GIC internal peripheral
  • briefly introduce the GIC peripheral (generic interrupt controller) and its main features
  • explain, when needed, how to configure the GIC peripheral.
The GIC peripheral is the Arm® Cortex®-A7 interrupt controller.
It is consequently not accessible from the Arm® Cortex®-M4 core on STM32MP15x lines More info.png.
2.1. Features[edit source]
Refer to STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to know which features are really implemented.
The GIC is a secure peripheral (under ETZPC control).
3.1. Boot time[edit source]
The GIC is configured by the FSBL (see Boot chain overview), mainly to define the routing of each interrupt to the secure or non-secure context at runtime.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The GIC is shared between:
  • the Arm® Cortex®-A7 secure core to be used under OP-TEE with the GIC OP-TEE driver (or TF-A secure monitor if the OP-TEE is not present)
  • the Arm® Cortex®-A7 non-secure core to be used under Linux® with the interrupts framework
OP-TEE Linux
Core/Interrupts GIC OP-TEE GIC driver Linux interrupt framework
OP-TEE Linux STM32Cube
non-secure
Core/Interrupts GIC GIC
non-secure
Cortex-M4
