SDMMC internal peripheral
  • briefly introduce the SDMMC peripheral and its main features
  • explain, when necessary, how to configure the SDMMC peripheral.
The SDMMC peripheral is used to interconnect STM32 MPU to SD memory cards, SDIO and MMC devices.
2.1. Features[edit source]
SDMMC1/2/3 instances are either non-secure or secure peripherals (under ETZPC control).
  • When an SDMMC instance is secure internal, the DMA cannot be used to perform data transfers.
  • STMicroelectronics does not provide secure MMC driver (see below chapter)
3.1. Boot time[edit source]
SDMMC1/2 instances can be used to support memory boot on SD or MMC Flash devices.
The SDMMC3 is not used at boot time.
The SDMMC instances are ordered by address in the device tree arch/arm/boot/dts/stm32mp151.dtsi file:
sdmmc3: sdmmc@48004000 {
sdmmc1: sdmmc@58005000 {
sdmmc2: sdmmc@58007000 {
By default, in OpenSTLinux distribution, sdmmc3 is disabled so the sdmmc1 (SD card on Evaluation boards and Discovery kits) and sdmmc2 (eMMC on Evaluation boards and Wifi on Discovery kits) are respectively aliased to mmc0 and mmc1.
If you enable sdmmc3, it will take the mmc0 alias and the aliases above will shift, so don't forget to update the Linux kernel boot command accordingly!
For instance, 'root=/dev/mmcblk0p6' will become 'root=/dev/mmcblk1p6' to mount the rootfs from the sdmmc1 (SD card) when sdmmc3 is enabled.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
SDMMC1/2/3 instances can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the MMC framework
Chapter #Peripheral assignment describes which peripheral instance can be assigned to which context.
| Mass storage
| SDMMC
| Linux MMC framework
| STM32Cube SDMMC driver
For Linux® kernel configuration, please refer to SDMMC device tree configuration.
| rowspan="3" | Mass storage
| rowspan="3" | SDMMC
| SDMMC1
| SDMMC2
| SDMMC3
| Assignment (single choice)
