The purpose of this article is to explain how to configure the RCC internal peripheral clocks using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
The peripheral can be assigned to different contexts/software components, depending on the final product needs. Refer to How to assign an internal peripheral to a runtime context article for guidelines on this configuration .
2. DT bindings documentation
- TF-A BL2:
- for STM32MP13x lines
docs/devicetree/bindings/clock/st,stm32mp13-rcc.txt
- for STM32MP15x lines
docs/devicetree/bindings/clock/st,stm32mp1-rcc.txt
- OP-TEE:
documentation/devicetree/bindings/clock/st,stm32mp13-rcc.yaml
- U-Boot, Linux® OS:
- for example: STM32MP1x device tree bindings: Documentation/devicetree/bindings/clock/st,stm32mp1-rcc.yaml
3. DT configuration
3.1. DT configuration (STM32/SoC level)
The RCC node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
The objective of this chapter is to explain how to configure a clock tree related to the board.
Using this chapter, the end-user can configure any
parameters via the DT to adapt to a new board.
3.2.1. STM32MP15x lines
Clock tree configuration it's only done in TF-A BL2. It is only copied in OP-TEE DT for a functional check purpose.
This an example a clock configuration tree:
&rcc {
st,clksrc = <
CLK_MPU_PLL1P
CLK_AXI_PLL2P
CLK_MCU_PLL3P
CLK_PLL12_HSE
CLK_PLL3_HSE
CLK_PLL4_HSE
CLK_RTC_LSE
CLK_MCO1_DISABLED
CLK_MCO2_DISABLED
st,clkdiv = <
1 /*MPU*/
0 /*AXI*/
0 /*MCU*/
1 /*APB1*/
1 /*APB2*/
1 /*APB3*/
1 /*APB4*/
2 /*APB5*/
23 /*RTC*/
0 /*MCO1*/
0 /*MCO2*/
st,pkcs = <
CLK_CKPER_HSE
CLK_FMC_ACLK
CLK_QSPI_ACLK
CLK_ETH_PLL4P
CLK_SDMMC12_PLL4P
CLK_DSI_DSIPLL
CLK_STGEN_HSE
CLK_USBPHY_HSE
CLK_SPI2S1_PLL3Q
/* VCO = 1066.0 MHz => P = 266 (AXI), Q = 533 (GPU), R = 533 (DDR) */
pll2: st,pll@1 {
compatible = "st,stm32mp1-pll";
reg = <1>;
cfg = <2 65 1 0 0 PQR(1,1,1)>;
frac = <0x1400>;
/* VCO = 417.8 MHz => P = 209, Q = 24, R = 11 */
pll3: st,pll@2 {
reg = <2>;
cfg = <1 33 1 16 36 PQR(1,1,1)>;
frac = <0x1a04>;
/* VCO = 594.0 MHz => P = 99, Q = 74, R = 74 */
pll4: st,pll@3 {
reg = <3>;
cfg = <3 98 5 7 7 PQR(1,1,1)>;
You can find a full example of the board configuration here stm32mp15xx-dkx.dtsi
3.2.2. STM32MP13x lines
Clock tree configuration it's done in TF-A and in OP-TEE.
Usually a minimal configuration is applied in TF-A BL2 and the full configuration in OP-TEE.
&rcc {
compatible = "st,stm32mp13-rcc", "syscon", "st,stm32mp13-rcc-mco";
pinctrl-0 = <&rcc_mco_pins_a>;
pinctrl-names = "default";
st,clksrc = <
CLK_MPU_PLL1P
CLK_AXI_PLL2P
CLK_MLAHBS_PLL3
CLK_RTC_LSE
CLK_MCO1_HSE
st,clkdiv = <
DIV(DIV_MPU, 1)
DIV(DIV_AXI, 0)
DIV(DIV_MLAHB, 0)
st,pll_vco {
pll3_vco_417_8Mhz: pll3-vco-417_8Mhz {
src = < CLK_PLL3_HSE >;
divmn = < 1 33 >;
frac = < 0x1a04 >;
pll4_vco_600Mhz: pll4-vco-600Mhz {
src = < CLK_PLL4_HSE >;
divmn = < 1 49 >;
pll3:st,pll@2 {
reg = <2>;
st,pll = < &pll3_cfg1 >;
pll3_cfg1: pll3_cfg1 {
st,pll_vco = < &pll3_vco_417_8Mhz >;
st,pll_div_pqr = < 1 16 36 >;
/* VCO = 600.0 MHz => P = 50, Q = 10, R = 50 */
pll4:st,pll@3 {
reg = <3>;
st,pll = < &pll4_cfg1 >;
pll4_cfg1: pll4_cfg1 {
st,pll_vco = < &pll4_vco_600Mhz >;
st,pll_div_pqr = < 11 59 11 >;
You can find a full example of the board configuration here stm32mp135f-dk.dts
5. References
