1. PMIC NVM Partition[edit source]
2. STPMIC1 NVM Partition[edit source]
For STPMIC1, the NVM partition has a fixed size of 8 bytes and exports in R/W the NVM shadow Registers bytes (Address 0xF8 to 0xFF) as defined in STPMIC1 datasheet:
NVM_DEV_ADDR_SHR | 0xFF | 7 |
