STM32MP13 RNG internal peripheral
Revision as of 09:07, 13 October 2021 by Registered User
  • briefly introduce the RNG peripheral and its main features
  • explain how to configure the RNG peripheral.
The RNG peripheral is used to provide 32-bit random numbers.
2.1. Features[edit source]
RNG1 is a secure peripheral (under ETZPC control).
RNG2 is a non-secure peripheral.
3.1. Boot time[edit source]
RNG instances are not used as boot devices.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
RNG instances can be allocated to:
Chapter #Peripheral assignment exposes which instance can be assigned to which context.
| Security
| RNG
| OP-TEE RNG driver
| Linux hardware random framework
| STM32Cube RNG driver
| rowspan="2" | Security
| rowspan="2" | RNG
| RNG1
| Assignment (single choice)
| RNG2
Not applicable.
