STM32MP15 U-Boot
This article briefly describes the STM32MP15x lines More info.png support in U-Boot.
1. STM32MP15x lines More info.png support
For detailed information, please read the file in the delivered U-Boot code = doc/board/st/stm32mp1.rst or the stm32mp1 documentation generated by make htlmdocs: board/st/stm32mp1.html.
Also available in official U-Boot Git.
Code :
Configuration Files:
The two next defconfig are kept only for compatibility with upstream, don't use them:
2. Selecting targets : choose defconfig and Device Tree
The STM32 MPU boot chain is supported by one U-Boot configuration with defconfig = stm32mp15_defconfig
Several boards are supported with the associated device-tree (same name as kernel):
Board part number Device tree Description
STM32MP157A-EV1 Evaluation board More info green.png stm32mp157a-ev1 MB1262+MB1263
STM32MP157C-EV1 Evaluation board More info green.png stm32mp157c-ev1
STM32MP157D-EV1 Evaluation board More info green.png stm32mp157d-ev1
STM32MP157F-EV1 Evaluation board More info green.png stm32mp157f-ev1
STM32MP157A-DK1 Discovery kit More info green.png stm32mp157a-dk1 MB1272
STM32MP157D-DK1 Discovery kit More info green.png stm32mp157d-dk1
STM32MP157C-DK2 Discovery kit More info green.png stm32mp157c-dk2 MB1272+MB1407
STM32MP157F-DK2 Discovery kit More info green.png stm32mp157f-dk2
For information the 'Evaluation' daughter-board only (MB1263 without MB1262) is also supported by stm32mp15*-ed1.dts device tree files.
3. Compilation
See U-Boot_overview#U-Boot_build with the defconfig file: stm32mp15_defconfig
 PC $> make stm32mp15_defconfig
 PC $> make DEVICE_TREE=<Device tree> all
The supported variables are:
  • DEVICE_TREE: select in arch/arm/dts the device tree that is used
  • KBUILD_OUTPUT: change the destination directory for the build
  • EXT_DTB: select external device tree
The ouput file u-boot.stm32' is only generated for stm32mp15_trusted_defconfig with CONFIG_STM32MP15x_STM32IMAGE; it is not more used for ecosystem release ≥ <span title="Main software components: unknown revision unknown revision unknown revision unknown revision unknown revision unknown revision unknown revision">v4.0.0 More info.png .
4. U-Boot integration in FIP
U-Boot binary and its associated device tree are part of the FIP binary, created with TF-A Makefile option :
  • BL33_CFG = u-boot.dtb
  • BL33 = u-boot-nodtb.bin
or updated with fiptools:
  • --hw-config u-boot.dtb
  • --nt-fw u-boot-nodtb.bin
Example for FIP update :
 PC $> fiptool --verbose update --nt-fw u-boot-nodtb.bin \
             --hw-config  u-boot.dtb \
             fip-<board>.bin
 DEBUG: Replacing nt-fw with.../u-boot-nodtb.bin
 DEBUG: Replacing hw-config with .../u-boot.dtb
 DEBUG: Metadata size: ... bytes
 DEBUG: Payload size: ... bytes
See How_to_configure_TF-A_FIP for details.
5. Examples
 PC $> make DEVICE_TREE=stm32mp157f-ev1 all
An existing FIP file is updated with:
 PC $> fiptool --verbose update --nt-fw u-boot-nodtb.bin --hw-config u-boot.dtb \
              fip-stm32mp157f-ev1.bin
 PC $> make DEVICE_TREE=stm32mp157c-ev1 all
              fip-stm32mp157c-ev1.bin
 PC $> make DEVICE_TREE=stm32mp157d-dk1 all
              fip-stm32mp157d-dk1.bin
Using export to select the device tree
 PC $> export KBUILD_OUTPUT=../build/stm32mp15
 PC $> export DEVICE_TREE=stm32mp157c-dk2
 PC $> make all
 PC $> fiptool --verbose update --nt-fw $KBUILD_OUTPUT/u-boot-nodtb.bin \
              --hw-config  $KBUILD_OUTPUT/u-boot.dtb \
              fip-stm32mp157c-dk2.bin
5.5. Custom board with external device tree
 PC $> make EXT_DTB=stm32mp151a-myboard.dtb all
Then you can create or update the FIP
