure audio streams in Broadcast or Unicast mode, the BAP specifies the format of "Codec Specific Configuration". The Codec Specific Configuration is a byte array constituted of multiple Length-Type-Value (LTV) structures to define stream parameters like the Sampling Frequency or the Frame Duration.
| Parameter | Size | Description |
| LENGTH | 1 Byte | Length of the type field + Length of the value field |
| TYPE | 1 Byte | Type of the data: Sampling Frequency (0x01) Frame Duration (0x02) Audio Channel Allocation (0x03) Octets Per Codec Frame (0x04) Codec Frame Block Per SDU (0x05) |
| VALUE | LENGTH - 1 Byte | Value corresponding to the type See Assigned Numbers section 6.12.5[2] |
In Unicast mode, the codec specific configuration is used to configure an audio stream as Unicast Client and its value should be chosen according to the Published Audio Capabilities (see section 4) read on the remote Unicast Server.
In Broadcast mode, the codec specific config is used to configure a Broadcast Source audio stream and is exposed to remote Broadcast Sinks in the BASE structure (see section 2.4.1).
The following table summarize types found in Codec Configuration and common values:
| Type | Mandatory | Values | |
| Sampling Frequency | 0x01 | Yes | 0x01: 8 kHz 0x03: 16 kHz 0x05: 24 kHz 0x06: 32kHz 0x07: 44.1 kHz 0x08: 48kHz |
| Frame Duration | 0x02 | Yes | 0x00: 7.5ms codec frames 0x01: 10ms codec frames |
| Octets Per Codec Frame | 0x04 | Yes | Number of bytes in a frame |
| Audio Channel Allocation | 0x03 | No (absence of value means one channel mono) | 4-bytes bitfield of Audio Location values Bit 0: Front Left Bit 1: Front Right |
| Codec Frame Block Per SDU | 0x05 | No (default 1) | Number of Codec Frame per SDU |
The following table is an example of a codec specific configuration:
| Setting | Length | Type | Value | |||
| Sampling Frequency = 48KHz | 0x02 | 0x01 | 0x08 | |||
| Frame Duration = 10ms | 0x02 | 0x02 | 0x01 | |||
| Audio Channel Allocation = Front Left + Front Right (stereo) | 0x05 | 0x03 | 0x03 | 0x00 | 0x00 | 0x00 |
| Octets Per Codec Frame = 100 octets | 0x03 | 0x04 | 0x64 | 0x00 | ||
2.3. Unicast Roles
The following diagram illustrates the interaction between the different unicast roles:
2.3.1. Unicast Topologies
The BAP specifies 16 different topologies for the Unicast Roles. They define ways of establishing audio stream between one Central device and one or two Peripheral devices. The following table can be found in the BAP Specification and lists the possible topologies:
| Audio Configuration |
Legend C------S |
Num Servers | Sink ASEs | Source ASEs | Audio Channels per Sink ASE |
Min Sink Audio Locations per Server |
Audio Channels per Source ASE |
Min Source Audio Locations per Server |
CISes | Audio Streams |
| 1 | --------> | 1 | 1 | 1 | 1 | 1 | ||||
| 2 | <-------- | 1 | 1 | 1 | 1 | 1 | ||||
| 3 | <-------> | 1 | 1 | 1 | 1 | 1 | 1 | 2 | ||
| 4 | ------->> | 1 | 1 | 2 | 2 | 1 | 1 | |||
| 5 | <----->> | 1 | 1 | 1 | 2 | 1 | 1 | 2 | ||
| 6(i) | --------> --------> |
1 | 2 | 1 | 2 | 2 | 2 | |||
| 6(ii) | --------> <-------- |
2 | 2 | 1 | 1 | 2 | 2 | |||
| 7(i) | --------> <-------- |
1 | 1 | 1 | 1 | 1 | 2 | 2 | ||
| 7(ii) | --------> <-------- |
2 | 1 | 1 | 1 | 1 | 2 | 2 | ||
| 8(i) | --------> <-------> |
1 | 2 | 1 | 1 | 2 | 1 | 2 | 3 | |
| 8(ii) | --------> <-------> |
2 | 2 | 1 | 1 | 1 | 1 | 1 | 2 | 3 |
| 9(i) | <-------- <-------- |
| 9(ii) | <-------- <-------- |
| 10 | <<------- | 1 | 1 | 2 | 2 | 1 | 1 | |||
| 11(i) | <-------> <-------> |
1 | 2 | 2 | 1 | 2 | 1 | 2 | 2 | 4 |
| 11(ii) | <-------> <-------> |
2 | 2 | 2 | 1 | 1 | 1 | 1 | 2 | 4 |
The arrows in the "Legend" column illustrate the CISes (Connected Isochronous Streams) to establish between the devices. One arrow means 1 CIS. The arrow tip indicates the direction of the CIS (unidirectional or bidirectional). When the tip of the arrow is doubled, the CIS transport two channels. Topologies with "(i)" define interactions between 1 Central and 1 Peripheral, whereas topologies with "(ii)" define interactions between one Central and two Peripherals (earbud use-case for example).
