Approved version. Approved on: 09:07, 30 April 2020
- Last edited 2 years ago ago
How to write a variable from flow
It is possible to write a variable value directly from a flow or dashboard, without entering the value in the "write panel" node. Here is a solution using standard nodes: A slider is used to set the value (but can be done by any node) then the “template” node formats the payload and the change node sets the topic.
Details :
The variable address and variable type must be filled here. For the type and address, the easiest way is to try first with a writing panel and a debug node, and see the values. The Payload value from the input will be inserted in the template. (the value to write)
The next node is a “change” node to set the topic to “write”
The result :
When the slider is moved, the new value is written to g_constDouble
