This article provides the basic information needed to start using the Linux® command tool: ethtool [1].
2. Introduction
Tool | STM32MPU Embedded Software distribution | STM32MPU Embedded Software distribution for Android™ Only supported for STM32MP15x lines ![]() | ||||||
ethtool | Monitoring tools | ethtool[1] allows to query or control network driver and hardware settings, in particular for wired Ethernet devices. | ![]() |
ethtool is installed by default and ready to be used with all STM32MPU Embedded Software Packages.
which ethtool
/usr/sbin/ethtool
It is integrated in weston image distribution through the meta-st package: meta-st/meta-st-openstlinux/recipes-st/packagegroups/packagegroup-framework-tools.bb
ethtool \ iproute2 \ "RDEPENDS_packagegroup-framework-tools-network-base = "\
4. Getting started
The ethernet links available on your board can be listed by using the IP Linux command line:
ip link | grep eth
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 00:80:e1:42:43:65 brd ff:ff:ff:ff:ff:ff
- Get information about the eth0 network device:
ethtool eth0
Settings for eth0:
Supported ports: [ TP AUI BNC MII FIBRE ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: ug
Wake-on: d
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: yes
- Display Ethernet driver settings for eth0
ethtool -i eth0
driver: st_gmac
version: Jan_2016
firmware-version:
expansion-rom-version:
bus-info:
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
- Display network statistics for eth0:
ethtool -S eth0
NIC statistics:
mmc_tx_octetcount_gb: 0
mmc_tx_framecount_gb: 0
mmc_tx_broadcastframe_g: 0
mmc_tx_multicastframe_g: 0
mmc_tx_64_octets_gb: 0
mmc_tx_65_to_127_octets_gb: 0
mmc_tx_128_to_255_octets_gb: 0
mmc_tx_256_to_511_octets_gb: 0
mmc_tx_512_to_1023_octets_gb: 0
mmc_tx_1024_to_max_octets_gb: 0
mmc_tx_unicast_gb: 0
mmc_tx_multicast_gb: 0
mmc_tx_broadcast_gb: 0
mmc_tx_underflow_error: 0
mmc_tx_singlecol_g: 0
mmc_tx_multicol_g: 0
mmc_tx_deferred: 0
mmc_tx_latecol: 0
mmc_tx_exesscol: 0
mmc_tx_carrier_error: 0
mmc_tx_octetcount_g: 0
mmc_tx_framecount_g: 1809
mmc_tx_excessdef: 0
mmc_tx_pause_frame: 0
mmc_tx_vlan_frame_g: 0
mmc_rx_framecount_gb: 0
mmc_rx_octetcount_gb: 0
mmc_rx_octetcount_g: 0
mmc_rx_broadcastframe_g: 0
mmc_rx_multicastframe_g: 0
mmc_rx_crc_error: 0
mmc_rx_align_error: 0
mmc_rx_run_error: 0
mmc_rx_jabber_error: 0
mmc_rx_undersize_g: 0
mmc_rx_oversize_g: 0
mmc_rx_64_octets_gb: 0
mmc_rx_65_to_127_octets_gb: 0
mmc_rx_128_to_255_octets_gb: 0
mmc_rx_256_to_511_octets_gb: 0
mmc_rx_512_to_1023_octets_gb: 0
mmc_rx_1024_to_max_octets_gb: 0
mmc_rx_unicast_g: 1514
mmc_rx_length_error: 0
mmc_rx_autofrangetype: 0
mmc_rx_pause_frames: 0
mmc_rx_fifo_overflow: 0
mmc_rx_vlan_frames_gb: 0
mmc_rx_watchdog_error: 0
mmc_rx_ipc_intr_mask: 0
mmc_rx_ipc_intr: 0
mmc_rx_ipv4_gd: 0
mmc_rx_ipv4_hderr: 0
mmc_rx_ipv4_nopay: 0
mmc_rx_ipv4_frag: 0
mmc_rx_ipv4_udsbl: 0
mmc_rx_ipv4_gd_octets: 0
mmc_rx_ipv4_hderr_octets: 0
mmc_rx_ipv4_nopay_octets: 0
mmc_rx_ipv4_frag_octets: 0
mmc_rx_ipv4_udsbl_octets: 0
mmc_rx_ipv6_gd_octets: 0
