Sysprof
This article provides the basic information needed to start using the Linux kernel tool: sysprof[1].
sysprof Monitoring tools sysprof[1] is a statistical, system-wide profiler for Linux. It helps in finding the functions in which a program spends most of its time.
sysprof proposes a user interface available directly on the board display screen.
Yes Yes Yes No No No
3.1. Using STM32MPU Embedded Software distribution[edit | edit source]
sysprof is installed by default and ready to be used with all STM32MPU Embedded Software Packages.
which sysprof
/usr/bin/sysprof
Sysprof is integrated in weston image distribution through packagegroup-framework-tools-kernel package defined in meta-st-openstlinux/recipes-st/packagegroups/packagegroup-framework-tools.bb.
SUMMARY:packagegroup-framework-tools-kernel = "Framework tools components for kernel"
RDEPENDS:packagegroup-framework-tools-kernel = "\
    cpufrequtils    \
    sysfsutils      \
    dosfstools      \
    mmc-utils       \
    blktool         \
    mtd-utils-ubifs \
    sysprof         \
  • Starting sysprof on the board: Need to specify the display to be used, for example:
sysprof --display=/run/user/1000/$WAYLAND_DISPLAY
Sysprof proposes a User interface through the board X interface to the display. It might be more convenient to plug a mouse (and optionally a keyboard) to use the tool interface.
  • Recording
Clicking on the top left Record button launches the recording. Recording is stopped by clicking on the top left Stop button (that replaces the record button).
The following report is then available on the board display:
Several options are available to the user in order to filter the report, and then study the results:
  • Possibility to browse on Functions list, Descendants list
  • Possibility to select a certain period of the CPUs graph.
  • Possibility to save traces, to make screen shots...
  • Useful external links
Sysprof from Gnome Standard Wiki page
Profiling using Sysprof User manual Linux.com
