DBGMCU internal peripheral
  • briefly introduce the DBGMCU peripheral and its main features
  • explain, when necessary, how to configure the DBGMCU peripheral.
2. Peripheral overview
The DBGMCU peripheral is used to configure internal peripherals behavior when one of the cores (Cortex®-A7 or Cortex®-M4) enters in debug mode.
For instance, it allows to freeze a watchdog (IWDG) to avoid getting a watchdog reset when the Cortex®-A7 enters in debug mode (via a breakpoint or JTAG break).
2.1. Features
2.2. Security support
The DBGMCU is a non secure peripheral.
3.1. Boot time
DBGMCU is partly initialized by the FSBL at boot time in order to freeze IWDG2 when the Cortex®-A7 enters in debug mode.
3.2. Runtime
3.2.1. Overview
There is no real runtime support for DBGMCU. Instead, users who need to freeze some peripherals for a debug session should complete the minimal initialization done in the FSBL with their needs.
3.2.2. Software frameworks
non-secure
Cortex-M4
Trace & Debug DBGMCU
3.2.4. Peripheral assignment
Internal peripherals
non-secure
Cortex-M4
Trace & Debug DBGMCU DBGMCU No assignment