For example:
- The configuration 4 defines a unidirectional stereo stream on one CIS to one device, which could be applied to transmit media to a headphone.
- The configuration 11(ii) defines two bidirectional CISes to two peripheral devices, which could be applied for a telephony use-case using earbuds where the two microphones on the earbuds would be used.
2.3.2. Unicast Codec Configurations
The BAP specifies LC3 codec configurations that can be used to establish audio streams between devices in Unicast mode. The following tables can be found in the BAP Specification and list the possible configurations:
Low Latency:
| Set Name | Sampling Frequency (kHz) |
Frame Duration (ms) |
SDU Interval (µs) |
Framing | Maximum SDU Size (Octets) |
RTN | Max Transport Latency (ms) |
Presentation Delay (µs) |
| 8_1_1 | 8 | 7.5 | 7500 | unframed | 26 (27.734 kbps) | 2 | 8 | 40000 |
| 8_2_1 | 8 | 10 | 10000 | unframed | 30 (24 kbps) | 2 | 10 | 40000 |
| 16_1_1 | 16 | 7.5 | 7500 | unframed | 30 (32 kbps) | 2 | 8 | 40000 |
| 16_2_1* | 16 | 10 | 10000 | unframed | 40 (32 kbps) | 2 | 10 | 40000 |
| 24_1_1 | 24 | 7.5 | 7500 | unframed | 45 (48 kbps) | 2 | 8 | 40000 |
| 24_2_1 | 24 | 10 | 10000 | unframed | 60 (48 kbps) | 2 | 10 | 40000 |
| 32_1_1 | 32 | 7.5 | 7500 | unframed | 60 (64 kbps) | 2 | 8 | 40000 |
| 32_2_1 | 32 | 10 | 10000 | unframed | 80 (64 kbps) | 2 | 10 | 40000 |
| 441_1_1 | 44.1 | 8.163 | 8163 | framed | 97 (95.06 kbps) | 5 | 24 | 40000 |
| 441_2_1 | 44.1 | 10.884 | 10884 | framed | 130 (95.55 kbps) | 5 | 31 | 40000 |
| 48_1_1 | 48 | 7.5 | 7500 | unframed | 75 (80 kbps) | 5 | 15 | 40000 |
| 48_2_1 | 48 | 10 | 10000 | unframed | 100 (80 kbps) | 5 | 20 | 40000 |
| 48_3_1 | 48 | 7.5 | 7500 | unframed | 90 (96 kbps) | 5 | 15 | 40000 |
| 48_4_1 | 48 | 10 | 10000 | unframed | 120 (96 kbps) | 5 | 20 | 40000 |
| 48_5_1 | 48 | 7.5 | 7500 | unframed | 117 (124.8 kbps) | 5 | 15 | 40000 |
| 48_6_1 | 48 | 10 | 10000 | unframed | 155 (124 kbps) | 5 | 20 | 40000 |
(*) Mandatory Configuration Unicast Client & Unicast Server
High reliability:
SDU Interval (µs) |
| 8_1_2 | 8 | 7.5 | 7500 | unframed | 26 (27.734 kbps) | 13 | 75 | 40000 |
| 8_2_2 | 8 | 10 | 10000 | unframed | 30 (24 kbps) | 13 | 95 | 40000 |
| 16_1_2 | 16 | 7.5 | 7500 | unframed | 30 (32 kbps) | 13 | 75 | 40000 |
| 16_2_2 | 16 | 10 | 10000 | unframed | 40 (32 kbps) | 13 | 95 | 40000 |
| 24_1_2 | 24 | 7.5 | 7500 | unframed | 45 (48 kbps) | 13 | 75 | 40000 |
| 24_2_2 | 24 | 10 | 10000 | unframed | 60 (48 kbps) | 13 | 95 | 40000 |