mmc_rx_ipv6_hderr_octets: 0
mmc_rx_ipv6_nopay_octets: 0
mmc_rx_ipv6_gd: 0
mmc_rx_ipv6_hderr: 0
mmc_rx_ipv6_nopay: 0
mmc_rx_udp_gd: 0
mmc_rx_udp_err: 0
mmc_rx_tcp_gd: 0
mmc_rx_tcp_err: 0
mmc_rx_icmp_gd: 0
mmc_rx_icmp_err: 0
mmc_rx_udp_gd_octets: 0
mmc_rx_udp_err_octets: 0
mmc_rx_tcp_gd_octets: 0
mmc_rx_tcp_err_octets: 0
mmc_rx_icmp_gd_octets: 0
mmc_rx_icmp_err_octets: 0
tx_underflow: 0
tx_carrier: 0
tx_losscarrier: 0
vlan_tag: 0
tx_deferred: 0
tx_vlan: 0
tx_jabber: 0
tx_frame_flushed: 0
tx_payload_error: 0
tx_ip_header_error: 0
rx_desc: 0
sa_filter_fail: 0
overflow_error: 0
ipc_csum_error: 0
rx_collision: 0
rx_crc_errors: 0
dribbling_bit: 0
rx_length: 0
rx_mii: 0
rx_multicast: 0
rx_gmac_overflow: 0
rx_watchdog: 0
da_rx_filter_fail: 0
sa_rx_filter_fail: 0
rx_missed_cntr: 0
rx_overflow_cntr: 0
rx_vlan: 0
tx_undeflow_irq: 0
tx_process_stopped_irq: 0
tx_jabber_irq: 0
rx_overflow_irq: 0
rx_buf_unav_irq: 0
rx_process_stopped_irq: 0
rx_watchdog_irq: 0
tx_early_irq: 0
fatal_bus_error_irq: 0
rx_early_irq: 0
threshold: 1
tx_pkt_n: 1809
rx_pkt_n: 12682
normal_irq_n: 11110
rx_normal_irq_n: 11082
napi_poll: 11118
tx_normal_irq_n: 28
tx_clean: 11641
tx_set_ic_bit: 28
irq_receive_pmt_irq_n: 0
mmc_tx_irq_n: 0
mmc_rx_irq_n: 0
mmc_rx_csum_offload_irq_n: 0
irq_tx_path_in_lpi_mode_n: 0
irq_tx_path_exit_lpi_mode_n: 0
irq_rx_path_in_lpi_mode_n: 0
irq_rx_path_exit_lpi_mode_n: 0
phy_eee_wakeup_error_n: 0
ip_hdr_err: 0
ip_payload_err: 0
ip_csum_bypassed: 544
ipv4_pkt_rcvd: 9189
ipv6_pkt_rcvd: 1948
no_ptp_rx_msg_type_ext: 12682
ptp_rx_msg_type_sync: 0
ptp_rx_msg_type_follow_up: 0
ptp_rx_msg_type_delay_req: 0
ptp_rx_msg_type_delay_resp: 0
ptp_rx_msg_type_pdelay_req: 0
ptp_rx_msg_type_pdelay_resp: 0
ptp_rx_msg_type_pdelay_follow_up: 0
ptp_rx_msg_type_announce: 0
ptp_rx_msg_type_management: 0
ptp_rx_msg_pkt_reserved_type: 0
ptp_frame_type: 0
ptp_ver: 0
timestamp_dropped: 0
av_pkt_rcvd: 0
av_tagged_pkt_rcvd: 0
vlan_tag_priority_val: 0
l3_filter_match: 0
l4_filter_match: 0
l3_l4_filter_no_match: 0
irq_pcs_ane_n: 0
irq_pcs_link_n: 0
irq_rgmii_n: 1
mtl_tx_status_fifo_full: 0
mtl_tx_fifo_not_empty: 0
mmtl_fifo_ctrl: 0
mtl_tx_fifo_read_ctrl_write: 0
mtl_tx_fifo_read_ctrl_wait: 0
mtl_tx_fifo_read_ctrl_read: 0
mtl_tx_fifo_read_ctrl_idle: 0
mac_tx_in_pause: 0
mac_tx_frame_ctrl_xfer: 0
mac_tx_frame_ctrl_idle: 0
mac_tx_frame_ctrl_wait: 0
mac_tx_frame_ctrl_pause: 0
mac_gmii_tx_proto_engine: 0
mtl_rx_fifo_fill_level_full: 0
mtl_rx_fifo_fill_above_thresh: 0
mtl_rx_fifo_fill_below_thresh: 0
mtl_rx_fifo_fill_level_empty: 0
mtl_rx_fifo_read_ctrl_flush: 0
mtl_rx_fifo_read_ctrl_read_data: 0
mtl_rx_fifo_read_ctrl_status: 0
mtl_rx_fifo_read_ctrl_idle: 0
mtl_rx_fifo_ctrl_active: 0
mac_rx_frame_ctrl_fifo: 0
mac_gmii_rx_proto_engine: 0
tx_tso_frames: 0
tx_tso_nfrags: 0
5. To go further
Lots of documentation exists on Internet about ethtool.
Refer to ethtool man page[1] for more details on command options.
6. References
- Useful external links
ethtool | Standard | Wikipedia article |
ethtool-command | User guide | thegeekstuff web page |
