ETH internal peripheral
  • briefly introduce the ETH peripheral and its main features,
  • indicate the assignment of the peripheral instances at boot time and their assignment at runtime (including whether instances can be allocated to secure contexts),
2. Peripheral overview
The ETH peripheral is based on Synopsys DesignWare® Ethernet GMAC IP, which enables the host to communicate data using the Gigabit Ethernet protocol (IEEE 802.3) at 10, 100 and 1000 Mbps.
The peripheral is composed of three main layers: the gigabit ethernet media access controller (GMAC), the MAC transaction layer (MTL), and the MAC DMA controller (MDC). The driver used to drive the ETH is Stmmac.
The Ethernet peripheral main features are the following:
  • Compliance with IEEE 802.3 specifications
  • Support for IEEE 1588-2002 and IEEE 1588-2008 standards for precision networked clock synchronization
IEEE 802.3-az for Energy Efficient Ethernet (EEE)
IEEE 802.3x flow control automatic transmission of zero-quanta pause frame on flow control input de-assertion.
IEEE 802.1Q VLAN tag detection for reception frames on STM32MP15x lines More info.png only
AMBA 2.0 for AHB Master/Slave ports and AMBA 3.0 for AXI Master/Slave ports
  • Configurability allowing to support data transfer rates of 10/100/100 Mbps, 10/100 Mbps only or 1000 Mbps only
  • Support for multiple TCP/IP offload functions
3. Peripheral usage
3.1. Boot time assignment
3.1.1. On STM32MP1 series
The Ethernet peripheral can be used at boot time by SSBL (by UBoot with tftp protocol for image loading). See How to boot the kernel via TFTP from U-Boot for more details.
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Networking ETH Any instance Assignment (single choice)
3.1.2. On STM32MP2 series
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
Networking ETH ETH1
ETH2
3.2. Runtime assignment
non-secure
Networking ETH ETH1 Assignment (single choice)
ETH2 Assignment (single choice)
non-secure
Cortex-M4
Networking ETH ETH Assignment (single choice)
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
Networking ETH ETH1 OP-TEE
ETH2 OP-TEE
Below are listed the software frameworks and drivers managing the XXX peripheral for the embedded software components listed in the above tables.
  • generation of partial device trees (pin control and clock tree) for the OpenSTLinux software components,
When the Ethernet peripheral is assigned to the Linux® OS, it is configured through the device tree according to the information given in the Ethernet device tree configuration article.
