Regulator overview
This article gives information about the Linux® regulator framework.
1. Article Purpose
This article aims to explain how to use regulators:
  • how to configure a regulator on a Linux BSP
  • how to access a regulator from a kernel space
This article is applicable for the Linux kernel version 4.10 and later.
2. System overview
Some documentation on the Linux regulator framework is provided with the Linux documentation or in code source power/regulator/overview.rst [1]
2.1. Overview
The power supplies can be provided by various blocks:
  • External single regulators:
    • Low-dropout regulators (LDO)
    • BUCKs (DC-to-DC power converter)
    • Switches
  • A Power Management Integrated Circuit (PMIC) that integrates several LDO and BUCKS
All the regulators are implemented and controlled under the standard Linux regulator framework.
2.2. Components Description
2.2.1. External devices: external regulators, PMIC
This corresponds to physical components that provide the various power supplies on the board, for example STMicrolectronics PMIC.
2.2.2. Microprocessor device internal regulators
This corresponds to the regulators integrated to the microprocessor device. Those regulators supply mainly the USB and ADC peripherals.
2.2.3. Regulator drivers
A regulator that can be controlled (enable/disable, adjust voltage...) needs a driver to operate. This is the role of the regulator driver.
A driver can also send notifications like over current or over temperature.
Notes:
  • The kernel contains generic drivers for GPIO controlled regulators.
  • The PMIC uses a specific driver.
  • The internal regulators of the microprocessor device are implemented in the STM32 machine.
  • kernel Documentation regulator.rst [2]
2.2.4. Regulator framework core
The core manages all the regulators as described in Linux documentation. A consumer request is not handled directly by a regulator driver. It is handled by the core that can arbitrate requests between consumers in order to save power.
2.2.5. Regulator consumers
The devices correspond to internal or external peripherals of the microprocessor device ( ADC, SDCARD, USB, ETHERNET... )
Each peripheral that needs a power supply to operate must enable it. When a regulator is not used, it is disabled by the core.
The consumer interface allows to control a regulator (enable/disable, set voltage...), and to register to a notification service.
2.2.6. Sysfs interface
The regulator framework offers a sysfs interface that can be used for monitoring. It is not possible to control a regulator via the sysfs.
See Documentation/ABI/testing/sysfs-class-regulator for details.
2.2.7. Configfs interface
Most of the regulator configurations are described in the device-tree (configfs)
3. How to find the source code
Everything is part of the kernel source code:
4. Regulator configuration
4.1. Kernel configuration
The configuration is done using the standard menuconfig. Most configurations are available under Device Drivers / Voltage and Current Regulator Support
4.2. Device tree configuration
Binding documentation: regulator.yaml
The device tree describes regulators and consumers:
  • A regulator provides a supply.
  • A consumer uses a supply.
When possible, the supply name comes from the electrical schematics of the board.
4.2.1. Some regulator drivers
4.2.1.1. Fixed regulator
usb otg vbus:
   vbus_otg: regulator-vbus_otg {
       compatible = "regulator-fixed";
       regulator-name = "vbus_otg";
       regulator-min-microvolt = <5000000>;
       regulator-max-microvolt = <5000000>;
       gpio = <&gpioz 4 0>;
       enable-active-high;
Binding documentation:fixed-regulator.yaml
4.2.1.2. Gpio controlled regulator
sdcard level shifter:
   sd_switch: regulator-sd_switch {
       compatible = "regulator-gpio";
       regulator-name = "sd_switch";
       regulator-min-microvolt = <1800000>;
       regulator-max-microvolt = <2900000>;
       regulator-type = "voltage";
       regulator-always-on;
       gpios = <&gpiof 14 GPIO_ACTIVE_HIGH>;
       gpios-states = <0>;
       states = <1800000 0x1 2900000 0x0>;
Binding documentation:gpio-regulator.yaml
4.2.1.3. PMIC
   pmic: stpmu1@33 {
       compatible = "st,stpmu1";
       reg = <0x33>;
       interrupts = <0 2>;
       interrupt-parent = <&gpioa>;
       interrupt-controller;
       #interrupt-cells = <2>;
       status = "okay";
       regulators {
           compatible = "st,stpmu1-regulators";
           vddcore: buck1 {
               regulator-compatible = "buck1";
               regulator-name = "vddcore";
               regulator-min-microvolt = <800000>;
               regulator-max-microvolt = <1350000>;
               regulator-initial-mode = <2>;
           vdd_ddr: buck2 {
               regulator-compatible = "buck2";
               regulator-name = "vdd_ddr";
               regulator-min-microvolt = <1350000>;
Binding documentation:st,stpmic1.yaml
4.2.1.4. Microcontroller device internal regulator
VREFBUF regulator:
   vrefbuf: vrefbuf@50025000 {
       compatible = "st,stm32-vrefbuf";
       reg = <0x50025000 0x8>;
       regulator-min-microvolt = <1500000>;
       regulator-max-microvolt = <2500000>;
       clocks = <&rcc_clk VREF>;
       status = "disabled";
Binding documentation:st,stm32-vrefbuf.yaml
4.2.1.5. SCMI regulator
The SCMI protocol permits to drive a regulator handled by the secure monitor (OP-TEE). Linux scmi driver implements requests like get, set voltage, enable and disable. OP-TEE then receives and arbitrate the requests depending on internal constraints.
 scmi0_voltd: protocol@17 {
 	reg = <0x17>;
 	scmi0_regu: regulators {
 		scmi_reg11: voltd-reg11 {
 			voltd-name = "reg11";
 			regulator-name = "reg11";
 		scmi_reg18: voltd-reg18 {
 			voltd-name = "reg18";
 			regulator-name = "reg18";
Binding documentation:arm,scmi.yaml
4.2.2. Consumers
See below some examples of consumers.
