RNG internal peripheral
  • Briefly introduce the RNG peripheral and its main features,
  • Indicate the peripheral instances assignment at boot time and their assignment at runtime (including whether instances can be allocated to secure contexts),
  • List the software frameworks and drivers managing the peripheral,
  • Explain how to configure the peripheral.
2. Peripheral overview
The RNG peripheral is used to provide 32-bit random numbers.
The RNG can be assigned to non-secure or secure world (default behavior). If the RNG is assigned to the secure world then the non-secure world can request random numbers through the OP-TEE RNG PTA. More information about this mechanism can be found in OP-TEE documentation [1]. Else, the software component uses its RNG driver directly.
What is applicable for the Linux Kernel is applicable for U-Boot.
3. Peripheral usage
The hardware RNG peripheral for Arm® Cortex®-A processor is default assigned to OP-TEE. This is the default and recommended setup.
It is possible to assign the RNG to the Linux Kernel, but it is necessary to deactivate it in OP-TEE device tree and activate it in the Linux kernel device tree, declare it as a firewall exception in the OP-TEE firewall driver and declare your board in the flavorlist-no_rng in the OP-TEE board configuration makefile .
3.1. Boot time assignment
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security RNG RNG Required for DPA peripheral protection
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security RNG RNG1
3.1.3. On STM32MP2 series
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
non-secure
(U-Boot)
Security RNG RNG
3.2. Runtime assignment
If the Arm® Cortex®-A processor hardware RNG peripheral is assigned to OP-TEE, then the Linux Kernel can request random numbers through the hardware random framework which is interfaced with the OP-TEE RNG Linux driver .
If the Arm® Cortex®-A processor hardware RNG peripheral is assigned to the Linux Kernel, then the Linux Kernel can access it through the hardware random framework which is interfaced with the Linux RNG driver .
non-secure
Security RNG RNG Assignment (single choice)
non-secure
Cortex-M4
Security RNG RNG1 Assignment (single choice)
RNG2
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
non-secure
Cortex-M33
(TF-M)
Cortex-M33
non-secure
Cortex-M0+
Security RNG RNG OP-TEE
Below are listed the software frameworks and drivers managing the RNG peripheral for the embedded software components listed in the above tables.
This configuration is done in OP-TEE, through device tree.
Refer to RNG device tree configuration.
6. References