| 32_1_2 | 32 | 7.5 | 7500 | unframed | 60 (64 kbps) | 13 | 75 | 40000 |
| 32_2_2 | 32 | 10 | 10000 | unframed | 80 (64 kbps) | 13 | 95 | 40000 |
| 441_1_2 | 44.1 | 8.163 | 8163 | framed | 97 (95.06 kbps) | 13 | 80 | 40000 |
| 441_2_2 | 44.1 | 10.884 | 10884 | framed | 130 (95.55 kbps) | 13 | 85 | 40000 |
| 48_1_2 | 48 | 7.5 | 7500 | unframed | 75 (80 kbps) | 13 | 75 | 40000 |
| 48_2_2 | 48 | 10 | 10000 | unframed | 100 (80 kbps) | 13 | 95 | 40000 |
| 48_3_2 | 48 | 7.5 | 7500 | unframed | 90 (96 kbps) | 13 | 75 | 40000 |
| 48_4_2 | 48 | 10 | 10000 | unframed | 120 (96 kbps) | 13 | 100 | 40000 |
| 48_5_2 | 48 | 7.5 | 7500 | unframed | 117 (124.8 kbps) | 13 | 75 | 40000 |
| 48_6_2 | 48 | 10 | 10000 | unframed | 155 (124 kbps) | 13 | 100 | 40000 |
The configurations are separated between two tables: Low Latency and High Reliability. High Reliability configurations use a higher Retransmission Number (RTN) and higher maximum transport latency to ensure that the audio packets are all correctly transmitted, but induce higher latency due to increased buffering of the audio packets. Most of the configurations use an "unframed" mode, meaning the spacing of the events on the air will be a multiple of the actual time between two audio Packets (SDU Interval).
2.4. Broadcast Roles
The following diagram illustrates the simple broadcast use-case, where a device acting as Broadcast Sink interacts with a Broadcast Source.
When the device acting as Broadcast Sink is not able to select which Broadcast Source to synchronize to, due to limited display or input capacity for example, the device may use the Scan Delegator role to ask a remote Broadcast Assistant to scan and select the Broadcast Source.
2.4.1. Broadcast Advertisement
A Broadcast Source advertises to be visible by remote Broadcast Sinks. It's advertisement is composed of two different types of advertising:
- Extended Advertising: Partially on advertising channels (37-38-39) and on connection channels, it permits to be visible when a Broadcast Sink is scanning
- Periodic Advertising: On connection channels, it contains large packets with information about the stream configuration
To synchronize to a Broadcast Source, a broadcast sink initiates a scanning procedure to find the extended advertising payload, which points to the Periodic Advertising payload, which itself points to the BIG (Broadcast Isochronous Group), which contains one or more BIS(es) (Broadcast Isochronous Stream) with audio stream(s). For more information about BIG/BIS, see the Introduction to Bluetooth® LE Audio wiki page[3].
