STM32MP15 RNG internal peripheral
  • briefly introduce the RNG peripheral and its main features
  • explain how to configure the RNG peripheral.
The RNG peripheral is used to provide 32-bit random numbers.
2.1. Features[edit source]
RNG1 is a secure peripheral (under ETZPC control).
RNG2 is a non-secure peripheral.
3.1. Boot time[edit source]
RNG instances are not used as boot devices.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
RNG instances can be allocated to:
Chapter #Peripheral assignment exposes which instance can be assigned to which context.
OP-TEE Linux STM32Cube
Security RNG OP-TEE RNG driver Linux hardware random framework STM32Cube RNG driver
non-secure
Cortex-M4
Security RNG RNG1 Assignment (single choice)
RNG2
4. References[edit source]
