DAC internal peripheral
  • briefly introduce the DAC peripheral and its main features,
2. Peripheral overview
The DAC peripheral is a voltage output digital-to-analog converter:
  • It may be configured in 8- or 12-bit mode (data could be left- or right-aligned)
  • It has two output channels, each with its own converter
  • The dual DAC channel mode could be done independently or simultaneously
  • It has built-in noise and triangle waveform generator and supports triggers for conversions, using: TIM[1], LPTIM[2] or EXTI[3]
  • The DAC output buffer allows a high drive output current
  • It can operate under Normal mode or low-power Sample and Hold mode (uses LSI clock, from RCC[4]).
  • It may be used in conjunction with the DMA[5] controller (with underrun error detection)
  • The common reference voltage, can be provided by either VREFBUF[6] or any other external regulator[7] wired to VREF+ pin.
3. Peripheral usage
3.1. Boot time assignment
The DAC peripheral is not used at boot time.
3.2. Runtime assignment
non-secure
Cortex-M4
Analog DAC DAC Assignment (single choice)
Below are listed the software frameworks and drivers managing the DAC peripheral for the embedded software components listed in the above tables.
For the Linux kernel configuration, please refer to DAC device tree configuration and DAC Linux driver articles.
6. References
