Calibration device tree configuration
The purpose of this article is to explain how to configure the OP-TEE Calibration service using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
The device tree binding documents are stored in the given applicable components listed:
The Calibration node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
3.1.1. STM32MP13x lines More info.png[edit source]
By default, Timer12 is the counter used by both HSI/CSI calibration node at SoC level.
3.1.2. STM32MP15x lines More info.png[edit source]
By default, Timer15 is the counter used by both HSI/CSI calibration node at SoC level.
The objective of this chapter is to explain how to enable and configure the calibration DT nodes for a board.
Configuration should be done in specific board device tree files (board dts file).
By default, both HSI/CSI calibration are disabled. It must be explicitly enable at board level.
Here is an example for CSI calibration activation:
&csi-calibration {
	status = "okay";
Here is an example for HSI calibration activation with a counter update:
&hsi-calibration {
	counter = <&timers15 0 7>;
	status = "okay";
The timer channel entry is SoC specific for the internal signal calibration. Refer to How to configure the DT using STM32CubeMX for more details
