STM32MP13 RNG internal peripheral
Revision as of 15:45, 26 November 2021 by Registered User
  • briefly introduce the RNG peripheral and its main features
  • explain how to configure the RNG peripheral.
The RNG peripheral is used to provide 32-bit random numbers.
2.1. Features[edit source]
Refer to STM32MP13 reference manuals for the complete list of features, and to the software components, introduced below, to know which features are really implemented.
RNG is a secure peripheral (under ETZPC control).
3.1. Boot time[edit source]
RNG instance is used to seed the DPA peripherals which are connected over the interval RNG Bus: SAES and PKA. It is also used to generate random numbers required for secure boot processing such as key generation for DDRMCE encryption key.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
RNG instances can be allocated to:
Chapter #Peripheral assignment exposes which instance can be assigned to which context.
OP-TEE Linux
Security RNG OP-TEE RNG driver Linux hardware random framework
non-secure
Security RNG RNG Assignment (single choice)
Not applicable.
