MDMA device tree configuration
This article explains how to configure the MDMA internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the Dmaengine overview.
The configuration is performed using the Device tree mechanism that provides a hardware description of the MDMA internal peripheral, used by the STM32 MDMA Linux driver and by the DMA framework.
Hardware description is a combination of:
  • STM32 MDMA peripheral
  • and STM32 MDMA client
At device level, MDMA is declared as follows:
mdma1: dma@58000000 {
    compatible = "st,stm32h7-mdma";
    reg = <0x58000000 0x1000>;
    interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&rcc MDMA>;
    resets = <&scmi0_reset RST_SCMI0_MDMA>;
    #dma-cells = <6>;
    dma-channels = <32>;
    dma-requests = <48>;
The DTS file is located under arch/arm/boot/dts/stm32mp151.dtsi .
Warning.png This device tree part is related to STM32 microprocessors. It must be kept as is, without being modified by the end-user.
The whole configuration remains at STM32 level.
