DTS internal peripheral
The DTS peripheral is used to monitor the device temperature and take some preventive action (like frequency scaling or peripheral disabling) in case it is becoming too high and before destroying the component.
1.1. Features[edit source]
Refer to the STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features , and to the software components, introduced below, to see which features are implemented.
The DTS is a non secure peripheral.
2.1. Boot time[edit source]
DTS is not used at boot time.
2.2. Runtime[edit source]
2.2.1. Overview[edit source]
The monitoring is done from the Cortex-A7 non-secure context with Linux® thermal management framework.
2.2.2.1. On STM32MP13x lines More info.png[edit source]
OP-TEE Linux
Power & Thermal DTS Linux thermal framework
2.2.2.2. On STM32MP15x lines More info.png[edit source]
OP-TEE Linux STM32Cube
2.2.4.1. On STM32MP13x lines More info.png[edit source]
non-secure
Power & Thermal DTS DTS
2.2.4.2. On STM32MP15x lines More info.png[edit source]
non-secure
Cortex-M4
3. References[edit source]
