SDMMC internal peripheral
  • briefly introduce the SDMMC peripheral and its main features
  • explain, when necessary, how to configure the SDMMC peripheral.
2. Peripheral overview
The SDMMC peripheral is used to interconnect STM32 MPU to SD memory cards, SDIO and MMC devices.
2.1. Features
Refer to the STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are implemented.
2.2. Security support
The SDMMC1/2 instances are secure peripherals (under ETZPC control).
The SDMMC1/2/3 instances are non-secure peripherals.
3.1. Boot time
SDMMC1/2 instances can be used to support memory boot on SD or MMC Flash devices.
The SDMMC3 (only present on STM32MP15x lines More info.png) is not used at boot time.
3.2. Runtime
3.2.1. Overview
On STM32MP13x lines More info.png only, the SDMMC1/2 instances can be allocated to the Arm® Cortex®-A7 secure context but this is not supported in OpenSTLinux.
All the SDMMC instances can be allocated to the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the MMC framework.
On STM32MP15x lines More info.png only, SDMMC3 can be allocated to the Arm® Cortex®-M4 to be controlled in STM32Cube MPU Package by STM32Cube SDMMC driver.
Chapter #Peripheral assignment describes which peripheral instance can be assigned to which context.
3.2.2. Software frameworks
OP-TEE Linux
Mass storage SDMMC Linux MMC framework
OP-TEE Linux STM32Cube
Mass storage SDMMC Linux MMC framework STM32Cube SDMMC driver
For Linux® kernel configuration, please refer to SDMMC device tree configuration.
3.2.4. Peripheral assignment
non-secure
Mass storage SDMMC SDMMC1 Assignment (single choice)
SDMMC2 Assignment (single choice)
non-secure
Cortex-M4
SDMMC2
SDMMC3 Assignment (single choice)
4. References
