STM32MP15 MCU SRAM internal memory
  • briefly introduce the MCU SRAM internal memory peripheral and its main features,
2. Peripheral overview
The MCU SRAM peripheral is 384-Kbyte wide and physically near to the Cortex®-M4 for optimized performances from this core. It is split into four separate banks:
  • MCU SRAM1 (128 Kbytes)
  • MCU SRAM2 (128 Kbytes)
  • MCU SRAM3 (64 Kbytes)
  • MCU SRAM4 (64 Kbytes)
Those banks have individual security control (see security support in the runtime assignment table below) and automatic clock gating (for power management optimization), but they are not supplied when the system goes to Standby low power mode, so their content is lost in that case.
3. Peripheral usage
3.1. Boot time assignment
The ROM code uses the MCU SRAM1 to store the USB context during a boot on USB for Flash programming (with STM32CubeProgrammer).
Linux remoteproc framework (running on the Cortex®-A7) loads the Cortex®-M4 firmware code into the MCU SRAM, except the exception table that must be loaded in the RETRAM since the Cortex®-M4 is looking for its reset entry point at address 0x00000000. The overall memory mapping is shown in the platform memory mapping section.
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Core/RAM MCU SRAM Any instance
3.2. Runtime assignment
non-secure
Cortex-M4
Core/RAM MCU SRAM SRAM1 Assignment (between A7 S and A7 NS / M4)
Shareable (between A7 NS and M4)
SRAM2 Assignment (between A7 S and A7 NS / M4)
SRAM3 Assignment (between A7 S and A7 NS / M4)
SRAM4 Assignment (between A7 S and A7 NS / M4)
Below are listed the software frameworks and drivers managing the XXX peripheral for the embedded software components listed in the above tables.
Notice the and/or allocation between Cortex®-A7 non-secure and Cortex®-M4, meaning that it is possible to share banks between those cores, typically to realize inter process communication between RPMsg on Linux side and OpenAMP on STM32Cube side.
The default assignement set in STMicroelectronics distribution is in line with the platform memory mapping, that can be adapted by the platform user.
The several SRAM banks are accessible via different address ranges in order to benefit from the Cortex-M4 multiple ports.
