System build troubleshooting grid
Revision as of 16:19, 14 October 2019 by Registered User
Some typical troubles related to the system build are listed below. Solutions or ways of debugging are proposed for these troubles.
If your trouble is not listed, it's recommended to go through the articles of the system build category.
Symptom Resolution
Distribution Package
repo init ...<br>
repo sync
"The requested URL returned error: 404 Not Found" is displayed
This error has no impact on the process. You can avoid this error by adding the option --no-clone-bundle to your command repo init or repo sync
repo init ...
Some github projects are not accessible
It is convenient to indicate in your $HOME/.netrc your github credentials like below:
 machine github.com
 login "github login"
 password "github password"
Developer Package
make ...
Any build command fails
Check that the SDK is started
