- briefly introduce the DDRPERFM peripheral and its main features
- explain how it can be allocated to the three runtime contexts and linked to the corresponding software components
- explain, when necessary, how to configure the DDRPERFM peripheral.
2. Peripheral overview
The DDRPERFM peripheral is used to count various DDRCTRL events, for performance analysis.
2.1. Features
The read, write and time counters are certainly the ones that are the most useful from user point of view, since they allow computing the DDR read and write throughputs.
Other counters are available in order to monitor the DDR controller arbitration dynamic, refresh commands and low-power management.
2.2. Security support
The DDRPERFM is a non-secure peripheral.
3.1. Boot time
The DDRPERFM is not used at boot time.
3.2. Runtime
3.2.1. Overview
The DDRPERFM is allocated to the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the perf framework.
3.2.2. Software frameworks
Trace & Debug | DDRPERFM | Linux perf[1] framework |
3.2.4. Peripheral assignment
Cortex-M4 (STM32Cube) | |||
Trace & Debug | DDRPERFM | DDRPERFM | ✓ |
4. How to go further
Refer to How to measure the DDR throughput to learn how to use the DDRPERFM internal peripheral via the perf tool.
5. References