2.4.1.1. BASE Structure
The Broadcast Audio Source Endpoint (BASE) structure is the data structure that permits to describe a Broadcast Source. It is located in the periodic advertising data and is constituted of 3 levels with the following items:
| Level | Parameter | Description |
| 1 (Group) | Basic Audio Announcement Service UUID | UUID defined in Bluetooth Assigned Numbers: 0x1851 |
| 1 (Group) | Presentation Delay | Presentation Delay parameter. Refer to the the LC3 codec and audio data path wiki page, section Audio Latency[4] |
| 1 (Group) | Num Subgroups | Number of subgroups (level 2) |
| 2 (Subgroup) | Num BIS | Number of BISes (level 3) |
| 2 (Subgroup) | Codec ID | Codec ID for the subgroups. 0x0000000006 for the LC3 codec |
| 2 (Subgroup) | Codec Specific Configuration | Series of LTV structures with common codec specific configuration for the subgroup |
| 2 (Subgroup) | Metadata | Series of LTV Metadata structures |
| 3 (BIS) | BIS Index | Unique index for the BIS |
| 3 (BIS) | Codec Specific Configuration | Series of LTV structures with codec specific configuration for the bis |
Example of a stereo Broadcast Source with one BIS:
Example of a stereo Broadcast Source with two BISes:
2.4.1.2. Broadcast Source Air Events
Over the air, a Broadcast Source emits four different types of packets:
- ADV_EXT_IND packets are sent on the three advertising channels (Extended Advertising)
- AUX_ADV_IND packets are sent on connection channels and contains the remaining data of ADV_EXT_IND packets (Extended Advertising)
- AUX_SYNC_IND packets are sent on connection channels (Periodic Advertising)
- BIS ISO Packets are sent on connection channels during BIG Events (BIG)
The following diagram illustrates a possible scheduling of those packets:
2.4.2. Broadcast Topologies
The BAP specifies three different topologies for the Broadcast Roles. They define ways of establishing audio stream between one Central device and one or two Peripheral devices. The following table can be found in the BAP Specification and lists the possible topologies:
Legend | Audio Channels per BIS |
BISes | Audio Streams |
| 12 | ---)))--> | 1 | 1 | 1 |
| 13 | ---)))--> ---)))--> |
1 | 2 | 2 |
| 14 | ---)))-->> | 2 | 1 | 1 |
2.4.3. Broadcast Codec Configurations
The BAP specifies LC3 codec configurations that can be used to establish audio streams between devices in Broadcast mode. The following tables can be found in the BAP Specification and list the possible configurations: Low Latency:
SDU Interval (µs) |
| 24_2_1** | 24 | 10 | 10000 | unframed | 60 (48 kbps) | 2 | 10 | 40000 |
| 441_1_1 | 44.1 | 8.163 | 8163 | framed | 97 (95.06 kbps) | 4 | 24 | 40000 |
| 441_2_1 | 44.1 | 10.884 | 10884 | framed | 130 (95.55 kbps) | 4 | 31 | 40000 |
| 48_1_1 | 48 | 7.5 | 7500 | unframed | 75 (80 kbps) | 4 | 15 | 40000 |
| 48_2_1 | 48 | 10 | 10000 | unframed | 100 (80 kbps) | 4 | 20 | 40000 |
| 48_3_1 | 48 | 7.5 | 7500 | unframed | 90 (96 kbps) | 4 | 15 | 40000 |
| 48_4_1 | 48 | 10 | 10000 | unframed | 120 (96 kbps) | 4 | 20 | 40000 |
| 48_5_1 | 48 | 7.5 | 7500 | unframed | 117 (124.8 kbps) | 4 | 15 | 40000 |
| 48_6_1 | 48 | 10 | 10000 | unframed | 155 (124 kbps) | 4 | 20 | 40000 |
(*) Mandatory Configuration Broadcast Source & Broadcast Sink
(**) Mandatory Configuration Broadcast Sink
High reliability:
SDU Interval (µs) |
| 8_1_2 | 8 | 7.5 | 7500 | unframed | 26 (27.734 kbps) | 4 | 45 | 40000 |
| 8_2_2 | 8 | 10 | 10000 | unframed | 30 (24 kbps) | 4 | 60 | 40000 |
| 16_1_2 | 16 | 7.5 | 7500 | unframed | 30 (32 kbps) | 4 | 45 | 40000 |
| 16_2_2 | 16 | 10 | 10000 | unframed | 40 (32 kbps) | 4 | 60 | 40000 |
| 24_1_2 | 24 | 7.5 | 7500 | unframed | 45 (48 kbps) | 4 | 45 | 40000 |
| 24_2_2 | 24 | 10 | 10000 | unframed | 60 (48 kbps) | 4 | 60 | 40000 |
| 32_1_2 | 32 | 7.5 | 7500 | unframed | 60 (64 kbps) | 4 | 45 | 40000 |
| 32_2_2 | 32 | 10 | 10000 | unframed | 80 (64 kbps) | 4 | 60 | 40000 |
| 441_1_2 | 44.1 | 8.163 | 8163 | framed | 97 (95.06 kbps) | 4 | 54 | 40000 |
| 441_2_2 | 44.1 | 10.884 | 10884 | framed | 130 (95.55 kbps) | 4 | 60 | 40000 |
| 48_1_2 | 48 | 7.5 | 7500 | unframed | 75 (80 kbps) | 4 | 50 | 40000 |
| 48_2_2 | 48 | 10 | 10000 | unframed | 100 (80 kbps) | 4 | 65 | 40000 |
| 48_3_2 | 48 | 7.5 | 7500 | unframed | 90 (96 kbps) | 4 | 50 | 40000 |
| 48_4_2 | 48 | 10 | 10000 | unframed | 120 (96 kbps) | 4 | 65 | 40000 |
| 48_5_2 | 48 | 7.5 | 7500 | unframed | 117 (124.8 kbps) | 4 | 50 | 40000 |
| 48_6_2 | 48 | 10 | 10000 | unframed | 155 (124 kbps) | 4 | 65 | 40000 |
Like the Unicast codec configurations, the Broadcast codec configurations are separated between a Low Latency table and a High Reliability table.
