SPI overview
  • how to activate the SPI interface on a Linux® BSP
  • how to access the SPI from kernel space
  • how to access the SPI from user space.
1. Framework purpose
The Linux kernel provides a specific framework for SPI[1] protocol support. The SPI (serial peripheral interface) is a synchronous serial communication interface used for short distance communications, mainly in embedded systems.
SPI devices communicate either in Full duplex, Half duplex, or Simplex (rx/tx) mode using a master-slave architecture with a single master.
2. System overview
2.1. Component description
2.1.1. Board external SPI devices
Master/Slave devices 'X' are physical devices (connected to the STM32 microprocessor via an SPI bus) that behave as slaves or master with respect to the STM32.
The STM32 is the SPI bus controller.
A chip select signal allows selecting independently each device.
2.1.2. STM32 SPI internal peripheral controller
2.1.3. STM32 QSPI internal peripheral controller
The STM32 QSPI controller can handles external SPI devices connected to the same bus.
For more information about STM32 QSPI internal peripherals, please refer to QUADSPI_internal_peripheral#Peripheral_overview
2.1.4. spi-stm32
The STM32 SPI controller driver offers an ST SPI internal peripheral abstraction layer to the spi-core.
It defines all the SPI transfer methods to be used by the SPI core base.
2.1.5. spi-core
  • As stated by its name, this is the SPI engine. It is also in charge of parsing device tree entries both for adapter and devices. It implements the standard SPI modes: 0, 1, 2 and 3.
2.1.6. Device drivers
2.1.7. spidev
2.1.8. Application
2.2. API description
2.2.1. User space application
  • /dev/spidevB.C: character special device created by "udev" that is used by the user space application to control and transfer data to the SPI device.
Supported system calls : open(), close(), read(), write(), ioctl(), llseek(), release().
Supported ioctls commands
Constant Description
SPI_IOC_RD_MODE, SPI_IOC_WR_MODE Gets/sets SPI transfer mode
SPI_IOC_RD_LSB_FIRST, SPI_IOC_WR_LSB_FIRST Gets/sets bit justification used to transfer SPI words.
SPI_IOC_RD_BITS_PER_WORD, SPI_IOC_WR_BITS_PER_WORD Gets/sets the number of bits in each SPI transfer word.
SPI_IOC_RD_MAX_SPEED_HZ, SPI_IOC_WR_MAX_SPEED_HZ Gets/sets the maximum SPI transfer speed in Hz.
2.2.2. Kernel space peripheral driver
3. Configuration
3.1. Kernel configuration
[x] Device Drivers
    [x] SPI support
        *** SPI Master Controller Drivers ***
        [x] STMicroelectronics STM32 SPI controller
        *** SPI Protocol Masters ***
        [x] User mode SPI device driver support
        [x] SPI slave protocol handlers
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
CONFIG_SPI_SLAVE=y
CONFIG_SPI_STM32=y
CONFIG_SPI_SPIDEV=y
4. How to use the framework
Detailed information on how to write an SPI device driver to control an SPI device are available in the Linux kernel documentation[5].
User-space examples can be found in How to use SPI from Linux userland with spidev.
5.1. How to trace
5.1.1. Activating SPI framework debug messages
[x] Device Drivers
    [x] SPI support
        [x] Debug support for SPI drivers
CONFIG_SPI=y
CONFIG_SPI_DEBUG=y
CONFIG_SPI_MASTER=y
5.1.2. Dynamic trace
  echo  "file spi* +p" > /sys/kernel/debug/dynamic_debug/control
5.2. How to debug
5.2.1. Detecting SPI configuration
5.2.1.1. sysfs
When a peripheral is instantiated, the spi-core and the kernel export several files through the sysfs :
  • /sys/class/spi_master/spix shows all the instantiated SPI buses, 'x' being the SPI bus number.
  • /sys/bus/spi/devices lists all the instantiated peripherals. For example, the repository named spi0.0 corresponds to the peripheral connected to SPI bus 0 and chip select 0. Below an example representing the "TPM" device:
  • /sys/bus/spi/drivers lists all the instantiated drivers. The tpm_tis_spi/ repository is the driver of TPM 2.0. The spidev/ repository is the generic driver of SPI user mode.
/sys/bus/spi/devices/spi0.0/
            /drivers/tpm_tis_spi/spi0.0/
            /drivers/spidev/...
                     /spi1/
                     /spi2/
5.2.2. devfs
  • 'x' is the SPI bus number
  • 'y' is the chip select index on the bus.
/dev/spi4.2
6. Source code location
7. References
