Ifconfig
This article provides the basic information needed to start using the Linux® kernel tool: ifconfig[1].
No Developer Package is presently delivered.
The tool (even if marked as present) has not been yet tested with the current release.
ifconfig Monitoring tools ifconfig[1] is a system administration utility for network interface configuration.
ifconfig is deprecated and has been replaced by ip (A web page provides a comparison between ifconfig and ip [2])
Yes Yes Yes Yes No Yes
ifconfig is installed by default and ready to be used with all STM32MPU Embedded Software Packages.
It comes with the busybox:
which ifconfig | xargs ls -la
/sbin/ifconfig -> /bin/busybox.nosuid
3.2. Using the STM32MPU Embedded Software distribution for Android™[edit | edit source]
ifconfig is installed by default and ready to be used with all STM32MPU Embedded Software Packages for Android™.
It comes with the toybox:
/system/bin/ifconfig -> toybox
Follow the sequence described below to get started with the ifconfig tool.
Android logo.png Below information is related to the Android™ distribution
Need to enable root access rights for any changes
  • Using ADB shell is ADB link available:
adb root
adb shell
  • Using uart console shell:
su
4.1. List the available network interfaces[edit | edit source]
ifconfig
end0      Link encap:Ethernet  HWaddr 00:80:E1:42:43:65
          inet addr:10.48.1.144  Bcast:10.48.3.255  Mask:255.255.252.0
          inet6 addr: fe80::280:e1ff:fe42:4365%lo/64 Scope:Link
          RX packets:181274 errors:0 dropped:14553 overruns:0 frame:0
          TX packets:28583 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:23082127 (22.0 MiB)  TX bytes:6438412 (6.1 MiB)
          Interrupt:66 Base address:0x4000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1%1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:202 errors:0 dropped:0 overruns:0 frame:0
          TX packets:202 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13454 (13.1 KiB)  TX bytes:13454 (13.1 KiB)
4.2. Disable the network interface[edit | edit source]
Please make sure that no remote terminal is connected through this network (ssh), otherwise you will lost your shell connection.
  • For example, proceed as follows for end0
ifconfig end0 down
4.3. Enable the network interface if it is not already available[edit | edit source]
ifconfig end0 up
4.4. Assign a given IP address to a network interface[edit | edit source]
  • Proceed as follows to assign 10.48.1.324 address to end0
ifconfig end0 10.48.1.324
Refer to the man page[1] for more details on command options.
