- briefly introduce the CRYP peripheral and its main features
- explain how to configure the CRYP peripheral.
The CRYP peripheral provides hardware acceleration to encrypt or decrypt data using the DES[1], TDES[2] or AES[3] algorithms. It also supports multiple key sizes and chaining modes.
2.1. Features[edit source]
Refer to STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are implemented.
2.2.1. On STM32MP13x lines
[edit source]
CRYP is a secure peripheral (under ETZPC control).
2.2.2. On STM32MP15x lines
[edit source]
CRYP1 is a secure peripheral (under ETZPC control).
CRYP2 is a non secure peripheral.
3.1. Boot time[edit source]
3.1.1. On STM32MP13x lines
[edit source]
CRYP could be used in ROM code during boot process for FSBL decryption.
3.1.2. On STM32MP15x lines
[edit source]
CRYP peripheral is not used during boot process.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
3.2.1.1. On STM32MP13x lines
[edit source]
CRYP instance can be allocated to:
- the Arm® Cortex®-A7 secure core to be controlled in OP-TEE by the CRYP OP-TEE driver
- The Arm® Cortex® -A7 non-secure for using in Linux® with Linux Crypto framework
3.2.1.2. On STM32MP15x lines
[edit source]
CRYP1 instance can be allocated to:
CRYP2 instance can be allocated to:
- the Arm® Cortex®-M4 to be controlled in STM32Cube MPU Package by STM32Cube CRYP driver
3.2.2.1. On STM32MP13x lines
[edit source]
OP-TEE | Linux | |||
Security | CRYP | CRYP OP-TEE driver | Linux Crypto framework |
3.2.2.2. On STM32MP15x lines
[edit source]
Security | CRYP | CRYP OP-TEE driver | Linux Crypto framework | STM32Cube CRYP driver |
3.2.4.1. On STM32MP13x lines
[edit source]
Security | CRYP | CRYP | ☐ | ☐ | Assignment (single choice) |
3.2.4.2. On STM32MP15x lines
[edit source]
Cortex-M4 (STM32Cube) | |||
Security | CRYP | CRYP1 | ☐ | ☐ | Assignment (single choice) | |
CRYP2 | ☐ |
4. References[edit source]
