- briefly introduce the PKA peripheral and its main features
- explain how it can be allocated to the runtime contexts and linked to the corresponding software components
- explain, when necessary, how to configure the PKA peripheral.
2. Peripheral overview
The PKA (public key accelerator) is peripheral is used to ease computation of cryptographic public key primitives, specifically those related to RSA, Diffie-Hellmann or ECC (elliptic curve cryptography) over GF(p) (Galois fields).
2.1. Features
Refer to the STM32MP13 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are implemented.
2.2. Security support
The PKA is a secure peripheral (under ETZPC control).
3.1. Boot time
PKA is a boot device, it is used to verify signature on a secure boot processing.
3.2. Runtime
3.2.1. Overview
PKA instance is allocated to:
- the Arm® Cortex®-A7 secure core to be controlled in OP-TEE by the PKA OP-TEE driver through the ECC framework.
- the Arm® Cortex®-A7 non-secure core to be controlled in Linux® with Linux Crypto framework.
3.2.2. Software frameworks
OP-TEE | Linux | |||
Security | Peripheral (PKA internal peripheral) | OP-TEE PKA driver | Linux Crypto framework |
3.2.4. Peripheral assignment
Security | PKA | PKA | ☐ | ⬚ | Assignment (single choice) |
4. How to go further
5. References