The SDMMC needs 2 power supply:
   &sdmmc1 {
       vmmc-supply = <&vdd_sd>;
       vqmmc-supply = <&sd_switch>;
The name before "-supply" is not free. vmmc and vqmmc are imposed by the consumer driver. They should be aligned with the name used in the data sheet of the driven component.
The USBPHY is supplied by vdd_usb:
   &usbphyc {
       vdd-supply = <&vdd_usb>;
The DAC is supplied by vdda:
   &dac {
       pinctrl-names = "default";
       pinctrl-0 = <&dac_ch1_pins &dac_ch2_pins>;
       vref-supply = <&vdda>;
       status = "okay";
The regulators can be consumers. This is used to define power domains:
   pmic: stpmu1@33 {
       regulators {
           ldo1-supply = <&v3v3>;
           ldo2-supply = <&v3v3>;
           ldo5-supply = <&v3v3>;
           ldo6-supply = <&v3v3>;
           vref_ddr-supply = <&vdd_ddr>;
           vbus_otg-supply = <&bst_out>;
           sw_out-supply = <&bst_out>;
Enabling ldo1 will enable v3v3 automatically.
5. Power management
The regulator framework handles the power management at runtime and during suspend.
5.1. Runtime
  • The consumers should disable the regulators that are not needed.
  • The core disables a regulator as soon as it is not requested by any consumer.
This can be avoided by the usage of "regulator-always-on" property in the device-tree.
5.2. Suspend
The regulator framework offers the possibility to define suspend states for regulators. This is only possible if the driver allows it. The regulator suspend sate is no more handled by the linux kernel in OpenSTLinux distribution.
regulator-state-standby, regulator-state-mem, regulator-state-disk are used to define the state of the regulators during suspend.
               regulator-state-standby {
                   regulator-on-in-suspend;
                   regulator-suspend-microvolt = <900000>;
                   regulator-mode = <8>;
               regulator-state-mem {
                   regulator-off-in-suspend;
  • The regulator runtime strategy does not apply to suspend. With "regulator-on-in-suspend", the regulator is enabled in suspend even if no consumer uses it.
  • "regulator-always-on" does not apply to suspend states.
6.1. How to trace
The regulator framework provides debugfs tools. The most important one is regulator/regulator_summary:
 cat /sys/kernel/debug/regulator/regulator_summary
 regulator                      use open bypass voltage current     min     max
  regulator-dummy                  0    6      0     0mV     0mA     0mV     0mV
     vddcore                       0    0      0  1200mV     0mA   800mV  1350mV
     vdd_ddr                       0    1      0  1350mV     0mA  1350mV  1350mV
        vtt_ddr                    0    0      0   675mV     0mA   675mV   675mV
     vdd                           0    1      0  3300mV     0mA  3300mV  3300mV
        58007000.sdmmc                                            3300mV  3300mV
     v3v3                          1    5      0  3300mV     0mA  3300mV  3300mV
        vdda                       0    2      0  2900mV     0mA  2900mV  2900mV
           40017000.dac                                              0mV     0mV
           48003000.adc                                              0mV     0mV
        v2v8                       0    0      0  2800mV     0mA  2800mV  2800mV
        vdd_sd                     0    1      0  2900mV     0mA  2900mV  2900mV
           58005000.sdmmc                                         2900mV  2900mV
        v1v8                       0    0      0  1800mV     0mA  1800mV  1800mV
     vdd_usb                       0    0      0  3300mV     0mA  3300mV  3300mV
     bst_out                       0    2      0  5000mV     0mA     0mV     0mV
        vbus_otg                   0    0      0  5000mV     0mA     0mV     0mV
        vbus_sw                    0    0      0  5000mV     0mA     0mV     0mV
  sd_switch                        0    1      0  2900mV     0mA  1800mV  2900mV
     58005000.sdmmc                                               2700mV  2900mV
  reg11                            0    0      0  1100mV     0mA  1100mV  1100mV
  reg18                            0    0      0  1800mV     0mA  1800mV  1800mV
  usb33                            0    0      0  3300mV     0mA  3300mV  3300mV
  vref_ddr                         0    0      0   675mV     0mA     0mV     0mV
Notes:
  • use: counts the "enable" calls made by the consumers
  • open: is the number of consumers that get the regulator
  • vdd_sd is a consumer for v3v3
  • 58005000.sdmmc is a consumer for v3v3, vdd_sd, sd_switch
  • when regulator_always_on property is set, use is equal to ZERO (but the regulator is enabled...)
7. References