3. Audio Stream Control Service (ASCS)
The ASCS is hosted on a Unicast Server to permit remote Unicast Client to configure and establish audio streams between the two devices. It contains the current unicast state of the Unicast Server and its state machine. It's specified by the Bluetooth® SIG and the full specification is accessible on their website[5].
3.1. Audio Stream Endpoints (ASE)
Audio Stream Endpoints (ASE) are hosted on Unicast Server and are controlled by remote Unicast Client to establish audio streams. They can be Sink or Source: a Sink ASE will host an audio stream directed from the Unicast Client to the Unicast Server and a Source ASE from the Unicast Server to the Unicast Client. An ASE can host multiple channels, concatenated on one CIS.
The following diagram illustrate a Unicast Server hosting three ASE: two Sink ASE and one Source ASE. The bidirectional CIS is established using ASE with ids 1 and 3, the unidirectional CIS uses the ASE with ID 2. The resulting configuration is configuration 8(i).
3.2. ASE State Machine
The Source ASE State Machine is the following, as specified in the Bluetooth SIG ASCS Specification[5]:
The Sink ASE State Machine is the following, as specified in the Bluetooth SIG ASCS Specification[5]:
For more details about ASE states and state machine, refer to the ASCS Specification[5] section 3.
4. Published Audio Capability Service (PACS)
The PACS permits a Unicast Server or Broadcast Sink to expose its audio capabilities to remote Unicast Clients and Broadcast Assistants. It's specified by the Bluetooth® SIG and the full specification is accessible on their website[6].
The PACS contains information about six items
- Sink Published Audio Capabilities
- Sink Audio Locations
- Source Published Audio Capabilities
- Source Audio Locations
- Available Audio Contexts
- Supported Audio Contexts
4.1. Published Audio Capability (PAC)
A PACS Server exposes one or multiple Published Audio Capability (PAC) records. These records indicate to a remote PACS Client which audio configurations are supported by the server.
| Parameter | Size (octets) | Value |
| Codec_ID | 5 | Codec ID, 0x0000000006 for the LC3 Codec |
| Codec_Specific_Capabilities_Length | 1 | Length, in octets, of the Codec_Specific_Capabilities value |
| Codec_Specific_Capabilities | Varies | Sequence of LTVs (Length-Type-Value) of Codec Capabilities See Assigned Numbers[2] |
| Metadata_Length | 1 | Length of the Metadata field |
| Metadata | Varies | Sequence of LTVs (Length-Type-Value) of Metadata See Assigned Numbers[2] |
4.2. Audio Locations
A PACS Server exposes a bitfield of Audio Locations values supported. The possible values can be found in the Assigned Numbers specification[2]. Possible common values for an Audio Location are:
- 0x00: Mono Audio without audio location. A mono speaker which is not part a speaker system can use this value.
