GPU internal peripheral
  • briefly introduce the GPU peripheral and its main features
  • explain, when necessary, how to configure the GPU peripheral.
The GPU peripheral is a dedicated graphics processing unit. It accelerates numerous 3D graphics applications such as graphical user interface (GUI), menu display or animations. It works together with an optimized software stack designed for industry-standard APIs and supporting AndroidTM and Linux® embedded development platforms.
2.1. Features[edit source]
The GPU is a non-secure peripheral.
3.1. Boot time[edit source]
The GPU is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The GPU internal peripheral is allocated to the Arm® Cortex®-A7 non-secure core running the Linux® userland.
OP-TEE Linux STM32Cube
Visual GPU OpenGL®ES framework
The configuration is applied by the firmware running in the context to which the peripheral is assigned. The configuration can be done alone via the STM32CubeMX tool for all internal peripherals, and then manually completed (particularly for external peripherals), according to the information given in the corresponding software framework article, and in the GPU device tree configuration article for Linux®.
non-secure
Cortex-M4
Visual GPU GPU
Please go through the articles belonging to the GPU category.
