- briefly introduce the BSEC peripheral and its main features
- explain, when necessary, how to configure the BSEC peripheral.
2. Peripheral overview
The BSEC peripheral is used to control an OTP (one time programmable) fuse box, used for on-chip non-volatile storage for device configuration and security parameters.
2.1. Features
Refer to STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are implemented.
2.2. Security support
The BSEC is a secure peripheral.
3.1. Boot time
The BSEC is configured at boot time to set up platform security.
3.2. Runtime
3.2.1. Overview
The BSEC is a system peripheral and is controlled by the Arm® Cortex®-A7 secure:
3.2.2. Software frameworks
3.2.2.1. On STM32MP13x lines
OP-TEE | Linux | |||
Security | BSEC | OP-TEE BSEC driver | Linux NVMEM framework |
3.2.2.2. On STM32MP15x lines
The configuration is based on Device tree, please refer to BSEC device tree configuration article.
It can be applied by the firmware running in a secure context, done in TF-A or in OP-TEE.
It can also be configured by Linux® kernel, please refer to NVMEM overview article.
3.2.4. Peripheral assignment
3.2.4.1. On STM32MP13x lines
Security | BSEC | BSEC | ✓ | ✓ |
3.2.4.2. On STM32MP15x lines
Cortex-M4 (STM32Cube) | |||
4. How to go further
5. References
