STGEN internal peripheral
  • briefly introduce the STGEN peripheral and its main features
  • explain how it can be allocated to the three runtime contexts and linked to the corresponding software components
  • explain, when necessary, how to configure the STGEN peripheral.
2. Peripheral overview
The STGEN peripheral provides the reference clock used by the Arm® Cortex®-A7 generic timer for its counters, including the system tick generation.
It is clocked by ACLK (the AXI bus clock), so caution is needed when this clock is changed; otherwise the operating system (running on the Cortex-A7) might run with a varying reference clock.
2.1. Features
2.2. Security support
The STGEN is a single-instance peripheral that can be accessed via the two following register sets:
  • STGENC for the control. That is, a secure port (under ETZPC control).
  • STGENR for the read-only access. That is, a non secure port.
3.1. Boot time
The STGEN is first initialized by the ROM code, then updated by the FSBL (see Boot chains overview) once the clock tree is set up.
3.2. Runtime
3.2.1. Overview
Linux® and OP-TEE use the Arm Cortex-A7 generic timer that gets its counter from the STGEN, but this is transparent at run time.
Hence there is no runtime allocation decision for this peripheral: both contexts are selected by default.
3.2.2. Software frameworks
| Core
| STGEN
| see comment
| see comment
| Not applicable as the STGEN peripheral is configured at boot time and not accessed at runtime
3.2.4. Peripheral assignment
| rowspan="1" | Core
| rowspan="1" | STGEN
| STGEN
4. How to go further
5. References
