HSEM device tree configuration
Revision as of 16:56, 26 October 2022 by Registered User
This article explains how to configure the HSEM internal peripheral controlled by the Linux® Hardware spinlock framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the HSEM peripheral, used by the STM32 HSEM Linux driver.
The HSEM internal peripheral is represented by:
  • The generic hwlock device tree bindings[1]
  • The STM32 hardware spinlock device tree bindings[2]
The HSEM peripheral node is located in stm32mp151.dtsi [3] file.
hsem: hwspinlock@4c000000 {
	compatible = "st,stm32-hwspinlock";
	#hwlock-cells = <2>;
	reg = <0x4c000000 0x400>;
	clocks = <&rcc HSEM>;
	clock-names = "hsem";
Below is an example of an HSEM user device:
pinctrl: pin-controller@50002000 {
	hwlocks = <&hsem 0 1>;
The pincrl device uses the semaphore ID 0 (first number) and this semaphore can be shared (second number = 1, meaning shared usage), which means it is used by another device.
