1. Fixed issues
| ID |
Summary
| 63212 |
Editor hyperlinks sometimes jump to declaration instead of definition.
| 83159[1] |
After updating STM32CubeIDE to a new version, the post-update restart fails on Linux® and macOS®. STM32CubeIDE must be restarted manually.
| 100287 |
Bin-files are no longer generated by default to reduce build time and the size of build output.
| 118111 |
Slow debug performance with RTOS proxy, especially on Windows®.
| 109124 |
When creating a debug configuration using ST-LINK GDB server, the SWD frequency must manually be changed from auto to a maximum of 8000 kHz.
2. Known issues
The known issues are split into general, OS-specific, and target-specific issues.
2.1. General issues
| ID |
Summary
| 59435 |
Having a space or non-ASCII character in the project/workspace path or installation path is not fully supported.
| 63624 |
Some STM32CubeMX pop-up dialogs are not opened in front of the STM32CubeIDE workbench on all OS's.
| 68184 |
Hierarchical projects cannot be imported with the option Copy into workspace.
| 68440 |
Hierarchical projects cannot be renamed.
| 74251 |
SWV Exception Trace log data tab displays a peripheral column, which is always empty.
| 89454 |
Restart configuration only works for flash memory projects and not for RAM projects. Program Counter register is not set correctly. Manual work-around: In Restart configuration, manually set PC to the ResetHandler() in RAM: set $pc = 0x20000xxx.
| 101005 [1] |
New JRE™ bundling does not automatically import private certificate authorities, that are needed for secure connections. See the following knowledge article for a solution here.
| 109764 |
FreeRTOS™ kernel-aware debugging: Full stack traces off all tasks do not work if configUSE_PORT_OPTIMISED_TASK_SELECTION 1
| 115928 |
Editing live expressions while target is running does not work with SEGGER J-Link.
| 124062 |
GCC-10 is more strict with respect to declaration of global variables in header files. Read the GCC-10 porting guide.
2.2. OS-specific issues
2.2.1. macOS®
| ID |
Summary
| 85064 |
Some macOS® versions report installation image corruption or that the image cannot be opened because the developer cannot be verified. The work-around is to execute the following command: xattr -c /Applications/STM32CubeIDE.app.
2.2.2. Linux®
| ID |
Summary
| 126202 |
Debug unable to launch or crashes sporadically on some Linux® systems with GDB-client from Arm GCC10 package. Regression vs GCC9. Work-arounds: Use GCC9 or copy/replace arm-none-eabi-gdb from GCC9 to GCC10.
2.3. Target-specific issues
2.3.1. STM32H7
| ID |
Summary
| 73552 |
Serial Wire Viewer configuration is not reset for STM32H7 devices on the next launch if it was terminated with record active when using ST-LINK GDB server.
| 79658 |
ST-LINK GDB server reports being suspended on address: 0x05F0001 when debugging STM32H7 dual-core devices and the core under debug goes to sleep.
| 81763 |
OpenOCD does not support debugging STM32H7 dual-core devices when the core under debug goes to sleep.
2.3.2. STM32MP1
| ID |
Summary
| 73456 |
The SFRs view is not aware of the device tree configuration and consequently shows all peripherals regardless if they are managed by the Cortex®-M or not.
| 73895 |
Debugging in production mode requires a network connection. If STM32CubeIDE is configured to use a network proxy, then the IP address of the STM32MP1 board needs to be added to the "Proxy bypass" list.
| 73896 |
The synchronization check between the IP-address entered in launch configuration and the IP-address of the target does not abort the launch in case of mismatch.
2.3.3. STM32WL
| ID |
Summary
| 124465 |
STM32CubeIDE 1.9.0 is unable to debug the Cortex®-M0+ core of the STM32WL product. Customers are advised to use STM32CubeIDE 1.8.0.
1. Same limitation for Linux® and macOS®
