Template:ArticleMainWriter
- briefly introduce the HDP peripheral (hardware debug port) and its main features
- explain, when needed, how to configure the HDP peripheral.
2. Peripheral overview
The HDP peripheral is used to output some internal signals on up to 8 GPIO pins.
Follow the sequence below to connect a GPIO to an internal signal via the HDP:
- First of all, look for the internal signal you want to monitor in the HDP signal multiplexing table of the STM32MP15 reference manuals:
- Search for the HDP signal on which you can get it among eight possible choices.
- Note the corresponding HDPx multiplexing value to select.
- Then, look for the most suitable GPIO pin on which you can output HDPx in the data brief:
The GPIO bank, pin, alternate function and HDPx multiplexing value are the information required to configure each HDP signal.
2.1. Features
2.2. Security support
The HDP is a non-secure peripheral.
3.1. Boot time
The HDP is not used at boot time.
3.2. Runtime
3.2.1. Overview
The HDP can be allocated to the Arm® Cortex®-A7 non-secure core to be used under Linux® HDP driver.
3.2.2. Software frameworks
HDP | | HDP Linux driver | | |- |}| Trace & Debug |
3.2.4. Peripheral assignment
HDP | HDP | | ☐ | | |-| rowspan="1" | Trace & Debug | rowspan="1" |
