STM32MP15 U-Boot
This article briefly describes the STM32MP15x lines More info.png support in U-Boot.
1. STM32MP15x lines More info.png support
For detailed information, please read the file in the delivered U-Boot code = doc/board/st/stm32mp1.rst or the stm32mp1 documentation generated by make htlmdocs[1].
Also available in official U-Boot Git.
Code :
Configuration Files:
2. Selecting targets : choose defconfig and Device Tree
The STM32 MPU boot chain is supported by one U-Boot configuration with defconfig = stm32mp15_trusted_defconfig
Several boards are supported with the associated device-tree (same name as kernel):
Board part number Device tree Description
STM32MP157A-EV1 Evaluation board More info green.png stm32mp157a-ev1 MB1262+MB1263
STM32MP157C-EV1 Evaluation board More info green.png stm32mp157c-ev1
STM32MP157D-EV1 Evaluation board More info green.png stm32mp157d-ev1
STM32MP157F-EV1 Evaluation board More info green.png stm32mp157f-ev1
STM32MP157A-DK1 Discovery kit More info green.png stm32mp157a-dk1 MB1272
STM32MP157D-DK1 Discovery kit More info green.png stm32mp157d-dk1
STM32MP157C-DK2 Discovery kit More info green.png stm32mp157c-dk2 MB1272+MB1407
STM32MP157F-DK2 Discovery kit More info green.png stm32mp157f-dk2
For information the 'Evaluation' daughter-board only (MB1263 without MB1262) is also supported by stm32mp15*-ed1.dts device tree files.
3. Compilation
see U-Boot_overview#U-Boot_build
With the defconfig file: stm32mp15_trusted_defconfig
 PC $> make stm32mp15_trusted_defconfig
 PC $> make DEVICE_TREE=<Device tree> all
The supported variables are:
  • DEVICE_TREE: select in arch/arm/dts the device tree that is used
  • KBUILD_OUTPUT: change the destination directory for the build
  • EXT_DTB: select external device tree
The ouput file is u-boot.stm32 for ecosystem release ≤ v2.1.0 or if you activate CONFIG_STM32MP15x_STM32IMAGE in your defconfig for ecosystem release ≥ v3.0.0 More info.png (this temporary option is only introduced to facilitate the FIP migration but it will be removed in the next EcosystemRelease).
With FIP support for ecosystem release ≥ v3.0.0 More info.png , the offset on U-Boot environment in NOR are defined in the defconfig with:
 CONFIG_ENV_OFFSET=0x480000
 CONFIG_ENV_OFFSET_REDUND=0x4C0000
Without FIP support these MTD partition offsets in NOR for default flashlayout change and to reuse the ecosystem release ≤ v2.1.0 flashlayout the defconfig options become:
 CONFIG_STM32MP15x_STM32IMAGE=y
 CONFIG_ENV_OFFSET=0x280000
 CONFIG_ENV_OFFSET_REDUND=0x2C0000
4. U-Boot integration in FIP
U-Boot binary and its associated device tree are part of the FIP binary, created with TF-A Makefile option :
  • BL33_CFG = u-boot.dtb
  • BL33 = u-boot-nodtb.bin
or updated with fiptools:
  • --hw-config u-boot.dtb
  • --nt-fw u-boot-nodtb.bin
Example for FIP upddate of STM32MP157C-EV1 Evaluation board More info green.png:
 PC $> fiptool update --verbose --nt-fw u-boot-nodtb.bin \
             --hw-config  u-boot.dtb \
             tf-a-fip-stm32mp157c-ev1.bin
 DEBUG: Replacing nt-fw with.../u-boot-nodtb.bin
 DEBUG: Replacing hw-config with .../u-boot.dtb
 DEBUG: Metadata size: ... bytes
 DEBUG: Payload size: ... bytes
5. SPL compilation
6. Examples
 PC $> make DEVICE_TREE=stm32mp157f-ev1 all
 PC $> make DEVICE_TREE=stm32mp157c-ev1 all
 PC $> make DEVICE_TREE=stm32mp157d-dk1 all
Using export to select the device tree
 PC $> export KBUILD_OUTPUT=../build/stm32mp15_trusted
 PC $> export DEVICE_TREE=stm32mp157c-dk2
 PC $> make all
6.5. Custom board with external device tree
 PC $> make EXT_DTB=stm32mp151a-myboard.dtb all
