COMBOPHY internal peripheral
  • briefly introduce the COMBOPHY peripheral and its main features,
The COMBOPHY peripheral is used as protocol PHY for the USB3DR or PCIe. It provides:
  • The physical layer for differential Rx/Tx data encoding
  • The 100Mhz differential reference clock provided to the pins and the PCIe controller.
The 100Mhz PCIe internal reference clock can be sourced directly from:
  • The PLL with a 20Mhz the crystal oscillator (HSE) input
  • An external PCIe 100 MHz differential reference clock (with SSC).
COMBOPHY Block Diagram
STM32MP2 internal peripherals assignment table template
| rowspan="1" | High speed interface | rowspan="1" | COMBOPHY | COMBOPHY | | | | |-
| rowspan="1" | High speed interface | rowspan="1" | COMBOPHY | COMBOPHY | OP-TEE | | | | | |-
Below are listed the software frameworks and drivers managing the COMBOPHY peripheral for the embedded software components listed in the above tables.
  • Partial device trees (pin control and clock tree) for the OpenSTLinux software components,
For Linux kernel, please refer to the COMBOPHY device tree configuration