- 0x01: Front Left
- 0x02: Front Right
- 0x03: Front Left + Front Right
4.3. Available/Supported Audio Contexts
A PACS Server exposes a bitfield of Context Type values currently available and a bitfield of Context Type values supported. The possible values can be found in the Assigned Numbers specification[2]. Possible common values for a Context Type are:
- 0x0001: Unspecified
- 0x0002: Conversational
- 0x0004: Media
- 0x0008: Game
5. Broadcast Audio Scan Service (BASS)
The Broadcast Audio Scan Service is hosted on a Scan Delegator collocated with a Broadcast Sink to communicate with a remote Broadcast Assistant and exchange information and commands about available Broadcast Sources. It's specified by the Bluetooth® SIG and the full specification is accessible on their website[7].
6. STM32Cube Firmware APIs
This section details how to do Bluetooth LE Audio Stream Management, using STM32CubeWBA Firmware.
6.1. Audio stream transition procedures
The procedures associated to the audio stream transition are specified in the section 7.3.1 of the Common Audio Profile[8]
6.1.1. Unicast audio procedures
The unicast audio procedures (Unicast Audio Start, Unicast Audio Stop, Unicast Audio Update) described in the CAP specification are performed by the CAP Initiator thanks to the functions listed in the Table 6.1.
| Functions | Description | Header File |
| CAP_Unicast_AudioStart() | Start Unicast audio with specified CAP Acceptors according to sink/ source stream configuration. | cap.h |
| CAP_Unicast_AudioStop() | Stop Unicast Audio with specified CAP Acceptors. | cap.h |
| CAP_Unicast_AudioUpdate() | Change context type values and/or CCID values associated with one or more unicast audio streams. | cap.h |
The section 3.5 (Table of the Basic audio profile[1] describes the requirements of the CAP Acceptor in unicast server role concerning the audio capabilities configuration (see Table 3.5 of the specification), and the audio channels configuration (see section 3.5.3) to support according to the audio role (sink and/or source) and the audio locations.
Note that each Bluetooth® Low Energy audio use case profile specifies its audio capabilities and audio channels requirements.
During the unicast audio stream transition procedure, the CAP Initiator and the CAP Acceptor receive CAP events described inTable 6.3.
| CAP procedure | Events | Description | CAP Initiator | CAP Acceptor |
| Audio start | CAP_UNICAST_AUDIO_STARTED. | Unicast audio start procedure is complete with all the specified CAP Acceptors. | X | |
| Audio start | CAP_UNICAST_PREFERRED_QOS_REQ_EVT | Preferred QoS settings are requested for the specified audio stream endpoint. | X | |
| Audio start | CAP_UNICAST_AUDIO_DATA_PATH_SETUP_REQ_EVT | Audio data path setup is requested for the specified audio stream endpoint. The CAP_Unicast_SetupAudioDataPath() shall be called to respond to the audio data path setup request. |
X | X |
| Audio start | CAP_AUDIO_CLOCK_REQ_EVT | Audio clock subsystem should be updated to support submitted audio sample frequency | X | X |
| Audio start Audio stop |
CAP_UNICAST_SERVER_ASE_STATE_EVT | The state of an audio stream endpoint has changed in unicast server side (CAP Acceptor) The state and the transition are described in the section 3 of the Audio stream control service [9]'. |
X | |
CAP_UNICAST_CLIENT_ASE_STATE_EVT | The state of an audio stream endpoint has changed in unicast client side (CAP Initiator) The state and the transition are described in the section 3 of the Audio stream control service [9]'. |
X | |
| Audio start | CAP_UNICAST_AUDIO_CONNECTION_UP_EVT | Audio path is up for specified audio stream endpoint | X | X |
CAP_UNICAST_AUDIO_CONNECTION_DOWN_EVT | Audio path is down for specified audio stream endpoint | X | X |
| Audio stop | CAP_UNICAST_AUDIO_STOPPED | Unicast audio stop procedure is complete with all the specified CAP Acceptors | X | |
| Audio update | CAP_UNICAST_AUDIO_UPDATED | Unicast audio update procedure is complete with all the specified CAP Acceptors | X | |
| Audio update | CAP_UNICAST_ASE_METADATA_UPDATED_EVT | Metadata associated to an audio stream endpoint is updated but audio stream endpoint State does not change | X | X |
The Figure 6.1 shows the Functions/Events exchanged between the Generic Audio Framework (GAF) and the Application Layer during the CAP Unicast audio start procedure in CAP Initiator and CAP Acceptor side. In this example, the CAP Initiator starts a bidirectional unicast audio with one CAP Acceptor. Consequently, a source ASE and a Sink ASE are used by the CAP Initiator to set up the unicast audio.
