DBGMCU internal peripheral
  • briefly introduce the DBGMCU peripheral and its main features,
The DBGMCU peripheral is used by the boot chain and by OP-TEE to get the device ID and revision, to adapt their behavior accordingly.
The DBGMCU peripheral is also used to configure internal peripherals behavior when one of the available cores enters in debug mode.
During a debug session, the DBGMCU can be accessed via the debug access port (DAP) to configure the expected behavior on break, typically to get a watchdog (IWDG) frozen when the Cortex®-A enters in debug mode (via a breakpoint or JTAG break) and to avoid getting a watchdog reset during a debug session.
On STM32MP25x lines More info.png only, each peripheral freeze bit inherit the permissions that are set on the same peripheral it controls.
3.1.1. On STM32MP13x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Trace & Debug DBGMCU DBGMCU
3.1.2. On STM32MP15x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
3.1.3. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
non-secure
non-secure
Cortex-M4
3.2.3. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
There is no software dedicated to the DBGMCU internal peripheral delivered with STM32MPU ecosystem. Nevertheless, debuggers like STM32CubeIDE and OpenOCD can use the DBGMCU to freeze DMA and timer execution during step by step debugging.
