STM32MP15 SYSCFG internal peripheral
Revision as of 16:42, 18 October 2021 by Registered User
  • briefly introduce the SYSCFG peripheral and its main features
  • explain how it can be allocated to the three runtime contexts and linked to the corresponding software components
  • explain, when necessary, how to configure the SYSCFG peripheral.
The SYSCFG peripheral is used to configure various system aspects like IOs compensation, Ethernet clocking path, …
2.1. Features[edit source]
Refer to the STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are really implemented in ST software.
The SYSCFG is a non secure peripheral.
3.1. Boot time[edit source]
The SYSCFG peripheral is configured by TF-A and U-Boot at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
Linux and STM32Cube can directly change the SYSCFG at runtime from various drivers.
For instance, I2C fast mode plus (FM+) can be enabled for each instance in the SYSCFG so:
| Core
| SYSCFG
| Linux syscon framework[1]
| STM32Cube SYSCFG driver
| rowspan="1" | Core
| rowspan="1" | SYSCFG
| SYSCFG
4. References[edit source]
