- briefly introduce the HDP peripheral (hardware debug port) and its main features
- explain, when needed, how to configure the HDP peripheral.
2. Peripheral overview
The HDP peripheral is used to output some internal signals on up to 8 GPIO pins.
Follow the sequence below to connect a GPIO to an internal signal via the HDP:
- First of all, look for the internal signal you want to monitor in the HDP signal multiplexing table of the STM32MP13 reference manuals or STM32MP15 reference manuals:
- Search for the HDP signal on which you can get it among eight possible choices.
- Note the corresponding HDPx multiplexing value to select.
- Then, look for the most suitable GPIO pin on which you can output HDPx (in the datasheets for STM32MP13x lines
and datasheets for STM32MP15x lines
The GPIO bank, pin, alternate function and HDPx multiplexing value are the information required to configure each HDP signal.
2.1. Features
Refer to STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to know which features are really implemented.
2.2. Security support
The HDP is a non-secure peripheral.
3.1. Boot time
The HDP is not used at boot time.
3.2. Runtime
3.2.1. Overview
The HDP can be allocated to the Arm® Cortex®-A7 non-secure core to be used under Linux® HDP driver.
3.2.2. Software frameworks
3.2.2.1. On STM32MP13x lines
OP-TEE | Linux | |||
Trace & Debug | HDP | HDP Linux driver |
3.2.2.2. On STM32MP15x lines
3.2.4. Peripheral assignment
3.2.4.1. On STM32MP13x lines
Trace & Debug | HDP | HDP | ☐ |
3.2.4.2. On STM32MP15x lines
Cortex-M4 (STM32Cube) | |||
