LPTIM internal peripheral
  • briefly introduce the LPTIM peripheral and its main features,
2. Peripheral overview
The LPTIM peripheral is a single channel low-power timer unit, that can continue to run even during low power modes when it selects a clock source that remains active in RCC.
The LPTIM peripheral is available in different configurations. Depending on the selected instance, it can act as PWM, quadrature encoder[1], external event counter or trigger source for other internal peripherals, like ADC[2], DFSDM[3] and DAC[4] (on STM32MP15x lines More info.png).
LPTIM features PWM External event counter
Trigger source
Quadrature encoder
LPTIM1, LPTIM2 Yes Yes Yes
LPTIM3 Yes Yes
LPTIM4, LPTIM5 Yes
  • On STM32MP13x lines More info.png, LPTIM3 can be used for RCC HSE clock source monitoring
  • On STM32MP25x lines More info.png, LPTIM can have up to 2 independent channels. It also supports input capture. LPTIM1 can be used for RCC HSE monitoring.
3. Peripheral usage
3.1. Boot time assignment
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Core/Timers LPTIM LPTIM1
LPTIM2
LPTIM3
LPTIM4
LPTIM5
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Core/Timers LPTIM LPTIMx (x = 1 to 5) LPTIM are not used at boot time.
STM32MP2 internal peripherals assignment table template
| rowspan="1" | Core/Timers | rowspan="1" | LPTIM | LPTIMx (x = 1 to 5) | | | | LPTIM are not used at boot time. |-
3.2. Runtime assignment
non-secure
LPTIM2 Assignment (single choice)
LPTIM3 Assignment (single choice)
LPTIM3 can be used for HSE monitoring
LPTIM4
LPTIM5
non-secure
Cortex-M4
Core/Timers LPTIM LPTIMx (x = 1 to 5) Assignment (single choice)
| rowspan="5" | Core/Timers | rowspan="5" | LPTIM | LPTIM1 | OP-TEE | | | | | LPTIM1 can be used for HSE monitoring. |- | LPTIM2 | OP-TEE | | | | | |- | LPTIM3 | OP-TEE | | | | | |- | LPTIM4 | OP-TEE | | | | | |- | LPTIM5 | OP-TEE | | | | | |-
Below are listed the software frameworks and drivers managing the LPTIM peripheral for the embedded software components listed in the above tables.
For Linux kernel configuration, please refer to LPTIM device tree configuration and STM32 LPTIM Linux driver articles.
6. References
