DCMIPP internal peripheral
Revision as of 22:50, 21 March 2022 by Registered User
  • briefly introduce DCMIPP peripheral and its main features
  • explain, when needed, how to configure DCMIPP peripheral.
The DCMIPP (digital camera memory interface pixel processor) is an STM32 internal peripheral allowing the reception of video data from an external parallel camera sensor device, or from any other digital video equipment supporting a parallel interface.
The DCMIPP hardware block can receive various frame data formats such as: RAW8, RGB565, YUV422 and other formats, as well as compressed data such as JPEG.
2.1. Features[edit source]
Refer to STM32MP13 reference manuals for the complete list of features, and to the software components introduced below, to see which features are actually implemented.
The DCMIPP is a non-secure peripheral.
3.1. Boot time[edit source]
The DCMIPP is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The DCMIPP internal peripheral can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be used under Linux® with the V4L2 framework
  • the Arm® Cortex® -M4 core to be used with STM32Cube MPU Package with DCMIPP HAL driver
OP-TEE Linux
Visual DCMIPP V4L2 framework
The configuration is applied by the firmware running in the context to which the peripheral is assigned. The configuration can be done alone via the STM32CubeMX tool for all internal peripherals. It can then be manually completed (particularly for external peripherals), according to the information given in the corresponding software framework article, or in the DCMIPP device tree configuration article for Linux®.
non-secure
Visual DCMIPP DCMIPP
4. References[edit source]
