TIM device tree configuration
Template:ReviewsComments
The purpose of this article is to explain how to configure the timer (TIM)[1] when the peripheral is assigned to Linux® OS:
  • Configuring the timer peripheral to enable PWM, trigger or quadrature encoder.
  • Configuring the board, e.g. TIM pins.
It is used by the TIM Linux driver that registers relevant information in PWM and IIO frameworks.
2. DT bindings documentation
The TIM internal peripheral[1] is a multifunction device (MFD).
Each function is represented by a separate DT binding document:
  • STM32 TIM MFD device tree bindings[3] document deals with core resources (e.g. registers, clock, DMAs)
  • STM32 TIM PWM device tree bindings[4] document deals with PWM resources (e.g. PWM input/output pins)
  • STM32 TIM IIO trigger/encoder device tree bindings[5] document deals with other internal peripheral triggering and quadrature encoder resources
3. DT configuration
This hardware description is a combination of both STM32 microprocessor and board device tree files. Refer to Device tree for more explanations about device tree file split.
TIM nodes are declared in stm32mp157c.dtsi[6].
DT root node (e.g. timers1...) and DT child nodes describe the TIM features such as:
  • PWM
  • trigger and quadrature encoder
They also describe hardware parameters such as registers address, clock and DMA.
timers1: timer@address {
	compatible = "st,stm32-timers";                      Template:Highlight
	pwm {
		compatible = "st,stm32-pwm";                 Template:Highlight
	timer@0 {
		compatible = "st,stm32h7-timer-trigger";     Template:Highlight
		reg = <0>;                                   Template:Highlight
Template:Warning
This part is used to configure and enable the TIM hardware used on the board:
  • Enabling DT root node for the TIM instances in use (e.g timers1...) by setting status = "okay";
  • Enabling DT child node(s) for the feature(s) in use (PWM input/output, trigger and quadrature encoder) by setting status = "okay";
  • Configuring pins in use via pinctrl through pinctrl-0, pinctrl-1 and pinctrl-names.
3.3.1. TIM configured in PWM mode and trigger source
The example below shows how to configure TIM1 channel 1 to act as:
Note: The PWM output does not require any DMA channel. Disable them if they are configured by default in the .dtsi file.
pwm1_pins_a: pwm1-0 {
	pins {
		pinmux = <STM32_PINMUX('E', 9, AF1)>;        Template:Highlight
		bias-pull-down;
		drive-push-pull;
		slew-rate = <0>;
pwm1_sleep_pins_a: pwm1-sleep-0 {
	pins {
		pinmux = <STM32_PINMUX('E', 9, ANALOG)>;     Template:Highlight
&timers1 {
	status = "Template:Highlight";
	/delete-property/dmas;                               Template:Highlight
	/delete-property/dma-names;
	pwm {
		pinctrl-0 = <&pwm1_pins_a>;                  Template:Highlight
		pinctrl-1 = <&pwm1_sleep_pins_a>;
		status = "Template:Highlight";                             Template:Highlight
	timer@0 {
3.3.2. TIM configured in PWM input capture mode
The example below shows how to configure TIM1 channel 1 in PWM input capture mode (e.g. period and duty cycle):
A DMA channel is required and must be configured depending on the PWM input channel:
  • Select DMA channel 1, "ch1", to capture PWM input channel 1 and/or 2
  • Select DMA channel 3, "ch3", to capture PWM input channel 3 and/or 4
pwm1_in_pins_a: pwm1-in-0 {
	pins {
		bias-disable;
pwm1_in_sleep_pins_a: pwm1-in-sleep-0 {
	pins {
&timers1 {
	dmas = <&dmamux1 11 0x400 0x5>;                      Template:Highlight
	dma-names = "ch1";
	pwm {
		pinctrl-0 = <&pwm1_in_pins_a>;               Template:Highlight
		pinctrl-1 = <&pwm1_in_sleep_pins_a>;
3.3.3. TIM configured as quadrature encoder interface
The example below shows how to configure TIM1 to interface with a quadrature encoder:
tim1_in_pins_a: tim1-in-pins-0 {
	pins {
		pinmux = <STM32_PINMUX('E', 9, AF1)>, /* TIM1_CH1 */
			 <STM32_PINMUX('J', 11, AF1)>; /* TIM1_CH2 */
		bias-disable;
tim1_in_pins_sleep_a: tim1-in-pins-sleep-0 {
	pins {
		pinmux = <STM32_PINMUX('E', 9, ANALOG)>, /* TIM1_CH1 */
			 <STM32_PINMUX('J', 11, ANALOG)>; /* TIM1_CH2 */
&timers1 {
	timer@0 {
		pinctrl-0 = <&tim1_in_pins_a>;               Template:Highlight
		pinctrl-1 = <&tim1_in_pins_sleep_a>;
5. References
  1. Jump up to: 1.0 1.1 TIM internal peripheral
  2. Device tree
  3. Template:CodeSource, STM32 TIM MFD device tree bindings
  4. Template:CodeSource, STM32 TIM PWM device tree bindings
  5. Template:CodeSource, STM32 TIM trigger/encoder device tree bindings
  6. Template:CodeSource, STM32.dtsi file