In case of a failure occurs during the unicast audio start procedure, the CAP Initiator automatically aborts the procedure to move the audio stream endpoints in IDLE or CODEC CONFIGURED state. Once the abort operation is complete, the upper layer is notified with CAP_UNICAST_AUDIO_STARTED event including a failure status.
The Figure 6.2 shows the Functions/Events exchanged between the Generic Audio Framework (GAF) and the Application Layer during the CAP Unicast audio stop procedure in CAP Initiator and CAP Acceptor side. In this example, at the starting point, a source ASE and a Sink ASE are in streaming state when the CAP Initiator calls the CAP_Unicast_AudioStop() function.
6.1.2. Broadcast audio procedures
6.1.2.1. CAP Initiator
The Figure 6.3 shows the broadcast state machine of the CAP Initiator in broadcast source role. The oval shapes represent the states of the CAP Initiator state machine. The labeled arrows represent the CAP broadcast function, which can cause a transition of the state machine.
The broadcast audio procedures (Broadcast Audio Start, Broadcast Audio Stop, Broadcast Audio Update) described in the CAP specification are performed by the CAP Initiator thanks to the functions listed in the Table 6.3.
| CAP_Broadcast_AudioStart() | Configure and start a broadcast source with the given parameters. | cap.h |
| CAP_Broadcast_AudioStop() | Stop a broadcast source and go to configured or idle State. | cap.h |
| CAP_Broadcast_AudioUpdate() | Update a streaming broadcast source metadata Cannot change an audio configuration. |
cap.h |
During the CAP broadcast audio procedures, the CAP Initiator is notified, over CAP events, that the procedure is complete and the state of the audio path associated to the audio stream has changed. These events notified during the CAP broadcast audio procedures are listed in theTable 6.4.
| Events | Description | Header File |
| CAP_BROADCAST_AUDIOSTARTED_EVT | Event notified when the broadcast audio start procedure is complete. | cap_types.h |
| CAP_BROADCAST_AUDIOSTOPPED_EVT | Event notified when the broadcast audio stop procedure is complete. | cap_types.h |
| CAP_BROADCAST_AUDIO_UP_EVT | Event notified when the audio path has been set up. | cap_types.h |
| CAP_BROADCAST_AUDIO_DOWN_EVT | Event notified when the audio path has been removed. | cap_types.h |
6.1.2.2. CAP Acceptor
When a broadcast audio stream is in progress, a CAP Acceptor, supporting broadcast sink role, which would be synchronized with the broadcast audio stream needs to call successive Bluetooth® Low Energy legacy functions and CAP functions to be able to be synchronized with the broadcast isochronous stream emitted by a CAP Initiator. The CAP functions allowing the CAP Acceptor to manage broadcast audio stream are listed in the Table 6.5.
| CAP_Broadcast_StartAdvReportParsing() | Start parsing extended advertising events to look for broadcast UUIDs and generate CAP_ACC_BROADCAST_SOURCE_ADV_REPORT_EVT events An observation procedure must be started by the user in parallel. |
cap.h |
| CAP_Broadcast_StopAdvReportParsing() | Stop parsing extended advertising events. | cap.h |
| CAP_Broadcast_StartPASync() | Start synchronization to a periodic advertising train. | cap.h |
| CAP_Broadcast_StartBIGSync() | Start synchronization to a broadcast isochronous group. | cap.h |
| CAP_Broadcast_StopPASync() | Stop synchronization to a periodic advertising train. | cap.h |
| CAP_Broadcast_StopBIGSync() | Stop synchronization to a broadcast isochronous group. | cap.h |
| CAP_Broadcast_ParseBASEGroup() | Parse a BASE payload reported by a CAP_ACC_BROADCAST_REPORT_EVT and fill a BAP_BASE_Group_t structure. | cap.h |
| CAP_Broadcast_ParseBASESubgroup() | Parse a BASE payload reported by a CAP_ACC_BROADCAST_REPORT_EVT and fill a BAP_BASE_Subgroup_t structure. | cap.h |
| CAP_Broadcast_ParseBASEBIS() | Parse a BASE payload reported by a CAP_BROADCAST_BASE_REPORT_EVT and fill a BAP_BASE_BIS_t structure. | cap.h |
During the broadcast audio procedure in CAP Acceptor side, various CAP events are notified in the application layer resulting to operations started by the CAP Acceptor itself or the remote CAP Initiator. These CAP events received in the CAP Acceptor side are listed in the Table 6.6.
