STM32MP13 VREFBUF internal peripheral
  • briefly introduce the VREFBUF peripheral and its main features
  • explain, when needed, how to configure the VREFBUF peripheral.
2.1. Features[edit source]
The VREFBUF is supplied via the VDDA pin. When enabled, it can provide a reference voltage in the range of: 1,65V, 1,8V, 2,048V or 2,5V. The VREFBUF can be used to provide an analog voltage reference for:
  • ADC internal peripheral[1]
  • External components through the dedicated VREF+ pin.
Refer to the STM32MP13 reference manuals for the complete list of features, and to the software components, introduced below, to know which features are really implemented.
The VREFBUF is a secure peripheral (under ETZPC control).
3.1. Boot time[edit source]
The VREFBUF is usually not used at boot time. But it may be needed by the SSBL (see Boot chain overview), to supply the internal ADC[1] for example.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The VREFBUF can be allocated to:
  • The Arm® Cortex®-A7 secure to be used under OP-TEE SCMI regulator framework</ref>.
  • The Arm® Cortex®-A7 non-secure to be used under Linux® with regulator framework[2].
The Peripheral assignment chapter describes which peripheral instance can be assigned to which context.
As soon as one VREFBUF client peripheral (ADC1 or ADC2) is set secure, the VREFBUF should be set secure
OP-TEE Linux
Analog VREFBUF OP-TEE SCMI Linux regulator framework
non-secure
Analog VREFBUF VREFBUF Assignment (single choice)
VREFBUF should be secured whenever one ADC is secured. VREFBUF must not be secured when all ADC are non-secured.
4. References[edit source]
  1. 1.0 1.1 ADC internal peripheral
  2. Regulator overview, Linux® regulator framework overview
