- briefly introduce the QUADSPI peripheral and its main features
- explain, when needed, how to configure the QUADSPI peripheral.
The Quad-SPI interface (QUADSPI peripheral) is used to interface the processor with serial NOR Flash and serial NAND Flash memories.
It supports:
- Single, dual or quad SPI Flash memories
- A dual-flash mode, allowing to agregate two Flash memories into a virtual single one
- Dual data rate and memory-mapped modes.
Refer to STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to know which features are really implemented.
2.2.1. On STM32MP13x lines
The QUADSPI is a secure peripheral (under ETZPC control).
2.2.2. On STM32MP15x lines
The QUADSPI is a non secure peripheral.
3. Using the peripheral - associated software[edit | edit source]
QUADSPI instance is boot device that support serial boot for Flash programming with STM32CubeProgrammer.
The QUADSPI instances can be allocated to:
- the Arm® Cortex®-A7 secure context, on STM32MP13x lines
only, but this is not supported in OpenSTLinux.
- the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the MTD framework
- the Arm® Cortex®-M4, on STM32MP15x lines
only, to be controlled in STM32Cube MPU Package by QUADSPI HAL driver
Chapter #Peripheral assignment describes which peripheral instances can be assigned to which context.
3.2.2.1. On STM32MP13x lines
OP-TEE | Linux | |||
Mass storage | QUADSPI | Linux MTD framework |
3.2.2.2. On STM32MP15x lines
Mass storage | QUADSPI | Linux MTD framework | STM32Cube QUADSPI driver |
For Linux kernel configuration, please refer to QUADSPI device tree configuration.
3.2.4.1. On STM32MP13x lines
Mass storage | QUADSPI | QUADSPI | ⬚ | ☐ | Assignment (single choice) |
3.2.4.2. On STM32MP15x lines
Cortex-M4 (STM32Cube) | |||
Mass storage | QUADSPI | QUADSPI | ☐ | ☐ | Assignment (single choice) |
