DMAMUX device tree configuration
This article explains how to configure the DMAMUX internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the Dmaengine overview.
The configuration is performed using the Device tree mechanism that provides a hardware description of the DMAMUX internal peripheral, used by the STM32 DMAMUX Linux driver and by the DMA framework.
  • STM32 DMAMUX peripheral
  • and STM32 DMAMUX client
At device level, DMAMUX is declared as follows:
dmamux1: dma-router@48002000 {
    compatible = "st,stm32h7-dmamux";
    reg = <0x48002000 0x1c>;
    #dma-cells = <3>;
    dma-requests = <128>;
    dma-masters = <&dma1 &dma2>;
    dma-channels = <16>;
    clocks = <&rcc DMAMUX>;
The DTS file is located under source/arch/arm/boot/dts/stm32mp157c.dtsi
The whole configuration remains at STM32 level.
