CEC internal peripheral
Revision as of 09:45, 13 October 2021 by Registered User
  • briefly introduce the CEC peripheral and its main features
  • explain, when necessary, how to configure the CEC peripheral.
The CEC (consumer electronics control) or HDMI-CEC is an STM32 internal peripheral that allows to receive/send messages from/to devices, such as TV or tuner, through a HDMI cable.
2.1. Features[edit source]
Refer to the STM32 CEC presentation [1] for an overview of the CEC hardware block capabilities.
The CEC is a non-secure peripheral.
3.1. Boot time[edit source]
The CEC is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The CEC internal peripheral can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the CEC framework
| Low-speed interface
| CEC
| CEC framework
| CEC HAL driver
The configuration is applied by the firmware running in the context to which the peripheral is assigned. The configuration can be done alone via the STM32CubeMX tool for all internal peripherals, and then manually completed (particularly for external peripherals), according to the information given in the corresponding software framework article or for Linux® in the CEC device tree configuration article.
| rowspan="1" | Visual
| rowspan="1" | CEC
| CEC
| Assignment (single choice)
Refer to the STM32 CEC application note (AN4066) [2] for a detailed description of the CEC peripheral and applicable use-cases.