| CAP_BROADCAST_SOURCE_ADV_REPORT_EVT | Notified when a broadcast source has been scanned. | cap_types.h |
| CAP_BROADCAST_PA_SYNC_ESTABLISHED_EVT | Notified when synchronization to a periodic advertising train has been established. | cap_types.h |
| CAP_BROADCAST_BASE_REPORT_EVT | Notified when a BASE report is received. | cap_types.h |
| CAP_BROADCAST_BIGINFO_REPORT_EVT | Notified when a BIG info is received. | cap_types.h |
| CAP_BROADCAST_BIG_SYNC_ESTABLISHED_EVT | Notified when synchronization to a BIG has been established. | cap_types.h |
| CAP_BROADCAST_PA_SYNC_LOST_EVT | Notified when synchronization to a periodic advertising train has been lost. | cap_types.h |
| CAP_BROADCAST_BIG_SYNC_LOST_EVT | Notified when synchronization to a BIG has been lost. | cap_types.h |
| CAP_BROADCAST_AUDIO_UP_EVT | Notified when audio data path has been set up. | cap_types.h |
| CAP_BROADCAST_AUDIO_DOWN_EVT | Notified when audio data path has been removed. | cap_types.h |
The Figure 6.4 describes the broadcast sink sequence diagram between the application, the Generic Audio Framework (GAF), the BLE Host Stack and the remote CAP Initiator during the broadcast audio stream synchronization procedure in CAP Acceptor side. To synchronize with broadcast audio stream, successive CAP broadcast operations are required in the CAP Acceptor side.
6.2. Published Audio Capabilities APIs
For CAP Acceptor supporting Unicast server or Broadcast Sink role, the Generic Audio Framework provides functions to :
- Register sink/source audio channels accessible by the remote CAP Initiator or CAP Commander
- Set/Update the audio contexts (Conversational, media… Audio_Context_t defined in audio_types.h)
- Set/Update the audio locations (Front left, front right… Audio_Location_t defined in audio_types.h)
- Register/Update the audio capabilities of the unicast server
The Table 6.7 describes the functions dedicated to the CAP Acceptor in the unicast server role.
| CAP_RegisterAudioChannels() | Register sink/source audio channels (and associated audio stream endpoint) supported by unicast server. | cap.h |
| CAP_SetSupportedAudioContexts() | Set/Update supported audio contexts for reception and transmission. | cap.h |
| CAP_SetAvailableAudioContexts() | Set available audio contexts for reception and transmission which will be used for BAP Announcement and for future connections. | cap.h |
| CAP_UpdateAvailableAudioContexts() | Update available audio contexts for reception and transmission associated to the specified remote CAP device. | cap.h |
| CAP_SetSnkAudioLocations() | Set/Update the supported sink audio locations. | cap.h |
| CAP_SetSrcAudioLocations() | Set/Update the supported source audio locations. | cap.h |
| CAP_RegisterSnkPACRecord() | Register published audio capabilities record for audio sink role. | cap.h |
| CAP_RegisterSrcPACRecord() | Register published audio capabilities record for audio source role. | cap.h |
| CAP_UpdatePACRecord() | Update a registered audio codec capabilities record for audio sink/source role. | cap.h |
7. References
- ↑ 1.0 1.1 BAP Specification
- ↑ 2.0 2.1 2.2 2.3 2.4 Bluetooth® Assigned Numbers
- ↑ Introduction to Bluetooth® LE Audio wiki - Link Layer and isochronous channels
- ↑ Bluetooth® Low Energy audio - STM32WBA LC3 codec and audio data path - Audio Latency
- ↑ 5.0 5.1 5.2 5.3 ASCS Specification
- ↑ PACS Specification
- ↑ BASS Specification
- ↑ Common Audio profile specification
- ↑ 9.0 9.1 Audio Stream Control Service specification
